Question about Philips Standard 107S 17" CRT Monitor
Have a phillips 107s monitor, green led flashes, making a tick tick sound, no display
    President:
  • 1,653 Answers
Make sure the mains plug is firmly inserted. The most likely cause of the problem is a power supply problem which will be uneconomical to repair in the current day. Cheaper to replace with an LCD.
Posted on Sep 28, 2009
17" flatron crt monitor only green led blinking and tick tick sound .No display
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | LG Flatron F700P 17" CRT Monitor
Dell monitor E173FP power led flashing green, no video
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Mar 07, 2014 | Dell E173FP 17" LCD Monitor
Problem on LG Flatron ez T713SH crt monitor
i have the same thing, monitor display is dark and tick tick sound audible and thats all it do untill now..
Feb 15, 2010 | Computers & Internet
Acer al1713 monitor and the power led flashes form yellw to green
The short answer, replace all of the capacitors. They can be bad without swelling. And there may be one 47mf/16v off to itself, if it fails, monitor will not come on. Also, check the menu or mode setting to make sure your VGA/DVI agrees with the cable if the monitor has both.
Jan 01, 2010 | Acer AL1713 17" LCD Monitor
X2 MW19R is ticking and no display?
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details or if you have any questions.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 13, 2009 | X2Gen MG19MY 19" LCD Monitor
The monitor is on but no signal
Hi
This monitor is trying to start but can't. The sound you're hereing is the B+ supply coming on and trying to start the high voltage system. Something down line, either the high voltage transformer or the Horizontal output circuit is faulty. I have repaired thousands of these. Generaly at $100. to $150. depending on parts. You can spend it to my company for repair or take to a local serviceman. If you decide to junk it and but a LCD monitor I would have to agree.
Thanks
Jul 24, 2009 | Philips Standard 107S 17" CRT Monitor
Samsung 191T Blank
You need a fluorescent back light and inverter kit. Available on eBay.
Jun 10, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
No display
The ticking sound is from the DC source voltage being fed into the flyback transformer. Because the transformer coil has one or many shorted components attached to it, it won't start. This monitor needs to see a pro to fix it.
Apr 27, 2009 | NetTV DTV 34X 34 in.CRT Conventional...
Aoc 5en no display
I alreeady encountered this problem. I fix it temporarily.... I just turn it off, Press all the Function btn and the recall btn, then pres the On btn... wait for 2 sec then release the func, recall btn. Then I already able to use the PC for about o hours without interrupted signal (on/off). I call it temporary fix because whenever you turn off the Monitor, you have to do the same process again..
Try it it can help.. Thnaks.... If you already find solution , maybe you can share it to me too .. Thanks..
Jun 25, 2008 | AOC 5 En 15" CRT Monitor
Philips Standard 107S 17" CRT Monitor Logo
238 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
