Question about Intel Motherboard
Can the power switch cause the motherboard to malfunction improperly/
  • 51 Answers
The switch should be a moment switch i.e on when you press and then off again, if its stuck in the on position it could make the power cycle on off on off or just not work atall. if your getting a good sounding click when you press it chances are its not the problem
Posted on Sep 28, 2009
Trouble code in a 2003 kia Sedona PO106
These are the only ones I have listed
P0100 Mass Air Flow or Volume Air Flow Circuit Malfunction.
P0101 Mass Air Flow or Volume Air Flow Circuit Range/Performance problem.
P0102 Mass Air Flow or Volume Air Flow Circuit Low Input.
P0103 Mass Air Flow or Volume Air Flow Circuit High Input.
P0107 MAP/BARO Circuit Low Input.
P0108 MAP/BARO Circuit High Input.
P0110 A/T Circuit Malfunction.
P0115 Engine Coolant Temperature Circuit Malfunction.
P0116 Engine Coolant Temperature Circuit Range/Performance Condition.
P0117 Engine Coolant Temperature Circuit Low Input.
P0118 Engine Coolant Temperature Circuit High Input.
P0120 Throttle Position Malfunction - Circuit A.
P0122 APP/TPP Sensor Switch Low Input - Circuit A.
P0123 APP/TPP Sensor Switch High Input - Circuit A.
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control.
P0130 Oxygen Sensor Circuit Malfunction - Bankicon1.png 1 Sensor 1.
P0131 Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 1.
P0132 Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 1.
P0133 Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 1.
P0134 Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 1.
P0135 Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 1.
P0136 Oxygen Sensor Circuit Malfunction - Bank 1 Sensor 2.
P0137 Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 2.
P0138 Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 2.
P0139 Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 2.
P0140 Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 2.
P0141 Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 2.
P0170 Fuel Trim Malfunction - Bank 1.
P0171 System too Lean - Bank 1.
P0172 System too Rich - Bank 1.
P0261 Injector Circuit Low - Cyl. 1.
P0262 Injector Circuit High - Cyl. 1.
P0264 Injector Circuit Low - Cyl. 2.
P0265 Injector Circuit High - Cyl. 2.
P0267 Injector Circuit Low - Cyl. 3.
P0268 Injector Circuit High - Cyl. 3.
P0270 Injector Circuit Low - Cyl. 4.
P0271 Injector Circuit High - Cyl. 4.
P0300 Multiple/Random Misfire detected.
P0301 Misfire detected - Cyls. 1-4.
P0302 Misfire detected - Cyls. 1-4.
P0303 Misfire detected - Cyls. 1-4.
P0304 Misfire detected - Cyls. 1-4.
P0325 Knock Sensor Circuit Malfunction
P0326 Knock Sensor 1 Circuit Range/Performance - Bank 1 or Single Sensor.
P0335 Crankshaft Position Sensor Malfunction - Circuit A.
P0336 Crankshaft Position Sensor Range/Performance - Circuit A.
P0340 Crankshaft Position Sensor Circuit Malfunction.
P0342 Crankshaft Position Sensor Circuit Low Input.
P0343 Crankshaft Position Sensor Circuit High Input.
P0400 EGR Flow Malfunction.
P0403 EGR Circuit Malfunction.
P0404 EGR Circuit Range/Performance Malfunction.
P0420 Catalyst System Efficiencyicon1.png below Threshold - Bank 1.
P0422 Main Catalyst Efficiency below Threshold - Bank 1.
P0440 Evaporative Control Malfunction.
P0441 Evaporative Control System - Improper Purge.
P0442 Evaporative Control System - Small Leak detected.
P0443 Evaporative Control System Purge Control Valve Circuit Malfunction.
P0446 Evaporative Vent Control Circuit Malfunction.
P0447 Evaporative Vent Control Circuit Open.
P0448 Evaporative Vent Control Circuit Short.
P0450 Evaporative System Pressure Sensor Circuit Malfunction.
P0452 Evaporative Control System Pressure Sensor Low Input.
P0453 Evaporative Control System Pressure Sensor High Input.
P0455 Evaporative Control System - Large Leak detected.
P0470 Exhaust Pressure Sensor Malfunction.
P0500 Vehicle Speed Sensor Malfunction.
P0501 Vehicle Speed Sensor Range/Performance.
P0505 Idle Air Control System Malfunction.
P0506 Idle Air Control System Malfunction - RPM Lower than expected.
P0507 Idle Air Control System Malfunction - RPM Higher than expected.
P0510 CTP Switch Malfunction.
P0561 System Voltage Unstable.
P0562 System Voltage Low.
P0563 System Voltage High.
P0601 Internal Control Module Memory Checksum Error.
P0604 Internal Control Module RAM Error.
