Question about Maytag 30" Built-In Double Electric Wall Oven - Black
WALL OVEN BAKE ELEMENT MEASURES 19 OHM RESISTANCE WHEN DETACHED. VOLTAGE ACROSS ELEMENT READS ZERO WHEN CONNECTED AND TURNED ON
4 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: Wall Oven
Hello zultar777,
The oven will fit however it will stick out a few inches beyond the front of the cabinet. If that looks ok to you, then go for it.... Is ther any way you can open up the wall behind the oven to allow the new oven to recess in deeper? You may want to investiaget that option. If the wall behind the stove is a non- weight bearing wall..you should be able to cut it opne and remove a section of the wall studs.. also..check to see if the new oven uses any mounting tabs to lock it in place.. if it does and these are close to the front of the oven, you may have to jury rig something to secure the oven.. It may or may not use them thou so check with the manufacturer..
Good Luck
Regards,
Rick
Posted on Dec 04, 2008
kachbibi1
  • 979 Answers
SOURCE: maytag CWE 4800 oven bake element
Go to google and type in model and IOM and it should give you what you need. Replacing the element should not be hard. Just disconnect the power first. My main concern is that you said the oven won't turn off. You may have a control switch problem. Did the element melt at the terminals or in the middle of the element itself?
Posted on Feb 15, 2009
  • 126 Answers
SOURCE: maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Posted on Jun 25, 2009
My Corriander model oven - stovetop works well, but the oven is completely "dead".
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
1.If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
2.On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
3.Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
4.Repeat the step above for the terminals "L2" and "H2".
5.If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
6.With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
7.A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. )
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
: rememberI offer free advice bcuz God is so good!
Dec 07, 2016 | Fisher and Paykel Ovens
What should the voltages across the elements in an oven be when using the different settings?
The heating element is either off or on and it should be 220. The issue you are having is the thermostat.
Mar 09, 2016 | GE Ovens
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
My oven will not heat up. the orange light turns on but thats all.
I am assuming this is an electric oven? If you have an ohm meter you can verify that the bake or broil element is good by measuring the resistance across the element. If it reads short then the elements are bad. The more expensive problem which usually tends to be the case is the oven controller board. There are to relays that control the high voltage current that is supplied to the elements. When the oven is turned on a signal from the oven controller activates the coil on the relay and closes the contact allowing current to flow to the element. There are two relays, one for broil and the other for bake. Try the oven on broil to see if that element heats up. If it does it could be the bake element, if it doesn't you till need to get a replacement oven controller board. They usually call them timer modules or clock modules. Good luck!
Jul 20, 2011 | Kenmore Ovens
This is a repost per instructions from FixYa I would prefer to hear from heatman101 on this please.We just reinstalled a used GE JTP13GV wall oven that was working when it was removed. Everything...
So you have voltage at the incoming side of both elements - good. If you have tested the element with an ohm meter across both terminals with both wires disconnected and have a reading of 1067 ohms you have a porblem. On a 240 volt system as an example with a 2000 watt element the resistance of the element should be 29 ohms. 1067 ohms means there a very slight circuit but when power is applied it simply will not work.
Just try that test again with the wires off the elements. It should not be over 100 ohms. If it is the elements are faulty.
Also with a voltmeter test across the terminals of the elements with wiring connected and the oven elements turned on. If you have full supply voltage across the terminals it definetely means that the elements are faulty as the full supply voltage represents a good active and neutral path.
If you test again and the continuity/resistance of the elements is good then the power isn't returning to the main neutral terminal which means that you have a faulty neutral. Sometimes the thermal cut-off switch has the neutral wired through it. With the whole of the system turned on and the wiring accessible you can use the voltmeter to trace the voltage path from the oven switch, through the elements and back to the neutral.
Feb 09, 2011 | Ovens
Electric Oven is not heating up (BAKE)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It could be that your lower element is burnt out or ready to burn out. They last 3-5 years depending how much you use your stove.
Disconnect POWER to the stove, remove the screws holding the lower element to the back of the inside of the stove, pull out carefully and remove the 2 screws holding the wires on. Check the element with an ohm meter, it should read 0 (zero or very close) resistance on an ohm meter. You may also take it to a store that sells replacements ($25) and they may check it for you.
Nov 13, 2009 | Ovens
Verify 220 volts into the oven terminal. If you have voltage in and no voltage at the element,you have a bad oven control.
Sep 28, 2009 | Ovens
GE Model JKP12G0P2BG Wall Oven Bake Element Not Working Properly
The temperature sensor is bad. The broil element will work even if the temp sensor is bad but the bake element will not. If you measure the resistance across the contacts on the sensor, it should be around 20 ohms, if it is much higher (1000+), then it is bad and should be replaced. It is just as easy to replace as the elements and looks like a small pencil sized rod in the inside top of the oven. Let me know how this works out for you.
Benjamin
Nov 19, 2008 | GE JGRP17 Gas Single Oven
Maytag 30" Built-In Double Electric Wall Oven - Black Logo
110 people viewed this question
Top Maytag Ovens Experts
Oloyede Monsuru
Mack Baxter
Craig Butler
Craig Butler
Are you a Maytag Oven Expert? Answer questions, earn points and help others
