Question about D-Link NetDefend DFL-700 Firewall
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on server to server. When I run a net view from client (Xp Pro) to server (Windows 2003) using IP address I get network resources not available error 53. I can ping via IP address from client to server fine. What might the problem be?
  • 3 Answers
This is an excerpt from a MS Technet page for error 53:
Resolutions: 1) if it is domain environment, check your WINS; 2) if it is peer-to-peer workgroup, enable NetBIOS over TCP/IP; 3) make sure the machine is running; 4) make sure file and Printer Share enabled on remote computer; 5) make sure client for ms networks is enabled on local computer; 6) make sure you type the correct name. 7) Make sure no firewall running or any security setting.
Pay close attention to #s 4 and 5 - I suspect XP pro might not be open enough.
Posted on Sep 30, 2009
Not recognize dns
Google has many different ip addresses. They have servers I guess you call them everywhere. I downloaded several apps that looked up IP addresses cause the ping had different ones I didn't use. They all led back to GooGle owning that address. Nothing to be alarmed about, theres just no escape from Google, they see everything, track everywhere, and won a lot of different IP
Apr 06, 2017 | TP-LINK Computers & Internet
Tip
Server 2003 & client configuration
<p><span>Some days before I have done a job on Windows Server 2003 Enterprise edition & Client XP. It is departmental food court. In the office room of the restaurant have a system which will be Server system and main domain. There was another 8 system in every department of food <span> </span>with printer for billing.I</SPAN><br> <p><span>Windows Server 2003 includes a mission critical Windows Server operating system, such as security, reliability, availability, and scalability.</SPAN><br> <p><span>You have to install DNS server for DC without DNS the client computers wouldn't know which one is DC.You can host DNS on a different server than DC.</SPAN><br> <p><span>Before Starting the DC installation process you need to make sure the <span> </SPAN>following points</SPAN><br> <p><span> </SPAN><br> <p><span>1)You have installed Basic windows server 2003 installation</SPAN><br> <p><span>2)Make sure you have assigned a static ip address to your server</SPAN><br> <p><span><span> </SPAN>Now start DC and DNS Setup process</SPAN><span></SPAN><br> <a><span> </SPAN></A> <span><span>Domain Controller</SPAN></SPAN><span></SPAN> <span>Active Directory is a huge topic in itself. While DCPROMO is easy to run, planning of both the physical and the logical structure is the key to a trouble free active directory. </SPAN> <p><span>Domain controllers do not have to be your most powerful machines, however they must be reliable and always available to answer logon requests. </SPAN><br> <a><span>DNS (Domain Name System)</SPAN></A><span><span> </SPAN></SPAN><span>Role</SPAN> <p><span>Once DNS is setup, it runs itself thanks to the new dynamic component hence DDNS. TCP/IP knowledge plus understanding of how DNS works is essential when troubleshooting connectivity problems.</SPAN><br> <p><span>DNS enables client machines to resolve servers IP addresses. Once the client finds the server, Active Directory uses LDAP to locate services like Kerberos, Global Catalog that clients request.</SPAN><br> <a><span>Print Server Role</SPAN></A><span></SPAN> <p><span>In my experience there is a contrast between the software settings which are easy to configure and the hardware which constantly need for attention e.g. paper jam, 'out of toner'. Check list for print server:</SPAN><br> <p><span></SPAN> <br> <p><span>Printer Priority</SPAN><br> <p><span>Network Printers</SPAN><br> <p><span></SPAN><br> <p><b><span>Client Configuration :- </SPAN></B><span>After</SPAN><span><span> Installation of Windows Xp give the IP Add on TCP/IP of IPV4.If you want to manually configure DNS server addresses, click</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Use the following DNS server addresses</SPAN></b><span><b><span>,</SPAN></B></SPAN><span><span> and then type the preferred DNS server and alternate DNS server IP addresses in the</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Preferred DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>and</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Alternate DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>boxes. After all job try to ping each other. I'm trying this and it also pinging. Files and data also can be shared through it.</SPAN></SPAN>
on Feb 15, 2011 | Computers & Internet
Frequent VPN connection drop on my wifi
If you can't connect via the Internet to your workplace network from home (or another location), check the items in this list:
  • Make sure that you typed the virtual private network (VPN) server name exactly as provided by your network administrator.
  • You must have an active Internet connection for a VPN connection to work.
  • If your modem is external, make sure that the modem power is turned on.
  • Contact your network administrator to make sure that you have the appropriate connection and domain permissions on the remote access server.
  • This could be a certificate problem. For assistance, contact your network administrator.
  • A VPN connection won't work with an active Winsock proxy client. Contact your network administrator to make sure the Winsock proxy client is not enabled.
  • If you know the IP address (for example: 131.107.10.25) of a website, type that address in the address bar of your web browser and press Enter. If this works, there is probably a Domain Name System (DNS) resolution problem. For assistance, contact your network administrator.
  • If you have special software that's required or installed by your workplace, it could be part of the problem. For assistance, contact your network administrator.
  • If you know the IP address (for example: 131.107.10.25) of your VPN server, type that address for the VPN connection, and then press Enter. If this works, there is probably a DNS resolution problem. For assistance, contact your network administrator.
  • There could be a problem with the server you're trying to connect to. For assistance, contact your network administrator.
