Question about Imperial Refrigerators
Icemaker needs replaced where to find (num.on outside of icemaker IM #S 106 626640 - inside part num 2194712 vendor 10504 cavity 5 need cost and availability in phx.AZ.
2 Suggested Answers
  • 1891 Answers
SOURCE: whirlpool ed25dq icemaker not working even though
the water valve maybe the problem as it is a dual one,, and if filter moded it has 3 solnoides flow . that control water . ck sol with ohm meter or test cord . . ice maker also works only at 15 deg or lower . so ckk tempt of freezer .. mm
Posted on Jan 07, 2010
Unwanted downloads
if u cant contact the vendor tel your bank to stop pay or get a replacement credit card with new num
May 27, 2012 | Cell Phones
My Harley has a bad ignition control module and where it's located at there are what looks like 2 pot rivets holding the outside cover is this factory do I just drill them out and put new ones back...
Yes, you do have to drill the heads off the rivets to get the cover off the timer cavity. Drill just enough to get the heads off the rivets with a large diameter drill bit. Before you remove the old ignition unit, mark the unit and the inside of the timer cavity so that you can install the new unit in EXACTLY the same position. This way you'll get the timing right. Do not use standard rivets to reinstall the cover plate. They are special rivets. Standard rivets will allow the broke piece to drop into the timer cavity and destroy your igniton system. You can get the rivets from you local dealer or you can replace the cover with a decorative aftermarket cover that uses screws instead of rivets.
Good Luck
Steve
Jul 30, 2011 | 2000 Harley Davidson XL Sportster 883
Hi my problem is yellowing colour on the white but only in the middle not on outer 150mm section of screen though. also im only new to this mamoth r.p.tv so i wondered if a new bulb will fix my colour...
laurenkristy,
You have a bad color wheel. The lamp may also need replaced depending on how old the set is and the number of hours. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which will help you replace the light engine and give the best place to get a replacement. I also have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains when you need to replace your lamp, why and where to get the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Aug 20, 2010 | Samsung HLM617W 61" Rear Projection...
My icemaker works slow to make ice. Sears Kenmore side by side refrigerator. Model.57572791
check temperature in freezer compartment,needs to be near zero,if it is,there may be a problem with the internal thermostat on the icemaker,also checkthat the icemaker mold is filling completely with water,all the cavities should fill
Jan 22, 2010 | Frigidaire FRS26H5AS Side by Side...
Icemaker problem
Good day,
with a small paper cup, pour water in the ice maker cavity to near full. make sure it's turned on, and close the freezer door and wait approx 3 to 4 hours. See if it dumps. (I've had new ones out of the box that never worked).
If the ice maker checks o.k. then it is one of two problems.
1. The fill tube that runs from the back of the ice maker to the outside rear of the machine, has become blocked with ice.
Remove ice maker, and inspect closely. If iced, defrost, but be carefull with heat. A lot of plastic and vinyl there that is easily ruined.
2. If that checks O.K., and you get water in the door, then the dual water valve in the bottom rear is bad, and needs replaced.
Dec 14, 2009 | Televison & Video
Pool of water at the bottom after is is ran
Where is the pool of water. At the bottom of the dishwasher (inside) or on the floor (outside)??
I'm assuming outside...You'll need to determine if the water is coming from the door or out from underneath the unit.
If it is coming from the door, this is usually the door gasket. Easy to replace and not too expensive!
If it is coming from underneath, then the leak is coming from a seal around where the motor shaft penetrates the interior cavity or there is a crack in the cabinet cavity itself.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | GE Nautilus 24" Built-in Dishwasher
We have a brand new 5 ton ac unit the part that goes outside how we got it is a long story but a good one but we need to but the other half that goes in the celing and idea how much this should cost me and...
This is called an "A" coil. You need a 5 ton "A" coil to match your outside unit, give or take 1/2 ton. The cost will vary greatly depending on the make of your unit.
Sep 29, 2009 | Heating & Cooling
Icemaker makes too few cubes
Find the water source for the ice maker(most are under the kitchen sink and are tapped off of the cold water line to the faucets) You need to either shut off the tap by turning it clockwise until it is closed. Then you need to disconnect the vinyl tubing from the valve. get a bucket and place it where it will catch the water from the tap. Gradually open the tap by turning it counterclockwise until water starts to come out of the valve. If you have a large enough bucket open the valve all of the way. If the stream of water does not change then the valve is bad and needs replacing. If the stream is nice and strong then the valve is ok. Turn the valve clockwise to close it, reattach the vinyl tubing and open the vale all of the way. This should improve the quanity of ice cubes. If not then there is a cripmp in the vinyl line between the tap and the solinoid valve on the back of the refrigerator.
Jul 18, 2009 | LG LRSC26910 Side by Side Refrigerator
Need to know amprage and polarity
According to several sites this monitor needs a 12-volt 4-amp adapter. Virtually every laptop that uses a coaxial power plug has the center pin positive and the outside shell ground. A Google search for "ct1810 replacement adapter" turned up several sources. Here's an eBay auction currently running for one vendor. If you're outside the US you should be able to find a suitable replacement on the Internet or perhaps locally.
Apr 27, 2009 | Computers & Internet
Ice maker not making ice
1)First check you have a water line that is getting water to the ice maker.
2)Ice makers have a valve at the bottom that open and close when told by the ice maker replace that cheap fix.
3)The ice maker needs to be repaced.
(how far into the line will the water freezehow far into the line will the water freeze)
.The valve at the back opens and closes will not leave water in the line to freeze.
Dec 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
288 people viewed this question
Top Imperial Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Imperial Refrigerator Expert? Answer questions, earn points and help others