P0703 Torque Converter/Brake Pedal Switch Malfunction - Circuit B.
P0705 Transaxle Range Sensor Circuit Malfunction (PRNDL Input).
P0706 A/T Range Sensor Circuit Range/ Performanceicon1.png.
P0710 Transaxle Fluid Temperature Sensor Circuit Malfunction.
P0711 A/T Fluid Temperature Sensor Circuit Range/Performance.
P0715 Input/Turbine Speed Sensor Circuit Malfunction.
P0722 Output Speed Sensor Circuit No Signal.
P0726 Engine Speed Input Circuit Range/ Performance.
P0727 Engine Speed Input Circuit - No Signal.
P0731 A/T Gear 1 Improper Ratio.
P0732 A/T Gear 2 Improper Ratio.
P0733 A/T Gear 3 Improper Ratio.
P0734 A/T Gear 4 Improper Ratio.
P0740 Torque Converter Clutch System Malfunction.
P0743 Torque Converter Clutch Circuit Electrical.
P0750 Shift Solenoid "A" Malfunction.
P0753 Shift Solenoid "A" Electrical.
P0755 Shift Solenoid "B" Malfunction.
P0758 Shift Solenoid "B" Electrical.
P0760 Shift Solenoid "C" Malfunction.
P1000 Readiness Function Code.
P1115 Engine Coolant Temperature Signal from ECM to TCM.
P1121 Throttle Position Sensor Signal Malfunction from ECM to TCM.
P1170 Front Heated Oxygen Sensor Stuck.
P1195 EGR Pressure Sensor (1.6L) or Boost Sensor (1.8L) Open or Short.
P1196 Ignition Switch "Start" Open or Short (1.6L).
P1250 Pressure Regulator Control Solenoid Valve Open or Short.
P1252 Pressure Regulator Control Solenoid Valve No. 2 Circuit Malfunction.
P1307 Chassisicon1.png Acceleration Sensor Signal Malfunction.
P1308 Chassis Acceleration Sensor Signal Low.
P1309 Chassis Acceleration Sensor Signal High.
P1345 No SGC Signal (1.6L).
P1386 Knock Sensor Control Zero Test.
P1402 EGR Valve Position Sensor Open or Short.
P1449 Canister Drain Cut Valve Open or Short (1.8L).
P1450 Excessive Vacuum Leak.
P1455 Fuel Tank Sending Unit Open or Short (1.8L).
P1457 Purge Solenoid Valve Low System Malfunction.
P1458 A/C Compressor Control Signal Malfunction.
P1485 EGR Solenoid Valve Vacuum Open or Short.
P1486 EGR Solenoid Valve Vent Open or Short.
P1487 EGR Boost Sensor Solenoid Valve Open or Short.
P1496 EGR Stepper Motoricon1.png Malfunction - Circuit 1 (1.8L).
P1497 EGR Stepper Motor Malfunction - Circuit 2 (1.8L).
P1498 EGR Stepper Motor Malfunction - Circuit 3 (1.8L).
P1499 EGR Stepper Motor Malfunction - Circuit 4 (1.8L).
P1500 No Vehicle Speed Signal to TCM.
P1505 Idle Air Control Valve Opening Coil Voltage Low.
P1506 Idle Air Control Valve Opening Coil Voltage High.
P1507 Idle Air Control Valve Closing Coil Voltage Low.
P1508 Idle Air Control Valve Closing Coil Voltage High.
P1523 VICS Solenoid Valve.
P1586 A/T-M/T Codification.
P1608 PCM Malfunction.
P1611 MIL Request Circuit Voltage Low.
P1614 MIL Request Circuit Voltage High.
P1624 MIL Request Signal from TCM to ECM.
P1631 Alternator "T" Open or No Power Output (1.8L).
P1632 Battery Voltage Detection Circuit for Alternator Regulator (1.8L).
P1633 Battery Overcharge.
P1634 Alternator "B" Open (1.8L).
P1693 MIL Circuit Malfunction.
P1743 Torque Converter Clutch Solenoid Valve Open or Short.
P1794 Battery or Circuit Failure.
P1795 4WD Switch Signal Malfunction.
P1797 P or N Range Signal or Clutch Pedal Position Switch Open or Short
Oct 01, 2014 | Vehicle Parts & Accessories
System shuts off within seconds of turning on and fan starts
Motherboards are designed so that holding in the power button for 4-5 seconds shuts the system off. The On/Off key getting stuck or something shorting the pins on the motherboard that the On/Off switch is connected to can cause this behavior.
