Question about Refrigerators
What does the overload relay and capacitor does.
  • davisjay39 Sep 29, 2009
    thanks alot for info, i think iam able to fix it now.
  • 6,784 Answers
HI. This device regulates the on/off function of the actual compressor unit that is located on the bottom section of your unit. This allows the correct voltage that is need for optimal operation of the compressor motor. The relay and capacitor are one. They are connected together on most units, separate on some. the capacitor stores the voltage and, the relay regulates the on/off functions, via control board(main).
If The relay and capacitor are malfunctioning, Your unit will not cool properly, and the compressor will not run as well.
Posted on Sep 28, 2009
MCCF7W freezer stopped working
Your description of the problem seems to suggest that the compressor start relay may be bad. If there is a capacitor present it should be also tested. If start relay and/or capacitor is defective, you have the option to replace it with OEM; which may be a bit expansive, or use a Solid State Relay Overload Start Capacitor Combination. Before replacing or installing one of them, check the horsepower of your compressor. Solid state relay overload start capacitors are horsepower based.
Mar 31, 2012 | Refrigerators
Magic chef refrigerator relay/overload
You need at least two terminals on your relay to hook up a capacitor, one wire of the capacitor goes on one terminal of the relay and the other capacitor wire would get spliced in with the neutral line that plugs into the relay
Dec 05, 2007 | Refrigerators
Overload relay rattles, but the relay doesnt. could overload be weak? i do here it clicking off after a few seconds of the compressor trying to start. its an armana bx20s5w bottom freezer. both relay tests...
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 20, 2011 | Refrigerators
Every thing runs but the compressor wont fire i think its the compressor start up capacitor how do i test the capacitor
first discharge the capacitor for safetys sake,then touch the meter leads of a multi-meter set to RX100 to the caps leads if the needle stays on 0 the cap is shorted(but that would trip the wall breaker),if it doesnt move at all its open,if it goes to 0 and slowly climbs back towards infinity its good,i believe you will find the ptc overload relay on the compressor is defective,its in combination with the capacitor,the cap is only on there to take the power spikes off the relay contacts during start-up,the ptc overload relay is what aids in compressor start-up/run/and overload protection if compressor wont fire,change them both and it will run
Mar 22, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
I'm getting a wierd sound coming from my JBL2088HES refrigerator. It is a buzz like an electric shaver followed by a click. It seems to happen in 3 min intervals. Any Idea what it could be?
Kevin,
It sounds like it could be the compressor overload relay or the compressor itself. Lets hope that it is the overload relay, most compressor replacements are very expensive.
The overload/relay isn't very expensive and replacing it will be cheaper than calling a repair tech to tell you if it is the compressor or the overload/relay.
This is a relatively simple repair, if you look at your compressor you will find two wires connected to a small box ( overload/relay )
To remove the overload first you must remove the metal retainer by unhooking it with a pair of needle nose pliers.
Now remove the overload relay by pulling it away from the compressor.
The relay for your refrigerator has a capacitor connected to it, the capacitor and the relay are sold as one piece part # 67005560.
all that you have to do is remove the old relay with the capacitor from the wires by pulling the plug off and connecting the new overload/relay/capacitor to it, reinstall the relay to the compressor and you are done.
Good Luck
Check us out at www.centuryappliancerepair.com
Dec 10, 2009 | Jenn-Air Refrigerators
Compressor kicks on for about a min then shuts down overload trips out
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Jul 29, 2009 | LG LHD45EL Dehumidifier
Capacitor for a refrigerator
A capacitor gives the compressor extra starting power (or running power) to pump refrigerant thru the system .It can work without one but most overload/relays can accept the existing capacitor . Some compressors say on a sticker " Do not use without starting device".My advise would be to use the existing capacitor but wire it correctly with the overload/relay .
Jul 06, 2009 | Refrigerators
Whirlpool fridge not cooling gone warm air blowing
more than likely the compressor is not starting, it has a starting device on the left side of the compressor which has a relay/overload called a relay, remove the relay and shake it , if it rattles it has gone bad. the relay/overload combination has gone bad and can be replaced with pro41 relay. if the compressor has a run capacitor just eliminate the capacitor when replacing with new relay. connection of the two wires makes no difference.
Jan 16, 2009 | Whirlpool GS6NBEXR Side by Side...
Installing new over load relay
The line voltage goes to the overload and the neutral(and capacitor lines if it has one) goes to the relay.
Dec 05, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerator not cooling.
compressor has failed. not a diy job
Apr 25, 2007 | Amana ASD2622HR Side by Side Refrigerator
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
