Innovair E2 error
Hello I have an Innovair 3ton (36000btu) split unit for one year . a few weeks ago it displayed error E4 for a day, and it would not cool. Then it started showing error E2, but it seems to cool, can't any other read outs the display though only E2
InMrFixIt
  • 121 Answers
SOURCE: e4 in an innovair a/c
Hi! jorget67
Sound like the compressor overload is tripped. Make sure the condenser is clean then reset the breaker on this circuit.
Sincerely, InMrFixIt
Posted on Jan 12, 2009
  • 659 Answers
It sounds like you have a freon leak and may need a charge. When there is a leak, the compressor will run for awhile but without the proper charge, it will heat up and kick on on thermal overload. After the compressor cools, the unit will come back on. Have the unit serviced by a professional.
Posted on Mar 20, 2009
shastalaker7
  • 1515 Answers
SOURCE: we were getting an E4 but now we get an E2 but
I do know that the owners manual should show you what each and every code means? Some times the manufacture will paste a strip located on the panel of the indoor unit showing what each code means. If not, I would contact the factory on this. I know on Bryant, Mitsubishi splits, Day and night, (Bryants), Tranes, Lennox and most all others, do show in the manual and on the unit behind the panel. Try looking for them there.
Sincerely, shastalaker7
Posted on Oct 28, 2009
shastalaker7
  • 1515 Answers
SOURCE: Can you tell me how
It would be hard to say by just giving you a number in pounds and oz. The condenser is charged with enough freon for up to 25' of line set. Even though it is a 3 ton unit, they all hold different amounts, yours may have a accumalator, a liquid and suction line drier ect. If you are doing the charging your self, when there is no data plate telling the amount the unit holds, we use a pocket pressure/temperature chart. We charge the unit according to the outdoor air temperature, wet bulb, sub-cooling or in your case superheat using your manifold gauges. With the system pulled into a vac, you charge through the low side port if using R-22 watch both your head pressure and low side using the increments and pressure/temp chart that you can pick up for free at any wholesale a/c refrigeration parts house. If I new what the ambient temperature was where you were doing this, I could help you or tell you where your gauges should be, but you really need to check the superheat to make sure you are not over charged which will kill the compressor due to liquid in the compressor. I would have to charge it my self if I did not know the charge which most units will not even show on the data plate.I hope I have been of some help to you.
Sincerely,
Shastalaker7
A/C, & Refrigeration Contractor.
Posted on Jun 03, 2011
Check the Capacitor.
Posted on Oct 06, 2011
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
Where can i download a manual for an image 10.4 treadmill? it displays an E2 or E4 error message. thanks.
Try Retrevo Manuals.com lots of manuals but you really have to search for them. Make sure you gave make, model number etc.
Dec 15, 2013 | Treadmill Doctor Image 10.4 Q Console...
Error code A 00 e2 03 for Samsung 3ton mini split
Google model and serial to get manual for flash code
Dec 05, 2012 | Heating & Cooling
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
We were getting an E4 but now we get an E2 but
Oct 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
E4 in an innovair a/c
Jan 12, 2009 | Heating & Cooling
Jan 09, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
285 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
