Question about Sony Audio Players & Recorders
My sony s-master HCDFC7 has a red light on and the unit will not power on
Same exact problem here..I have replaced internal fuse to no prevail. Also looking for expert solution.
Posted on Oct 10, 2009
I have a sony s-master digital amplifier which will not power up: when I plug it i to power it takes about 30 minutes before the red standby light comes on but no other functions operate.
So the standby indicator never changes state? If so, more than likely, your amplifier has DC Offset(a damaged amplifier inside) which will keep the speakers off, and disable any use of the front or remote functions. If you are interested in having your Sony repaired, please refer to my website, audioserviceclinic.com. You may contact me there. Thank you.
Jul 11, 2015 | Audio Players & Recorders
ERROR D-08-224 ON DISPLAY
Error type D08: Master making unit not setError point 224: Master making unit is not set (both the safety and lock sensor are OFF)
Try this: Set the master making unit in place.
Aug 15, 2012 | Riso Office Equipment & Supplies
Mhc-rg222 red light blinks power button wont turn on unit
Check the back of the unit for speaker wire shorts, if everything looks fine suspect the output ic's in the stereo.
May 26, 2012 | Sony MHC-RG222 CD Shelf System
Screen is black: eventhough the red power buttons on will not respond to power on button.
tv will not turn on. Red lights indicate power to unit, no change when on button is pushed. I have tried powering the unit down with the master power button and also unplugging the power cord from back of unit. No change
Aug 11, 2010 | Hitachi 26HDL52 26 in. LCD Television
Red light flashing
Unfortunately, this is a "Return to Sony" situation.
The flashing red light issue is often caused by power or system board issues which require some disassembly and soldering to fix.
The simplest solution is to return the unit to Sony. If it is still under warranty, the fix will be free; otherwise it'll cost $150.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
Mar 09, 2010 | Sony KDS-50A2000 50" HDTV
Try to turn on my ps3,after 2or3 sec it turns off and just blinks
HI, the power unit is experiencing some difficulties due the an overheating issue. if the light is turning yellow at any time, this will confirm a overheating issue. Now, if the light is simply turning red and, powering off then system with a red blink, this will confirm a power unit failure. you will need to replace the power unit in this case.
Contact your nearest Sony repair shop of, contact Sony manufacture for this repair.
NOTE(If its a simple overheating issue, you can purchase a cooling device to heel this issue)
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Repeating 5 flash red on power light, no power up
When the red light blinks five times that would indicate that there is a problem with the "Lamp Driver". That would be Sony part 1468798-14 for a Sony KDF-41WE655.
Aug 07, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
250 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
