Question about Audiovox Bosch 718 World Cellular Phone
How do i change the grey door seal on my Bosch washing machine?
Replacing the door seal of a bosch maxx 1000
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Aug 26, 2010 | Bosch Washing Machines
I have a hole in the grey rubber seal that connects between the drum and the front. water leaks through and down the inside front panel of the machine. Can i buy a replacement part? How hard is it to...
You can buy a new door seal.
It is a fairly tricky job to do it your self.
To get some one to fit it, I would expect you tp be paying around £70.00 to £90.00 depending on who you get, so get some quotes.
Hope this helps.
Dec 02, 2009 | Bosch Axxis WFL 2060 Front Load Washer
We have a Bosch Classixx washing machine which infrequently stains quite badly items in the wash. Have made sure it is cleaned frequently
pull back door seal lip as far as it will go and you will find grey scum underneath this will stain your laundry during wash need to manually wipe out and put on 90 degree wash with biological detergent anything less wont touch it.
Nov 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
I need to change the door seal on a bosch washing machine is it tricky
This video will show you how to change a door seal on this Bosch Classixx WFL 2066 Front Load Washer washing machine
Nov 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
New Bosch water not draining
Apr 01, 2008 | Bosch Axxis WFL 2060 Front Load Washer
BOSCH Washing Machine -Door Seal
1) remove the tension ring under the rim of the seal at the front
2) flip the whole seal into the drum so that you can get at the inside of the seal
3) remove the tension ring hold the seal to the outer tub
4) reverse of the process to put in the new seal
Its as simple as that.
Mar 09, 2008 | Washing Machines
Audiovox Bosch 718 World Cellular Phone Logo
48 people viewed this question
Top Audiovox Cell Phones Experts
Spud Howell
John Porter
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
