Question about Lexmark T630 Laser Printer
I have an lexmark 630 and keep getting the error "load MP feeder plain paper" thanks for the help chip loye chapelthrill@gmail.com charlesloye@gmail.com
    President:
  • Lexmark Master
  • 1,447 Answers
Please follow my tips ,When you print your computer before you go to print properties.Setting paper layout choice paper source and enable MP tray then print ok.
keep your mind before print you must be insert paper in MP tray.
Posted on Nov 25, 2009
  • Sazeed Computer
    Sazeed Computer Nov 26, 2009
    MP mean multi pass Tray i mean front tray load paper
  • Sazeed Computer
    Sazeed Computer Dec 01, 2009
    How can use your printer? Please read user manual from your printer driver CD It is format PDF file, so before you install Acrobat reader.
  • 320 Answers
Use the right arrow go to paper menu select this right to paper source select tray 1. on the mp tray on the left side there is a flag that goes into a slot on the metal tray make sure this flag is in place
Posted on Dec 07, 2009
Told that this is a PCL5 type printer and can be used as a plug n'play, and no need to install a driver. It does work, but will not hold the programming. I only want to use Tray1.
the thing is that with plug and play equipment, when you plug it into the pc and turn it on Usb connections) , there is a small message just above the task bar which says installing driver for printer
it is the way that the pc recognizes the printer in a port
it may be best it you go to the control panel ,printers and devices , add a printer and install it properly
Oct 13, 2016 | Lexmark Office Equipment & Supplies
What does load mp feeder letter mean? There is paper in the printer why is the printer not prinint
load mp feeder means To load the Manual Paper Feeder
You might have selected the printer settings for manual feeding. Hence you need to feed that papers in manual feeding tray.
You can change the settings to automatic paper feeding to get rid of this error.
Aug 27, 2010 | Lexmark Optra T610 Laser Printer
Load mp feeder with a4
find the switch and turn it to auto paper in the printer settings, mp is for manual paper feed ap is probally for auto paper feed, its a guess . hope it helps
Dec 01, 2009 | Lexmark Office Equipment & Supplies
I keep getting a Load MP Feeder Letter message. I can't clear what to do?
MP Feeder refers to Multi Purpose Feeder or Manual Paper Feeder or just plain bypass feeder. There should be a door that folds down to gain access to your MP Feeder tray. Try loading letter size paper on this tray.
Nov 24, 2009 | IBM Infoprint 1332 Laser Printer
Lexmark T630 error message: Change MP Feeder
use the right arrow go to paper menu scroll to the right to paper source select if it is set to mp tray reset it to tray one. if its set to tray 1. check the side of the paper drawer to make sure the paper size snap in plate is in place. if these things are good replace the paper size selection pcb located in behind the logic pack
Sep 15, 2009 | Lexmark T630 Laser Printer
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Lexmark T642 - I have plain white paper in tray 1 and yellow plain paper in the mp feeder tray. When I choose to print to the mp feeder tray the printer beeps to be loaded with paper but the paper is...
Make sure you have selected the multi purpose feeder (front of the printer) in the driver, not the Manual Feeder.
The manual feeder will prompt for paper on each page. All you have to do is to press the "Go" button.
Jun 03, 2009 | Lexmark T642 Laser Printer
Our printer says load MP feeder. We can't get it to print. Please
The front of the printer is a door that opens this is the MP feeder. Load paper in it and the unit should print. Someone likely sent a job requesting that tray.
for more help see.
http://www.lexmark.com/publications/pdfs/t640/eng/ug.pdf
Hope this helps
Mar 23, 2009 | Lexmark T642 Laser Printer
Load MP Feeder
That is not an error message. it is telling you to load the Manual Paper feeder. Put some papaer in it and it will print. check youyr set up to make sure that you are printing to the trays not the manual feeder
Nov 20, 2008 | Lexmark Optra M412 Laser Printer
Lexmark T644 MP Feeder STOP ASKING FOR MP FEEDER???!!!
Thanks mate, it worked for me too and my works printers (work in IT and this 'error' was driving us crazy)
Jul 29, 2008 | Lexmark T644 Laser Printer
Lexmark T630 Laser Printer Logo
683 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
