Question about Dell Dimension E510 PC Desktop
All I need to know is if there is slot for a memory stick or sm card on my pc.
  • 56 Answers
I looked it up and from what I see, it looks like there are several slots for media on your computer.
Posted on Sep 28, 2009
How can i transfer video from my DCR-700x to PC
Find the memory card in the device then take it out and into a slot some where in your computer. if you don't have a memory card you need to but one then slot it in to the camera load the pictures onto it then put it in the computer. if your computer doesn't have a slot then you can buy USB sticks with a memory card slot in then simply slot the memory card in and put the USB stick into the computer and load the files.
Dec 18, 2010 | Cameras
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
What are the slots on the front panel used for?
Those are card reader slots.
Various types of memory cards can be used.
A memory card, (Or can be stated as Flash Memory Card), takes the place of the old Floppy Disks, for one.
It is digital. There is no disk inside, just hardware electronic components.
Due to the size of trying to explain every type of memory card that is available, and the memory card itself, I would like to give you this link,
http://en.wikipedia.org/wiki/Memory_card
Here it explains the basic format of a memory card.
You can click on the titles of the memory card/s, (in blue), to get a deeper explanation, of that particular memory card.
The specifications for your eMachines ET1810 Desktop PC, state that you have the following card reader slots for,
1.Compact Flash (Type I and II)
2.CF Microdrive
3.MultiMedia Card (MMC)
4.MMCmobile
5.MMCmicro
6.Reduced-Size MultiMedia Card (RS-MMC)
7.Secure Digital Card (SD)
8.miniSD Card
9.xD-Picture Card
10.Memory Stick
11.Memory Stick PRO
12.Memory Stick PRO Duo
13.Memory Stick Micro (M2)
Look above each slot for an abbreviation.
For example on my computer,
I have one card reader slot that is approximately 1 inch wide.
It looks like a T that is stretched out.
It has SD/MMC/SM/MS/MS-PRO, above it.
This means that the card reader slot will support, (Use),
[In order as printed above],
1.SD Card - Secure Digital Card
2.MultiMedia Card.
3.Smart Media card
4.Memory Stick
5.Memory Stick Pro
I have one more card reader slot. It has CF-Microdrive above it. A wider slot than the above, and looks like a upside down stretched out T.
This means of course that it uses, (Supports), a Compact Flash Microdrive card
I've tried to explain the various card reader slots, on your computer's front panel, without being too technical, or being offensive in nature.
If you want, I can explain as technical as you wish, or simplify my solution more.
This is the Specifications page for your eMachines ET1810,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810sp2.shtml
Scroll down, and look to the right of the heading - Card Reader.
These are the cards your computer supports, (Uses)
Looking at the main support page for your eMachines, it looks as though you have four card reader slots.
Three grouped together on the left side, and two in the middle.
The two slots to the far right are USB ports, with probably a headphone jack port, and a microphone port to the right of them.
This page gives a little more detail, as to what your card reader slots support,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810fv.shtml
Dec 24, 2009 | eMachines ET1810-01 PC Desktop
Where to insert a camera memory stick in acer travelmate 4502lci laptop
according to the acer site..
these are usually on one side or the other. the issue here is whether your camera memory stick is same size as their slots. you may need to get an adapter. careful about forcing that mem stick into a slot that's not good to go.
Expandability 1 x Type I/II PC Card Slot, 1 x SD Card Slot, 1 x Memory Stick Card Slot, Docking Station/Port Replicator, 1 x MMC Card Slot
Nov 28, 2009 | Acer TravelMate 4150LCi Notebook
Memory card ?
Hi there.
At the front of the computer you should see 1-4 different sized small slots, the card should slide into one of these slots.
Good luck
Jun 02, 2009 | Dell Dimension 3100 PC Desktop
I dont know were to insert memoey stick from psp into my pc
The memory card can go with many devices like Digital cameras, computer card slots, memory card readers etc .. What device are you trying to use the card with?
Please let me know the details so that I can assist you better.
Thanks and Regards,
Srinivas
Apr 16, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
I do not know where to put the memory card into epson rx 425
There is a little panel on the front left, you can download the user guide fro Epson here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=nKGrQtfEm6mIr17BBoUTdZr5V9BVmX64&tc=5#10
Loadable memory card
This product features three memory card slots.
The types of memory cards loadable for each slot are shown below.
Slot
Card
a
Memory Stick/MagicGate Memory Stick/Memory Stick Duo*/
Memory Stick PRO/Memory Stick PRO Duo*/SD Card/miniSD Card*/MultiMediaCard
b
SmartMedia/xD-Picture Card
c
CompactFlash/Microdrive
r_space.gif * An adapter is required.
Mar 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Memory stick reader
It sounds like to me that either the slot is damaged, dirty or you may have the wrong kind of media for that slot. If you have a can of dust off (compressed air) you may want to blow out the dust in the slot. After doing this, try your memory stick again. If it still doesn't work but it has in the past for that slot you may want to consider replacing the card reader. Sometimes the pins get dislodged or bent inside. Good luck, let me know how it turns out. Thanks...
Dec 19, 2008 | E-Machines eMachines Desktop PC
Have a dell Inspiron 1525 notebook with memory card reader, compatible with Memory Stick Pro - but i cannot figure out how to insert the memory stick into the memory card reader - an SD card slots in...
the MS pro may need an adapter if it's the mini kind. then that will plug into that slot. it still won't fit the same way as the SD card, so insert it carefully. there should be an indented area for the MSP card to insert.
Aug 18, 2008 | Computers & Internet
Memory stick / card slot not reading
hi your card reader conect to laptop & reset ..........then laptop start your card ok.
Jan 21, 2008 | HP Compaq Presario V2000 Notebook
Dell Dimension E510 PC Desktop Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
