Question about Hamilton Beach 33966 6-Quart Slow Cooker
Slow cooker turns off automatically before going to warm mode.
How do you work the pc crock pot
How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. Quoted from manuals on line
http://www.manualsonline.com/support/other/slow-cooker/manual-2538852
Sep 07, 2017 | Crock Pots & Slow Cookers
Slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Feb 11, 2010 | CorningWare SC60 Slow Cooker
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
Dec 18, 2009 | CorningWare SC60 Slow Cooker
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
Nov 28, 2009 | CorningWare SC60 Slow Cooker
When you set the cook time it goes to warm will it change after it warms up
with this slow cooker it is automatic for temp settings you set the time and the rest is automatic, 1-6 ohurs starts on low and 7 and above start on high it worked out great
Nov 06, 2009 | CorningWare K4903 Slow Cooker
Need directions for presidents choice slow cooker
Heat intensity is warm, 1, 2, 3 (highest)
How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. NOTE: Not recommended using the WARM setting for more than 4 hours at a time. NOTE2: To stop the cooking process at any time, press the "round circle" power button. The unit will default to "0:00" time but the indicator light in the "3" high position will remain on.
Apr 11, 2009 | Crock Pots & Slow Cookers
Corningware k4903 slow cooker
I had the same problem and I had to ask my wife. You must first select the cook time (button on left). The more time you select, the higher the mode (warm, medium, high). Then you turn the unit on. I guess the unit calculates which mode based on the amount of time you select in step one.
Not nearly as intuitive as it should be.
Sep 01, 2008 | CorningWare K4903 Slow Cooker
Warm setting
Units such as the "Countdown" and "Recipe" Smart Pot™ slow cookers have a designated warm setting. Basic Smart Pot™ slow cookers have an automatic warm feature that activates a keep warm function when the cooking time expires. This type of warm feature will not activate without the set cooking time expiring first.
Feb 10, 2008 | Rival 38601 Smart Pot 6-Quart
Rival 38601 Smart Pot 6-Quart Slow Cooker can't get to to go to warm
Here is the manual for this cooker; http://www.crockpot.com/manuals/38601-C_English.pdf page E4 and E5 tells you details of programming/timer/temperature. Check through everything and see if you can figure anything out. after cooking, the unit should automatically switch to warm mode, if it isn't doing this then unfortunately i think it needs a replacement control board - probably not worth doing. If you want to give it a try then post again and we can try and source you the bits Hope this helps :)
Mar 16, 2007 | Rival 38601 Smart Pot 6-Quart
Hamilton Beach 33966 6-Quart Slow Cooker Logo
299 people viewed this question
Top Hamilton Beach Crock Pots & Slow Cookers Experts
Greg Cann
Greg Cann
tsalagi152
Dan Horsefield
Dan Horsefield
Are you a Hamilton Beach Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
