The machine fills with water, drum doesn't go round. The programme dial doesn't move on, but if you move it on manually the machine does empty the water.
  • Gerry Harvey
    Gerry Harvey May 11, 2010
    Could be two problems timer and or motor....
  • 82 Answers
Sounds like a motor problem or control unit problem.
Hope this helps.
Posted on Sep 29, 2009
The machine is displaying ELoOOOO and making a noise. How do I clear/fix this? Cheers, Phil
its clearly trying to empty the drum of water maybe there's a blockage problem in the outlet water hose as the machine cant advance till the water censor switch tells the programmer that the machine is ready to fill by being empty first please blow into the water outlet pipe to perhaps clear the blockage eric
Dec 21, 2017 | Washing Machines
Fills with water correctly, will not go to next cycle
Hi ,, ok lets try some fault finding,,, try putting the washing machine on a no or low temp programme like wool,, or even the fill empty spin , see if it moves then,, if the programmer moves through then spins, i would assume the thermostat is broken,, if it moves through but does not spin , it may be the heating element,, if it does not move at all in any programme i would assume the programmer has a problem
Nov 14, 2013 | Whirlpool Washing Machines
WATER GOES IN BUT WILL NOT SPIN ROUND
check the lid switch. if its bad it will not spin. and also check for a broken drive coupler, from motor to the transmission. to check lid switch. pull the lid switch out. tape the 2 wires together, if it works fine then youve found the problem. good-day !
Apr 20, 2012 | Washing Machines
Bosh washing machine won't do any programmes
If it fills then the next phase is to agitate.
To do that the motor must drive
Can you hear a whirring sound from the machine if you get close to it if so then the belt driving driving drum may have snapped.
If not then the motor brushes may have stuck or have worn out.
Does the machine programmer advance by itself or are you turning the dial
May 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Programme not going through cycle
Hi does the machine fill with water? If the machine programme dial does not move then it is more than likely to be the heat cycle that needs looking at!
If you are local to me then we can arrange a visit to repair.
Good luck.............................
Dec 28, 2008 | Hotpoint WMA54 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
