Question about Canon EOS 40D Digital Camera
Hi, when i turn on my camera all appears ok, but when i click any buttons incuding the shutter the 'busy' sign comes. Any Ideas?
jackboy
  • 2985 Answers
SOURCE: Shutter release button is stuck
You have two choices 1. take it to a repair shop and get a quote[almost the price of a new camera I wager] 2. Try your self[bearing in mind that if you cant fix it you'll have to buy a new camera] Chances are the in dropping it the button has forced it self through an aperture in the casing so that it cannot return. If you have access to fine screw drivers[Jewellers/watchmakers]slack off the screws holding the case together- done take 'em right out just slack 'em-it might pop right back out- if it does tighten up.
Posted on May 07, 2007
SOURCE: Canon Digital Rebel XT will not take pictures
turn camera off, take out battery, put in a one you know is charged up. Then turn on camera and try again. The numbers may just be from in the 'info button' and will disappear when taking a photo. I am wondering if the battery is dead is why the shutter won't work and has nothing to do with 'numbers.'
Posted on Oct 18, 2007
HeavyDLB
  • 46 Answers
SOURCE: shutter button not working
Dear phill523:
Unfortunately the solution is to call Canon (1-800-828-4040) and send the camera into the Service Center for repair.
Hope this helps a bit.
Sincerely,
HeavyDLB
Posted on Jun 03, 2008
SOURCE: Busy sign on LCD
GO **** YOURSELF!!!!!!!!!!!!!!!!
Posted on Jul 04, 2008
SOURCE: canon 20D error 99 shutter stuck
i hust send it to repair lest wait...
Posted on Aug 28, 2008
'err' sign on display nikkon D80, and appear r 15 when shutter button is press
"rXX" is just the camera estimate of how many pictures left on memory card. As for "ERR": while camera is in "On" position, take out battery and hold shutter button approximately 30 seconds. Turn camera "off, replace battery and turn "On" again. If thre is a hardware reset button (check manual carefully) while camera is "On" use that reset button/
Feb 19, 2011 | Nikon D80 Digital Camera with 18-135mm...
Press shutter releas button for error are coming ,wat is the Problem
1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR ' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR ' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR ' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR ' with a different Canon lens attached, then the camera should be serviced.
Nov 17, 2010 | Nikon D40x Digital Camera
The display does not come on, there is a "busy" sign flashing
Sounds like the problem Canon had to fix for me with my S2 IS which did the same thing. My camera shot blank pics. It turned out to be a stuck shutter. The camera makes all the usual noises, but the shutter is stuck closed.
Sep 08, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon Rebel XT wont fully come on
Hi
Error 99 is usually a lense error and gives the only real clue as to what is going on with your camera. You can try this simple fix which comes straight from Canon. Follow the steps to help isolate the issue. Note the fact that you are currently not getting the Error 99 is probably a good sign according to the troubleshoot.
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
Hope this helps. Please do rate my answer. Thanks.
Aug 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon eos 30 d is having err 99 problem after every five ok click
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Dec 29, 2008 | Nikon D200 Digital Camera
Canon 40D LCD Wont come on buSY flashes in view finder
Okay, this is simple. Your camera can take several pictures at one time in a burst. However when you release the shutter button your processor takes a second to actually SAVE the pictures to the card in the camera. One thing than has helped me in my wedding photography business is to buy the fastest speed cards I can find. It significantly reduced my "busy" time.
Nov 30, 2008 | Canon EOS 40D Digital Camera
Shutter locked up while reviewing stored pics
Problem not solved at this time. However the Optio web site offers live chat. M-F 9:30 am to 6:30 pm. I will contact them to discuss later today. I will post their recommendations. Thanks Txlingo
Sep 28, 2008 | Pentax Optio S4i Digital Camera
Oct 18, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Camera shuts off when you click the shutter button
The same thing happened to mine. While not a solution, my workaround has been to turn the LCD screen off when I'm shooting. It's worked so far.
Jul 21, 2007 | Fuji FinePix 2650 Digital Camera
Canon EOS 40D Digital Camera Logo
97 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
