Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Husqvarna yth2348 keeps blowing fuses as soon as one is changed and you attempt to turn it over the fuse blows
  • 855 Answers
You have a dead short in the circuit for that fuse. Check for a pinched wire, or a wire rubbed thru a touching metal.
Posted on Sep 28, 2009
Testimonial: "very helpful with the problem"
I have a 2009 Toyota Corolla. Recently the wiper fuse started blowing. The Fuse keeps blowing as soon as the ignition is turned on.
could be anything and without a look myself i couldnt tell you try disconnecting the wiper switch and see what happens is about the best i can come up with was thinking of the self park but with motor disconnected and it still blows ?? thats that out the equation .
Jan 08, 2017 | Toyota Corolla Cars & Trucks
What could be causing the front axillary fuse to keep blowing? Even bigger fuses blow.
fuses blow from over current( dead short) they are rated at lower than what is required so that the wire doesn't burn
If you keep putting in bigger fuses without fixing the dead short, eventually the wire will melt the plastic insulation off and the vehicle will burn
Apr 29, 2016 | 2005 Buick Rendezvous
Why did a new fuse blow?
check wiring for a bad ground or a short to ground
May 19, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mazda 626 ac fuse keeps blowing
Try unplugging the compressor then put in a new fuse. If the fuse does not blow, the problem may be the clutch on the compressor.
Jul 29, 2012 | 1997 Mazda 626
Why does my mower keep blowing the 20 amp fuse
could be the safety switch for the pedal
Apr 23, 2012 | Husqvarna Garden
Blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Jul 13, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Fuse keeps blowing
In my experience...if it blows the fuse as soon as you turn the key, under the flywheel, there is a stator that recharges the battery when the engine is running, remove the flywheel, in most cases the magnets under it are broken and are in direct contact with the stator. If that is the case, both must be replaced
Jun 17, 2009 | Garden
Fuse blows for wiper as soon as i turn on the wiper switch
If you can remove connector to wipers, do it, then turn them on and see what happens. If fuse blows, it's most likely a short in wiring harness, if it doesn't, then most likely the motor. Does it attempt to move at all, before it blows? Look for bad or bare wire in harness as well.
May 31, 2009 | 1999 Dodge Ram
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
1,277 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