Open the case and remove the little two wire connector (usually one red and one black wire) that runs from the motherboard to the front panel switch. Then carefully touch both the pins on the motherboard at the same time with something made of metal such as a paperclip or small screwdriver, remove it as soon as the computer starts to power up. If it still shuts off, you probably have a motherboard malfunction. If it starts normally, the switch needs to be replaced/repaired.
Aug 21, 2011 | Audio Players & Recorders
I have an 04 Kia spectra with a PO121 code. What domestic this mean
Well.... Here is a full list of the codes I can find that Kia list. Oddly it jumps from P0120 to P0122
I hope the attached will help, but you may need to talk to your dealer.
Diagnostic Codes
Kia
Without Onboard Diagnostics (OBD-II)
2 Distributor no Signal.
3 Distributor G Signal.
7 Fault on SGT Signal.
8 Mass Air Flow Sensor.
9 Engine Coolant Temperature Sensor.
10 Intake Air Temperature Sensor.
12 Throttle Position Sensor.
14 Atmospheric Pressure Sensor.
15 Oxygen Sensor.
16 EGR Valve Position Sensor.
17 Feedback System.
18 Injector No. 1 open or short.
19 Injector No. 2 open or short.
20 Injector No. 3 open or short.
21 Injector No. 4 open or short.
24 Fuel Pump Relay open or short.
25 Pressure Regulator Control Solenoid Valve.
26 Purge Control Solenoid Valve.
28 Solenoid Valve (EGR) open or short.
34 Idle Speed Control Solenoid Valve.
35 Deteriorated Injector.
36 Deteriorated Air Flow Sensor.
37 Intake System Air Leakage.
41 Variable Inertia Charging System Solenoid Valve.
46 A/C Cut Relay open or short.
48 Power Stage Group 1 Malfunction (inside ECM). Injector 1-4 Purge Solenoid Valve, EGR Solenoid Valve or Damaged Power Stage.
49 Power Stage Group 2 Malfunction (inside ECM). Idle Speed Control Valve Failure or Damaged Power Stage.
56 Idle Speed Control Valve Closing Coil open or short.
57 A/C Compressor Input Signal short.
73 Vehicle Speed Sensor open or short.
87 Malfunction Indicator Lamp short Circuit.
88 ECM Data.
99 Battery.
OBD-II
P0130 Oxygen Sensor Circuit Malfunction - Bank 1 Sensor 1.
P0420 Catalyst System Efficiency below Threshold - Bank 1.
P0706 A/T Range Sensor Circuit Range/ Performance.
P1307 Chassis Acceleration Sensor Signal Malfunction.
P1496 EGR Stepper Motor Malfunction - Circuit 1 (1.8L).
P1797 P or N Range Signal or Clutch Pedal Position Switch Open or Short.
Jun 21, 2011 | 2004 Kia Spectra
Will not power on.
check the power supply
and the power button
May 12, 2011 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
High Nox levels on emmission test
here are the possible causes of high nox levels, Misfire condition
Malfunctioning or improperly adjusted EGR valve
Failed oxygen sensor
Leak in exhaust tubing upstream of converter
Excessive carbon deposits in combustion chamber
Improper spark advance
Blocked coolant passage
Overly lean air-fuel mixture
Damaged cold air duct
Failed or malfunctioning catalytic converter
Corroded or damaged engine sensor electrical connections.the best advice is to take it to a emission specialist to check it out! good-luck!
Apr 29, 2011 | 1995 Mercury Tracer
I have a F250 lariat with a 460 - truck stalls when I put it in gear - even after it runs for 20 min. Sometimes it will stall while I'm driving. I had carborator replaced last year. Hope you can help.
Some possible causes could be:
Vacuum leaks cause an engine to run lean witch can cause the vehicle to stall when put into gear.
Improper base idle adjustment can cause the vehicle to stall when shifted into drive or reverse
A malfunctioning or damaged carburetor can cause the vehicle to stall when shifted into drive or reverse
Improper ignition timing can cause the vehicle to stall when shifted into drive or reverse.
A malfunctioning or damaged transmission or torque converter can cause the vehicle to stall when shifted into drive or reverse
Oct 31, 2010 | 1987 Ford F 250
What causes a circuit malfunction in the knock sensor?
Improper spark advance,
I have had bad motor mounts cause the knock sensor to malfunction.
Oct 13, 2010 | Chrysler PT Cruiser Cars & Trucks
I recently had my motherboard replaced by a Dell technician due to video problems. Ever since it was replaced I've been getting blue screen errors saying Hardware malfunction, random sudden restarts, and...
If this happened after the dell technician called, ring back and complain, if your not happy with the result, i would talk to an advice orginisation. In the UK we have places like the C.A.B. ( Citizens Advice Bureau )
Aug 03, 2010 | Dell Inspiron 1520 Motherboard
The gauge in my yamaha fz6 2006 is blinking, the manual says there is a electrical circuit problem. I check all the ligths nad fuses and they seem in order, what else could it be?
