Question about Sanyo Xacti VPC-T700 Digital Camera
I pluggeed my camera into the usb port on the computer but know the green light will not turn off and the lens is still zoomed out i really need help.
Lens size of a SVP DC- 1251
This is fixed lens camera.
Key Features Digital Zoom
8x Camera Type
Compact LCD Screen Size
2 in. Resolution
5 Megapixel Optical Zoom
Without Optical Zoom Image Quality Camera Resolution
5 Megapixel Image Sensor Type
CMOS Video Video Resolutions
640 x 480 (VGA) Lens Interchangeable Lens
Not Interchangeable Lenses Optical Zoom
Without Optical Zoom Exposure Control White Balance
Underwater (Preset) Storage Memory Type
Built-in • SD Card Built-in Memory Size
16 MB Included Features Self Timer
2 Sec. • 10 Sec. • 12 Sec. Tripod Mount
With Tripod Mount Interfaces Interface Type
USB 1.1 Power Supply Battery Type
2 x AAA Batteries Dimensions Depth
0.83 in. Height
2.3 in. Width
3.5 in. Miscellaneous UPC
859108008797 Product ID
77004823 Included Accessories
2 x AAA Batteries • USB Cable • Strap • AV Cable
Aug 04, 2012 | VuPoint Cameras
I need to recharge my battery on my vivcam t328
This one is a bit different as the battery can be swapped out but the only way to charge these is to plug in the usb cable into the camera and into a usb port on your computer. The computer has to be running.and the camera has to be turned off. You will see a green light that shows it charging when the battery is charged the light will go out. Depending on how much power the port supplies it can take 3-8 hours. As long as the port is supply power it really doesn't matter what computer it is on as you are not transferring picstures so don't worry about plugging it into any thing that running to get a charge.
Dec 28, 2011 | Cameras
I mistakenly dropped my digital camera a few inches when the lens was out.When i tried putting it off to know if the lens would go back in,it didnt move so i forcefully pushed it back inside.Now, when i...
You've likely jammed the zoom motor in the lens. You're correct in thinking that the camera can't work without the lens out. With it being physical damage repairs wouldn't be covered under warranty so you either need to pay to have it repaired (if that's even possible, it varies camera to camera) or buy a new camera unfortunately.
May 11, 2011 | Cameras
Fuji Zoom Error Message
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Jan 13, 2009 | Fuji Finepix J50 Digital Camera
Camera cannot connect to pc anymore
yeah it could be the cable,try connecting it to other usb ports as well just to check if its not the usb port..
Jan 09, 2009 | Olympus Camedia C-3030 Zoom Digital Camera
Tried uploading pics on computer now my camera wont turn on or off...did i break it..is there a virus???
I had the same problem. I took the battery out for 30 seconds and put it back in. I then turned it to the view mode, and turned the camera on. Hope this helps.
Oct 14, 2008 | Sanyo Xacti VPC-T700 Digital Camera
X6 won't pick up DSL
hopefully you haev installed the software first on yoy computer>
turn off the computer. connect the phone line one end to the ethernet port on your computer and the other end to one of the LAN port on the x6.
power up the (power cube shipped with the X6), the Pwr and the WLAN should come on and become steady, the LINK light should blink,
turn on you computer, connect a new phone line between ADSL port and the wall jack, the LINK light should become steady.
please rate the answer if it solved your porblem.
thank you
Sep 09, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Camera really messed up!
Have you tried taking out the batteries and leaving it alone for a bit, then loading new batteries? I would try this first before anything. Good Luck.
Apr 09, 2008 | Casio Exilim EXZ75 Digital Camera
Noise when turned on
Sounds like the gears are stripped in your lens. Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Nov 19, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Will not allow menu/dateset
carmera wont work on my compertuer.
Oct 24, 2006 | Fuji FinePix A205 Digital Camera
Sanyo Xacti VPC-T700 Digital Camera Logo
70 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
