Question about Pasquini Livia 90 Espresso Machine
Where can I get an owners manual for a Pasquinin, Livia 90?
  • 3,289 Answers
I found a writeup about this machine below. It has a great deal of information that may help you out:
http://ix.cs.uoregon.edu/~michal/espresso/livia-90.html
Additionally, you can contact the maker directly, and they should be able to supply you with a printed owner's manual. Their web page is below:
http://www.pasquini.com/
Posted on Sep 28, 2009
How do i replace a touch pad
See user's manual, if any hint. Actually, didn't know that asquini Livia 90 Espresso Machine has a touchpad. Looks a really interesing device!
https://www.seattlecoffeegear.com/assets/user-manuals/pasquini/pasquini-moka-grinder-user-manual.pdf
May 13, 2015 | Pasquini Livia 90 Espresso Machine
How to take the water reservoir out the livia 90 espresso machine
Hi
It should lift straight up. If it is one of the newer machine, it will lift right out. If it is an older machine it will have a wire attached to the left side of the tank. The wire will pull off at the terminal. Pull straight off at the same angle or you might damage the tank. Rember to reattach the wire when putting back in.
May 02, 2011 | Pasquini Livia 90 Espresso Machine
Pasquini livia 90 will power up for only few seconds and then shut down you know what iy maybe?
Try this open the steam valve when turning the machine on, if that works then the vent valve needs to be replaced, or the p.stat is damaged.
Feb 18, 2011 | Pasquini Livia 90 Espresso Machine
I need the parts diagram for the pasquini livia 90
I found something on amazon, click here and take a look: Amazon com pasquini livia 90 parts. I hope this was helpful. Cheers
Nov 18, 2010 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90: heats up for about 5 minutes, then shuts off
Sounds like the pressure switch is not working properly and the safety is turning the machine off. Try checking the tube from the boiler to the pressure switch that might be blocked, if not then the pressure switch needs to be replaced.
Jul 21, 2010 | Pasquini Livia 90 Espresso Machine
I have a six plus year old Livia 90 Semi Automatic. It builds up pressure and then releases through the release valve, sometimes every 10 minutes, sometimes not for a couple of hours. Always quite a...
This is a simple fix. This has been fixed on newer units with a rewire kit. This rewire kit is for Pasquini Livia 90’s with serial numbers PRIOR to #49000. We have them listed on our website Part# 90000 for $30.00.
You can contact me for this part - If you are local we could install it for you. If you do not fix this problem soon, you will need a new pressure release valve. It would also be advised you get a microswitch #7633905 for $13 at same time as the rewire kit. If you still require a manual we could provide you with a digital version.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Jan 16, 2010 | Pasquini Livia 90 Espresso Machine
Need a manual for Pasquini Livia 90
Hi I have one that I wrote if you want it. Send me your e-mail and I'll sent to you.
May 30, 2009 | Pasquini Livia 90 Espresso Machine
Livia 90 Lights come on then off, hums but not pumping
It is possible that the pump is blocked or damaged, remove top and side panels and check lines going to and from pump, you can run the machine without the panels and you will be able to see if the water is moving to the pump or if the pump is vibrating.
Feb 22, 2009 | Pasquini Livia 90 Espresso Machine
All 3 lights on Livia lighting up with hot water use
Is this a Livia 90 semi or auto ?? It sounds as if you are talking about an auto. The autos have had a history of the cpu controller board going out. Probably going to have to take it in for service for proper diagnostic repair. Parts are not cheap and with no warranty- you don't want to start throwing parts at it to get it working right.
Jan 27, 2008 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90 Espresso Machine Logo
315 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
De Brewerz
De Brewerz
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
