Question about Rowenta Powerglide DE011 Iron with Auto Shut-off
When using the steam it spits out sediment on the clothes. I have tried cleaning by holding the steam button.
    President:
  • 1,653 Answers
This happens due to limescale and / or build ups of mineral deposits such as iron in the water. You will need to use a kettle descaling solution or an iron descaling solution available from most supermarkets or home appliiance stores and clean out the debris in the iron. It happens to most if not all irons and cleaning on a regular basis is the only answer or use very expensive 'iron water'
Posted on Sep 28, 2009
    President:
  • 1,187 Answers
First, don't use tap water for steam. Use distilled water. All major grocers have 1 gallon bottles (Kroger, WalMart, HEB, Target, etc) for les sthan $1.
yes, empty the water tank and fill with distilled water and iron cleaner (it contains vinegar). Then clean out with only distilled water.
One treatment will last for a year.
Hi my swan steam gen iron is faulty , when I press the steam button it pours with water from the metal plate part of the iron , any ideas ??? Thanks
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle .
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
Feb 27, 2013 | Irons
Leaking water around base
If the iron does not spray properly, inspect and clean the nozzle.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
God bless you
Feb 03, 2013 | Rowenta Irons
How do you test a pump on a tefal steam generater
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron does not spray properly, inspect and clean the nozzle (see below).
Jan 31, 2013 | Irons
My iron is getting hot but giving no steam can anyone advise
Jan 31, 2013 | Breville Vin227 Extreme Steam Steam...
My Laurastar Premium Steam Iron is letting out lots of water with the steam Why/
see this steps and fix it. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the . Also test and, if needed, adjust calibration of the thermostat .
Nov 14, 2012 | Irons
Tefal easycord gv 5140 no steam
do this. and use the common sense and KEEP the calm. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 24, 2012 | Rowenta Irons
Can't get my Morphy Richards steam generator off of standby
do this and use the common sense. God bless you
Sep 24, 2012 | Irons
Troubleshooting of flat iron for clothes
follow the steps and use the common sense. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
Sep 20, 2012 | Irons
How to repair aan electrical iron
If the iron doesn't heat, make sure power is on to the outlet, check the electrical chord, and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical chord . Also test and, if needed, adjust calibration of the thermostat.
If the iron sticks to fabric, clean or repair the sole plate. If the iron stains fabric, clean the sole plate, clean the tank with a commercial cleaner, and use distilled or filtered water.
The tools you will need are
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial sole plate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
Please rate my solution.
Jun 25, 2010 | Rowenta Professional Luxe DM880 Iron
Spray Mister is clogged (likely due to hard water)-can this be cleaned/fixed?
try to clean the reservoir,etc.use agent that can dissolve sediments.then after cleaning, make sure use filtered water ,ok.use a cloth with cotton cloth.
May 29, 2009 | Sunbeam Steam Master 4055 Iron
Rowenta Powerglide DE011 Iron with Auto Shut-off Logo
837 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
