Question about Nikko Toys
How to charge nikko jumping car with its charger .i cant find the pin.
2 Suggested Answers
SOURCE: How do you activate the jump control on the nikko
Car needs to be traveling forward at speed to enable jump mechanism to operate. Information available from Google access of patent application.
Posted on Dec 18, 2009
What is the charger part for JNC300XL jump starter
you should have a red and yellow button on one side Right above it is a small AC adapter hole for a plug in charger.. IF you cant find the cord or you lost it, You still can charge it by hooking it up to a running car red to red and black to black for 10 mins and it should give it a good charge, IF fully dead leave it for 20 mins or hook it up to a battery charge low amp like 2 amps and leave it for 5 hours and do 1 hour each month unless used to start a car.
Aug 25, 2014 | JNC300XL Jump-n-carry Ultra-portable Jump...
Lost charger
if you are right and it has been discharged for this long it will take a long time for it to start to charge.it could also not charge ever again. batteries have to have a minimum off 1.5volts to be able to recharge. if it drop lower than this it cannot charge. now sometimes you can jump start the battery with a slightly higher voltage but only to the battery not in the unit. goes as follows. 1.5v battery jump 3 seconds on 3volt. 3v battery jump 6volt 3 sec, 9volt jump 12volt 2 seconds, 12volt 14-16volt 2 seconds 2 times. 14volt and 16volt is max 24volt 1 second at 3 intervals. all these are set at a 3amp no higher amp.
Mar 05, 2014 | Emerson 7" Atsc Lcd Tv Etv-070 Black...
Charging schematic for pride scooter
red + goes to pin 1, black - goes to pin 2 and jumps to pin 3
Dec 29, 2013 | Pride Rally 3 Wheel Scooter
Jump start
c85a2fd9-af0e-4d08-89b4-66fb0b469e10.jpgThe motor home battery I couldn't teel you but if you're talking about the vattery for yhe charger, it's located in the Passenger side inside the trunk. There is a cover over it that has to be removed to get access to it. If jumping, there are posts next to the battery I believe designed just forr jumping. I would REALLY suggest just charging the motor home batteries or using a different vehicle to use. Have found on your kind of vehicle that sometimes when getting jumped or visa versa That it causes an electrical problem. there is a fuse link in the wiring directly (sort of) from the battery to the alternator. Have seen this fuse link blown a lot and MANY people change the alternator thinking the alt. is bad beause the battery goes dead not to mention the car letting you know thta there is a charging problem.Hope this helps.....
Jun 04, 2013 | 2007 Dodge Charger SRT8 Sedan
Cant get it to charge correctly how do i fix it ?
The charger not only has to fit identically but must have identical electrical characteristics.
Jun 21, 2017 | SanDisk Sansa Audio Players & Recorders
I have a homelite 720 generator but cant fingd the instruction manual and i need to know if the charger leads only charge a battery or can be used as jump leads i know this might sound stupid but i wo
I can't find any reference to a Homelite model 720 generator but most battery charging systems do not supply enough amps to run a car starter. Battery chargers usually work in the two (trickle) to ten amp range. Car starters need way more amps to have enough power to turn an engine over, depending on the size and number of cylinders in the motor. Some chargers have a switch with a 60 amp 'start' position to help the battery turn the motor over, but without that there is little chance the charger side of your generator will supply enough amps to help your battery.
Feb 21, 2012 | Cars & Trucks
Why when i charge my bb the touc doesnt work|?Wht can i do?/
I changed the battery and the wall charger , found out the earlier charger pin was faulty causing the screen to hang while trying to use during charging
Nov 23, 2011 | RIM BlackBerry Storm 9530 Smartphone
K700i NOT CHARGING
the mains charger may be dead or the charging connector broken, the tiny pins on the connector break easy, common fault on sony ericsson chargers, try using the usb cable if you have one with your pc, when you plug it in, select 'media transfer' and the fone should start charging, if it charges then fone is ok but mains charger is bad, if you cant get it to charge either way then battery may be worn out and needs replacing.
Jan 14, 2011 | Sony Ericsson K700
How do you activate the jump control on the nikko jumping car. The red button doesn't seem to operate anything. Does the car have to be at a particular speed. Do you need to release the spring mechanism.?
Dec 17, 2009 | Nikko Toys
Nokia 1600 charging problem
the fuse is burned go to a cell phone service and have them replaced .
May 26, 2008 | Nokia 1600 Cellular Phone
Toys Logo
170 people viewed this question
Top Nikko Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a Nikko Toy Expert? Answer questions, earn points and help others
