Leaking water, only a trickle of water enters machine
  • Gerry Harvey
    Gerry Harvey May 11, 2010
    Is the fill hose leaking
  • 82 Answers
Sounds like the water solenoid has failed. It does happen.
Hope this helps
Posted on Sep 29, 2009
Cold water trickling into washer - what would cause this?
CHECK AND SEE IF THERE ARE SCREENS AT THE WATER VALVE IT MAY BE CLOGGED THERE
Jun 18, 2014 | Frigidaire CWS3600AS Top Load Washer
Water leaking under the machine
Take a look at the little spout area that pours into the water tray. It can get clogged with coffee grounds. This was our solution with one machine. But with another, the water was actually leaking out the back and was the result of a dying boiler assembly.
Dec 12, 2012 | Saeco Vienna Plus Espresso Machine
Water continues to trickle into machine when not in use
you have sediment in the water valve on the back of the machine,the valve isn't closing all the way and water is leaking into the washer
Nov 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a two month old Samsung WF350 front load washer. I have a trickle of water leaking from the bottom of the door during wash cycles.
I just received my Samsung WD 8804 front loader washing machine, and during the 3rd wash trial, I noticed the same problem of water trickling down from the base of the front door. I took a closer look and the problem is actually due to a cracked rubber seal, which can be seen through the glass door. I have informed the technician.
Jun 26, 2010 | Samsung Washing Machines
Hot water entering machine is only a trickle. It
Check the filter trap on the back of the washer where the hot water fill hose connects to the inlet valve, you wil have to shut the hot water valve off first, then remove the hose at the washer and inspect the little filter screen thats in the valve where the hose screws onto the washer, it probably has trapped enough sediment to restrict the flow of hot water into the washer.
Good Luck !
Mar 14, 2010 | Washing Machines
Kitchenaid dishwasher will not fill. Water does
First make sure your water inlet isn't plugged, then check that your solenoid is opening fully, unless this is an old model and you have calcium buildup throughout the machines plumbing I'd bet a new solenoid will fix you right up.
Feb 22, 2010 | Dishwashers
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
LG WM-1285FHD Leaking from Dispenser Drawer area
There is a problem with the dispenser assembly where the drawer enters.  You will have to have it checked by a qualified LG technician to see what the problem is.
Apr 27, 2008 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
