Question about Haier HPRD12XC7 Portable Air Conditioner
The red light (power button) is flashing when the unit is turned on. I reset the breaker and tried a different plug, and it did not solve the problem
5 Suggested Answers
SOURCE: Haier Air conditioner does not turn on
encountered the same problem today. It would seem one of the buttons on the front panel membrane is stuck......play with the buttons till it loosens itself or use the remote if u have one....that worked for me
Posted on Jul 09, 2008
I was having problems with my Haier A/C staying on, also. My timer was even changing on me. I just purchased it a few days ago, and the instructions were no help. My son decided to play video games on my Toshiba TV and change the brightness, (low and behold), this turned my A/C on and off. Then we found out the volume on the remote to the TV changed the timer on the A/C. We now have a peace of tape over the sensor on the A/C and it works fine now.
Posted on Aug 03, 2008
heinzhvac
  • 229 Answers
SOURCE: the unit worked fine when
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
Posted on May 10, 2011
  • 4736 Answers
SOURCE: I have a standalone portable
After pressing the reset switch on the plug. Wait 3 minutes before attempting to start the unit.The reset has a time delay.
Posted on Aug 02, 2011
Blue light flashing
Do a hard reset,usually there is a button on the back of the router.With power plugged in,press and hold reset button 15 sec. then without releasing button remove power plug and hold an additional 15 sec.,then plug power cord back in and hold an additional 15 sec. After that release the reset button and it should reset to default.You may need to do this a few times but it should solve your issue.
Apr 16, 2014 | Belkin Computers & Internet
Have a carrier 92 furnace. electric motor will not kick on...just hums. red light on circuit board flashes...help?
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
However you can have a missing 1 phase , test with the VOM, for to measure voltage. Or motor need repair for winding trouble,bearing.If you do not have enough experience call some electrician.
God bless you
Oct 08, 2012 | Heating & Cooling
Everstar mpm2-10cr-bb6 will not reset on power cord. light on reset doesn't light. seems like no power is getting to the unit.
Check the outlet that the unit is plugged into, to be sure that it is in fact, working. The circuit breaker in your home's circuit breaker panel for that outlet, may have tripped. Also, the outlet may have interior damage or a loose wire connection. If the unit seems not to be getting power, one of the above is the problem. Try plugging the unit into another outlet in a different room.
Hope this helps you troubleshoot and solve the problem.
Jun 02, 2011 | Danby DPAC8020 Air Conditioner
Unresponsive Logitech cordless mouse LX8
need drivers for my new v220 cordless mouse
Jan 12, 2010 | Logitech Cordless Mouse
When i plug in my samsung 32 lcd the power button just flashes red. sounds like it trying to turn on but just flashes red light.
Check your manual that came with the tv. You can try resetting by usually unplugging a few minutes, then plug in and hold the power button on for a few seconds when you turn it back on. Check manual, though; they're all very different/
Nov 17, 2009 | Samsung LN32A330 32 in. LCD TV
How to repair Samsung AQV 12 FAN Air Conditioner
You can turn off the Thermostat, and the powers switch on the furnance and turn the breaker off in the breaker box wait about 20 - 30 minutes and turn the breaker back on, and the power to the furance back on and the thermostat, this should reset the system.
Melvin
St Louis
Oct 03, 2009 | Samsung Heating & Cooling
Lock light stuck on, dishwasher will not work
We had turned the power off at the breaker but only flicked it on and off, a friend recommended we turn off the power and leave it off for 5 minutes then turn it back on. This solved the entire problem!
Jul 10, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Lights on Washer Machine flash but Washer doesn't work
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 31, 2009 | Kenmore Washing Machines
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
Haier HPRD12XC7 Portable Air Conditioner Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
