Question about Samsung S1050 Digital Camera
Samsung S1050 the moveable lens keeps jamming and I get no
The moveable lens keeps jamming and I get no picture on the viewfinder.
Only way to free the jam is to take batteries out and put them back in again but a minute later it jams again. Car'nt get no picture at all on hte camera. I've tried different batteries but this serious fault remains
My samsung s1050 keeps locking up intermitantly. beem stays on.lens freezing.have to re insert batterys over and over to get working. any ideas?
The Samsung S1050 is very battery hungry - make sure you use very fresh new batteries, rechargeable are great - the higher the mAh rating the better. I use Intec rechargeable batteries which are rated at 2900 mAh. If you do use rechargeables, you will have to set the appropriate menu setting for battery type to reflect the type of batteries used.
Jan 25, 2011 | Samsung S1050 Digital Camera
Samsung S1050 -out of focus - beeps twice and switches off
The drop indicates that you have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 14, 2009 | Samsung S1050 Digital Camera
S1050 frozen
Today (2009/11/21) have the same problem with the black model of s1050, sometimes ear the motor running but the lents dont move and the cam still dead.
Source problem : Photos whith ASR+Macro+5xZoom and switch to AUTO+Macro+5xOptical+3xDigital
Aug 03, 2009 | Samsung Digimax L830 Digital Camera
Over exposed pictures
look ur CCD is BAD !!
just call samsung i am sure they will do it Free becoz it is a manufac fault all manufacturers are doing it Free just call them and ask them about BAD CCD !!
Pls rate me WELL !
Jul 03, 2009 | Samsung S1050 Digital Camera
Image is very bright after picture is taken
try lowering or changing the setting of your cameras flash.
thanks.
Jun 20, 2008 | Samsung S1050 Digital Camera
Viewfinder jammed
The mechanical link between Lens on V/F element has broken - Only Olympus will be able to do anything for you -check out the support site.
Aug 19, 2007 | Olympus Camedia C-5050 Zoom Digital Camera
No visible picture in camera mode
Hello Kenza, replacement of CCD that belongs to Lens device. Please contact your nearest Samsung Service. Best regards, Arpad
Sep 04, 2006 | Samsung VP-D20 Mini DV Digital Camcorder
Why is part of a picture missing?
The cause and solution may include one of the following: Something was blocking the lens when the picture was taken. Keep hands, fingers, or other objects away from the lens when taking pictures. Your eye or the picture was not centered correctly in the viewfinder or LCD. Leave space around the subject when centering the picture in the viewfinder or the LCD.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Samsung S1050 Digital Camera Logo
132 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
