Question about Goodmans Car Audio & Video
Goodmans car stereo/cd malfunction
The cd will play normally for about 1 or 2 minutes then stops playing and displays "Error code 2" message. I have tried the Reset button but to no avail. This is not a disc fault as it appears when playing all/any good quality discs. Goodmans model GCE7109CD
  • 3 more comments
  • Anonymous Feb 19, 2008
  • Anonymous Jul 14, 2008
    error 2 shows on every cd then wont play
  • Anonymous Apr 11, 2009
    same good CDs wont play and displays "Error 2"
SOURCE: will play cd's but cant read dvd's - NO DISC appears
Could be that the lazer is faulty.try multizoning unit. switch on unit with NO disc inside. press enter,press 84269 and press enter again. unit will switch off.
Posted on Feb 22, 2007
  • 2985 Answers
SOURCE: Disc error message
Computer Burned discs are a grey area for some players[different firmware/chipsets] There is a list on the web of players and what they will play a Google/Yahoo will reveal. Also checkout the manual that came with the player.
Posted on Jul 01, 2007
SOURCE: Alpine Ipod/Stereo Error 1 message
Sorry but the ipod should never "die" when it's plugged in. I own this system and have encountered the same problem. The ipod should be continuously charging if plugged in, therefore it should never run out of juice.
Things I've been told to do f rom Alpine themselves:
-Get latest version of ipod software from itunes
-Plug ipod back into unit (via cord) with car turned off
-hold the center button and play button until ipod resets itself
-take off alpine face
-press the little button behind face to reset unit
I have done this with some success. The problem returned once in a while, however, for some reason after doing the process listed again a few months back, I've not had the error.
Posted on Nov 12, 2007
  • 6 Answers
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
Posted on Dec 30, 2007
  • 518 Answers
SOURCE: faulty goodmans 1104s dab player
In the lid should be a mgnetic plate that holds the disc to the motor spindle (much like slight pressure would). Inspect it to make sure it's free moving and seating all the way when the lid is closed. I had one unit where the spindle on the motor shaft had slid down slightly causing the magnetic plate to not seat down all the way. Also, if the magnetic plate is removable, try placing it on the disc with the lid open and bypassed and see what happens.
Hope that helps...
Posted on Mar 06, 2008
CD player doesn't play
It's possible the laser lens has been knocked out of alignment. If there's a code after the ERROR message, you may be able to find a solution by reading the manual for the unit - they can often be found online if you don't have one. Good luck!
Dec 20, 2013 | Dual XDMA6540 Bluetooth CD Receiver...
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
Cd player does not work
1. Check for disconnected speaker wires.
2. If 1, is ok, insert a CD cleaner disc to get the
CD laser eye the necessary cleaning job. Run it
for a couple of minutes, (2 TO 3 Minutes).
3. Insert the CD you want to play, and see results.
4. If you don't get result, then, you got to get it
repaired by a qualified CD technician for defective
parts. Otherwise, you have to replace it.
Nov 21, 2009 | Computers & Internet
CD player wont play disks, showing error 1 instead
The original user manual will define the headunits error readings. It is most likely an internal mechanical failure and will need to be repaired or replaced
May 20, 2009 | Goodmans CD / MP3 car radio GCE780MPT CD...
Error Code Displayed When CD Inserted
Error 01 is normally on most machines to say it cannot read the discs. Could be dirty laser or a defective one. Must open to make better diagnosis.
May 12, 2009 | Jensen MSR4050G CD Player
Eroor 2 code on my goodmans car stereo
Optic lens error. Replace or repair.
May 10, 2009 | Car Audio & Video
Radio won't play, display shows only a code of FB-1
Maybe the code error are F 61 for a panasonic sistem that code means bad audio amplifier
Jan 20, 2009 | Audio Players & Recorders
Sony cdx m8800 error message
if it gives you a cd error message check the cd for scratches.try playing different cd`s
Jul 05, 2007 | Sony CDX-M8800 CD Player
Disc error message
Jul 01, 2007 | Sony RDR-GX300 DVD Recorder
Error message on display of my Pioneer DEH-P8000R
Try buying a cleaning CD that will clean the laser lens and see if that helps. Otherwise it sounds like a trip to the repair shop for you. Good luck.
Feb 01, 2007 | Pioneer DEH-P8000R
Car Audio & Video Logo
88 people viewed this question
Top Goodmans Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Are you a Goodmans Car Audio and Video Expert? Answer questions, earn points and help others
