Question about Frigidaire ATF6000ES Front Load Washer
Drum only moves one inch then after a few min will kick off
    Problem Solver:
  • 11 Answers
Do you have a belt motor or a stator? if you have a stator, it could be the hall sensor.
Posted on Oct 28, 2009
    Genius:
  • Frigidaire Master
  • 1,474 Answers
By kick off i assume dies........Sounds like motor
Posted on Sep 28, 2009
I have a Whirlpool front loader Model GHW9150PW1.The drum seems to be wobbling real bad and dragging the bottom of the washer,can you help.
First, remove the 2 screws that hold the bottom front kick-plate on and remove the plate. Look to see if any of the shocks have come loose or broke. Post back your results.
Jan 20, 2013 | Whirlpool Washing Machines
My washer is off balance during the spin cycle it jumps, and moves around
With the washer empty, tilt it front a few inches and drop it back down. This will re-level the legs. If it still jumps around, replace the drum snubber, inside the front of the machine. It's a rubber pad that keeps the drum from moving around too much. Snubbers dry out with age.
May 07, 2011 | LG WM-2277HW Front Load Washer
CAN I ADD FREON TO MY FEDDERS AC ? it gets cool for a few mins then compressor kicks off ! does it sound like low on freon , ?
Take the front cover off and make sure the copper bulb is not touching the fins. Bend out a distance of 1/2 inch
Jun 15, 2010 | Fedders D Chassis AED24E7E Air Conditioner
How to remove stuck tires and rims off rear of 2001 f 250.
Greetings: My 97 F 250 has the aluminum wheels. The Aluminum of the rims actually becomes welded to the steel hubs after some time. I have beat on those things with various types of hammers and blocks. I've put a 6' length of 2" pipe between the shackles and wheel in an attempt to pry it of. Tires just absorb all the energy. After hours of frustration I figured out that a standard digging bar will fit between the drum and the wheel. It is tight, but it will fit. Popped both rims off in just a couple of minutes this way. Pry it till it moves, spin the wheel a bit and pry again. You will have to work it all the way around the wheel, but it will come off.
70e8aa04-73ed-407d-86c6-e40620cac7cc.jpg 33777f67-daff-402f-ac36-9615c984f9a9.jpg
Nov 19, 2009 | 2001 Ford F250 Super Duty Super Cab
Washer won't spin, motor sounds like its working, belt is fine...what do I check or do?
The belt may look fine, but if the motor is spinning, then the belt isn't transferring the motion to the drum.
First, make sure you can turn the drum by hand. Turn off the power. Reach inside the drum, grab the opposite sides and turn. If it moves more than a few inches, then it isn't the drum that's stuck. Possibly the belt tensioner has slackened and needs to be adjusted.
Jun 25, 2009 | GE WBSR3140DW Top Load Washer
Motor draws current, won't turn drum.
The motor has failed & needs to be replaced
May 05, 2009 | Kenmore Dryers
Sensor dry timer problem
Clean off the moisture sensor bars. They are the silver curved strips about 4 inches long inside the drum near the lint fitler. If you use fabric softner sheets, a waxy build up will coat the bars. The dyer can no longer sense the damp clothes, so it goes into the cool down and then shuts off. Time dry bypasses the moisture sensor.
Nov 30, 2008 | LG DLE5977 Stainless Steel Electric Dryer
Ilo 42 inch plasma
call for a fix ya technecian around you
Oct 11, 2008 | iLO 3200 32 in. LCD Television
Frigidaire ATF6000ES Front Load Washer Logo
51 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
