Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Flashing green button, won't reset or turn on
Tv shut off, green light blinking, won't reset. read about a similar problem from someone else troubleshooting. told to replace the 4 caps that sometimes bulge. question is, is how do we find and replace the 'caps'? where are they located on the tv??? would be greatly appreciated, don't want the $300 minimum bill for taking it to the repairman. I have a WS-65513 65 in. Mitsubishi that I noticed one night that the tv screen was blinking and shut it off and the next day turned it on and the tv started to blink and the volume went all the way up by itself, I tried to do something with the remote but it did not work. I shut the tv off and turned it back on and got the dreaded blinking light! Every once and awhile I can get it to turn on by pushing reset and then unplugging it while it is still blinking, but I can not do anything with the remote. Your help would be apprecicated.
  • JJSV Dec 24, 2007
    TV turned off by itself and noticed the green blinking light on front panel. Can't turn it on via remote/front panel button. Tried to reset but did'nt work. Three days ago the blinking stopped and I powered it on via remote. It was OK that week of the Choir competition on MBC but the problem started again on Dec 22. Tried everything: reset; unplugged and replugged;and I even have a surge protector with it! I give up ... don't know what to do and Christmas/guests are coming! Whheeewww!
  • Charles88 Dec 24, 2007
    flashing green button, won't reset or turn on problem.
    President:
  • 4,402 Answers
Http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Posted on Dec 18, 2007
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
You have to replace the faulty capacitors on the DM Board.. Even if you have some experience in electronics a service manual should prove very handy.. Its got full schematics and how to guides so that if you just have minimum knowledge about using a multimeter you can fix it yourself..
http://www.user-manuals.com/service-manual-MITSUBISHI-WS55859.html
Mar 22, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Our tv won't turn on light blinks a couple minuate and then turns read again and lamp light flashes red
A possible bad lamp if not replaced recently or removed and at least examined. What is model number and what have you tried so far?
Apr 19, 2012 | Sony Televison & Video
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
Sep 16, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
MIT WD-62525 DLP TV blinking green light on front won't stop
Hi!
It means your TV needs to reset. Although you have reset it previously, now again reset the TV as per procedure given below:
Please press the SYSTEM RESET button on the front panel with a pointed item such as the point of a ball point pen or end tip of a paperclip.
The TV will turn off and the green LED will flash quickly for about one minute. After the green LED stops flashing, turn on the TV again. The changes you made while the TV was most recently on, before you used the SYSTEM RESET button, may be lost; the changes you made previously, however, are not lost. Only those changes since the last power on may be lost when the system reset button is pressed. All other settings are retained.
TV Reset Menu
Read on-screen warnings before proceeding, as some user data or settings may be erased.
1. Press TV MENU and then 1, 2, 3 to see the RESET SERVICE MENU to reset the TV.
2. Select Reset System Defaults (CAUTION: All settings, except V-Chip, will be reset to the original factory defaults.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
You can get the complete service manual for your set at the following link and they will provide free support to help you do the repair and even send you the instructions with pictures on how to do the DM repair. Your set Is the V23 chassis mitsubishi and thats how you have to select the manual. V23. Heres the link they email the manual to you instantly.
Mar 31, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
339 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
