Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
I can not get water to come out of the floor cleaning part of the machine.
    President:
  • 1,653 Answers
This is most likely to be dirty pipes or filters or the water pump is faulty or the drive belt for the motor has broken.
Posted on Sep 28, 2009
Hoover floor mate h3000 will not suction water from floor when cleaning
Your collection canister may not be positioned tight enough in its place ment site. Tip machine back using foot pedal (as if you were going tio start using machine to clean) Insert collection canister (bottom container, then insert top canister with solution. The two canisters must be flush with machine side seams and must sit in position tightly. This is sometimes very tricky and may take a little elbow grease to make it click into place. Hope this helps
Jul 08, 2015 | Hoover Floormate H3000 Upright Wet/Dry...
Machine will not vacuum up the water
Most likely suction side is clogged with debris flip it over remove cover and brushes and clean the tube out.
Apr 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
E2 series not cleaning
Are the brushes spinning on the power head? If you disconnect the power head and just leave the hose only with the water canister filled .. does it "**** up" dirt?
Apr 16, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Dirty water comes out when I stop scrubbing. Floors remain wet.
Try one thing... the filter cover must be clicked into place. I thought it just sat on top, but it has to be pushed into place.
FWIW
Mar 22, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Can you use irobot Scooba on laminate floors?
they are suppose to be hardwood floor safe but maybe you should call the manurfacturer and make sure
Mar 21, 2009 | iRobot 5800 Scooba Vacuum
Changing from carpet cleaning to hard floor cleaniang
If you are looking to floor cleaner then don't go anywhere, Our experts helps you to clean your floor and the best thing is that you are never feeling regret after taking our services.
Taking fast services call us anytime 3105441028.
Commercial Floor Cleaning Services Waxing Los Angeles CleanerImage
Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to clean
I have found this so i think this answers my question.
Question         How do I remove the clear floor nozzle window on my machine?     shim.gif     Answer         Before starting, please be sure the machine is not plugged in and the machine handle is reclined.
To remove the clear floor nozzle, first detach the phillips head screws located at the base of the clear floor nozzle. Then, remove the tank in tank assembly. Next, remove the rectangular gasket at the top of the nozzle, and pull the clear floor nozzle forward to remove the tabs from the notches. This clear floor nozzle is removable so you may be able to access this area and clean.
When putting the clear floor nozzle back in place, please be sure the tabs at the TOP of the nozzle are properly inserted into the notches provided. If you do not have the tabs in place properly, you may have a problem with the machine's suction.
Rotate the window down into place, replace the screws, and replace the rectangular gasket.
If you would like additional assistance, please contact BISSELL Consumer Services at 1-800-237-7691, Monday - Friday 8 a.m. to 10 p.m., or Saturday 9 a.m. to 8 p.m., ET or email us by clicking on the Email BISSELL tab at the top of this page.
Reminder: When you have completed the deep cleaning process, it is recommended to return the SmartMix dial to "Water Only" prior to storing the machine.     shim.gif     How well did this
Oct 10, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
174 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