If you try to connect with a VPN connection and you see a message that says "The local computer does not support encryption" and has the error code 741, it's possible that the encryption that your computer uses doesn't match the encryption used by the VPN server. To change the encryption settings so that your computer uses the recommended setting of 3DES, follow these steps:
  1. Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
  2. Right-click the VPN connection, and then click Properties.
  3. Click the Security tab.
  4. Under Data encryption, select Maximum strength encryption (disconnect if server declines), and then click OK.
  5. Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
  6. Click the VPN connection, and then click Connect to try connecting again.
Apr 21, 2013 | Belkin Surf N300 Wireless N Router
I can't connect through network can't connect by pinging
Can you ping your router?
If you can, log into it and see if you have any problems with it. If you have ADSL, you will see the status of the line as well as whether you are connected or not. You may have a diagnostic feature that will test the connection to your provider.
If you have lost DNS with your provider, you will not be able to ping using names, only by IP addresses.
Jul 24, 2011 | Computers & Internet
Having problem internal network to connect outside but the router itself can ping the outside domain or public domain/IP. The Internal Network cannot ping the domain or cannot connect to the internet what...
1.Check whether there is ping to router from lan computers.
2. If there is no ping then check the cable b/w lan computers 7 router.
3.Else if there is ping to router, then check ur router for any ip blocks, access lists etc..
4. Turn - off the local firewall, so there also a chance of it blocking access to internet
Sep 27, 2010 | Cisco 881 Fast Ethernet Security Router
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
So you verified ICMP traffic isn't blocked and it appears the servers allow the netBios traffic to pass.
On the client machine, check to make sure the windows print and file sharing is installed and the machine isn't blocking netBios traffic.
Make sure TCP ports 137,139, and 445 are open on the xp machine and any devices in between.
It's acting like the TCP data is being blocked by the client machine.
HTH,
-Aaron
Sep 28, 2009 | Microsoft Windows XP Professional
Unable to get remote desk top computer to work on acer aspire one
I think you're trying to connect to your office computer from home/somewhere else.
If that's the case, make sure you have done the following :
  1. Your VPN Session is connected
  2. Your Office IT Administrator allowed RDC over VPN
  3. Your Office Computer RDC is enabled
  4. Your User (local or domain user) having administrative rights or allowed to connect to RDC session
  5. You got no firewall blocking RDC connection or remote registry
To check if you already connected to your office VPN, launch command prompt and try pinging your office computer name or IP Address. As an example if your office computer name is PC-100 and IP address is 192.168.1.100 then you will issue : ping PC-100 or ping 192.168.1.100. If you got ping reply than you're good to go.
To Enable RDC on your office computer there are 2 ways :
1. On your office computer, right click my computer > properties > Remote > Enable Remote Desktop
2. Via remote registry :
- Start > Run > Regedit > Enter/Return
- On registry editor, go to File > Connect Network Registry > Type in your office computer name > OK
- On your office computer registry, browse to : HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Terminal Server, find the key "fDenyTSConnections", double click it and change the value to 0
You should disable your windows firewall or 3rd party firewall for easier configuration. You can;however set up exception on your firewall but will need some knowledge to do that.
Hope it helps.
Nov 02, 2008 | Computers & Internet
Difference between DNS and WINS
WINS is Windows Internet Naming Service, a system that determines the IP address associated with a particular network computer. This is called name resolution. WINS supports network client and server computers running Windowsand can provide name resolution for other computers with specialarrangements. Determining the IP address for a computer is a complexprocess when DHCPservers assign IP addresses dynamically. For example, it is possiblefor DHCP to assign a different IP address to a client each time themachine logs on to the network.
__________________________________________________
DNS, a.k.a Domain Name System is a database system thattranslates a computer's fully qualified domain name into anIP address.Networked computers use IP addresses to locate and connect to eachother, but IP addresses can be difficult for people to remember. Forexample, on the web, it's much easier to remember the domain namewww.amazon.com than it is to remember its correspondingIP address (207.171.166.48). DNS allows you to connect to anothernetworked computer or remote service by using its user-friendly domainname rather than its numerical IP address. Conversely, Reverse DNS(rDNS) translates an IP address into a domain name.
Jul 20, 2008 | Microsoft Windows Server Standard 2003 for...
Vpn error. 800
Resolutions: 1) if you have firewall, open TCP Port 1723, IP Protocol 47 (GRE). 2) make sure you can reach the VPN server by using ping. Sometimes, poor connection can cause this issue too. 3) You may need to updated firmware on a router or firewall if other OS (win9x/nt/me/w2k) works except XP. 4) The VPN server may not be able to get IP from DHCP for the VPN client. So, you may want to re-configure VPN host networking settings. For XP pro VPN host, go to the Properties of the VPN>Network, check Specify TCP/IP address and Allow calling computer to specify its own IP address, and uncheck Assign TCP/IP addresses automatically using DHCP. 5) Make sure no other secure software blocks your access, for example, if you use Norton secure software, you may need to add the remote client's IP so that the client can access. 6) If your VPN running on a Windows RRAS with NAT enabled, you may want to check the NAT settings. 7) If you can establish the VPN from the desktop at home but not from the laptop. Make sure no security software like Microsoft OneCare software that blocks the GRE.
Oct 01, 2007 | Acer Aspire 5100 Notebook
D-Link NetDefend DFL-700 Firewall Logo
134 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