I believe you count the amount of blinks to read the codes. First blinks are first number, and second set of blinks are second number. Chaz Moto DC
Fault Code: 12
Symptom: No normal signals are received from the crankshaft position sensor.
Fault Code: 13
Symptom: Intake air pressure sensor-open or short circuit detected.
Fault Code: 14
Diagnostic Code: 03
Symptom: Faulty intake air pressure sensor pipe system
Fault Code: 15
Diagnostic Code: 01
Symptom: Throttle position sensor-open or short circuit detected.
Fault Code: 16
Diagnostic Code: 01
Symptom: A stuck throttle position sensor is detected.
Fault Code: 19
Diagnostic Code: 20
Symptom: Open circuit in the input line of ECU No4 terminal is detected when the start switch is pressed.
Fault Code: 21
Diagnostic Code: 06
Symptom: Coolant temperature sensor-open or short circuit detected.
Probable cause of malfunction: Open or short circuit in wiring harness.
Defective coolant temperature sensor.
Malfunction in ECU.
Improperly installed sensor.
Fault Code: 22
Diagnostic Code: 05
Symptom: Intake air temperature sensor-open or short circuit detected.
Defective intake temperature sensor.
Malfunction in ECU.
Fault Code: 30
Diagnostic Code: 08
Symptom: The motorcycle has overturned. Probable cause of malfunction:
Overturned.
Malfunction in ECU.
Fault Code: 33
Diagnostic Code: 30
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 1, #4).
Probable cause of malfunction: Open circuit in wiring harness.
Malfunction in ignition coil.
Malfunction in ECU.
Malfunction in a component of ignition cut-off circuit system.
Fault Code: 34
Diagnostic Code: 31
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 2, #3).
Malfunction in ECU.
Fault Code: 41
Diagnostic Code: 08
Symptom: Lean angle cut-off switch-open or short circuit detected.
Defective lean angle cut-off switch.
Malfunction in ECU.
Fault Code: 42
Diagnostic Code: 07, 21
Symptom: No normal signals are received from the speed sensor; or, an open or
short circuit is detected in the neutral switch.
Defective speed sensor.
Malfunction in vehicle speed sensor detected unit.
Defective neutral switch.
Malfunction in the engine side of the neutral switch.
Malfunction in ECU.
Fault Code: 43
Diagnostic Code: 09
Symptom: Supply power to the injector and fuel pump is not normal
Probable cause of malfunction: Open circuit in wiring harness. (red/blue line or blue/yellow line)
Malfunction in ECU.
Fault Code: 44
Diagnostic Code: 60
Symptom: An error is detected while reading or writing on EEPROM.
Probable cause of malfunction: Malfunction in ECU. (The CO adjustment value is not properly written on or read from the internal memory).
Fault Code: 46
Diagnostic Code: --
Symptom: Power supply to the FI system is not normal. Probable cause of malfunction:
Malfunction in "CHARGING SYSTEM".
Fault code: 50
Diagnostic Code: --
Symptom: Faulty ECU memory. When this malfunction is detected, the code
number might not appear on the meter.
Probable cause of malfunction: Malfunction in ECU. (The program and data are not
properly written on or read from the internal memory.)
Fault code: Er-1
Diagnostic Code: --
Symptom: No signals are received from the ECU.
Probable cause of malfunction: Open or short circuit in wiring sub lead.
Malfunction in meter.
Malfunction in ECU.
Fault code: Er-2
Diagnostic Code: --
Symptom: No signals are received from the ECU within the specified duration.
Probable cause of malfunction: Improper connection in wiring sub lead.
Malfunction in ECU.
Fault code: Er-3
Diagnostic Code: --
Symptom: Data from the ECU cannot be received correctly.
Malfunction in ECU.
Fault code: Er-4
Diagnostic Code: --
Symptom: Non-registered data has been received from the meter.
Malfunction in ECU.
Feb 23, 2010 | 2005 Yamaha FZ6
How can fix code P0703 on mazda 6i v6 2005
The conditions that set this code are as follows:
The PCM monitors changes in input voltage on Brake Switch No. 1. If the PCM does not sense voltage changes at PCM terminal 82 when alternately accelerated and decelerated 8 times, the PCM determines that brake switch No. 1 has a malfunction
Possible Causes are:
  • Brake Switch malfunction
  • connector or terminal malfunction
  • Short to power circuit between Brake Switch terminal D and PCM terminal 82
  • Open circuit between Brake Switch terminal D and PCM terminal 82
  • Malfunctioning PCM
Nov 11, 2009 | 2005 Mazda 6
Intel Motherboard Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
