HP Photosmart D7360 All-In-One InkJet Printer
Problem for HP Photosmart D7360 All-In-One InkJet Printer
I have tried all the solutions for the Ink System
By miserysk on Sep 28, 2009
I have tried all the solutions for the Ink System Failure for the D7360. My error code is Oxc19a0002 which I haven't seen listed anywhere!
I have tried changing cartridges, opening the right side, disconnecting flat wires and everything else.
Please help!!
Best Solution
posted on Sep 28, 2009
Very Helpful)
gailsbiz
Rank: Wiz
Rating: 79%, 34 votes
This is what I found for you.
If you get ink system failure you most likely have air in your ink system. This will happen after months of use -every ink cartridge you reload and purge will have a little bit of air trapped in it and over time it must add up. You have to do a system reset which causes your printer to start over and do a full purge of ink through your system. This is what happens when you do your first ink system set up when you open install new ink cartridges. To do a ink system reset you must first:
1. After your printer gives you a ink system failure you will need to press and hold down ok and cancel at the same time and then press the start button once. (make sure you hold the cancel and ok down until the system shuts down and then release).
2.Now (Again) hold the cancel and ok Button down and and press the on button again -making sure to keep holding down the cancel and ok until it shuts itself down again. It will seem like it is starting up again up will then just shut off. Now once it has shut off for the second time (It is VERY important that you have a new set of ink cartridges installed before turning on the system for the second time) This is because it will do a full ink purge and rid the trapped air in the system. If you have old ink in it or almost empty it will most likely not purge enough. A new set of ink works best- You can go back to your old ink after if you like and keep the "new" set for back up when the system fails again down the road (it will fail again -this is poor designing by HP).
3.Now once you have shut down the system and loaded a fresh set of ink (all 6 of the ink cartriges) you can now press the on button (at this time you should get a reset code the come on first and the printer will run its purging of the air and new ink.
4. You might have to do this more then once to rid all the air out of the system-keep trying and after 2 -3 times it will stop giving you the ink failure. I have fixed my printer many times by this fix for many years.
If you require any further information or clarification, I will gladly answer you, Please do not hesitate to ask me.
Please click the green ACCEPT icon if you feel I have given you a full and complete satisfactory answer,
If not, we can carry on trouble-shooting the problem, to find the Answer, and sometimes we have to isolate the problem first, And then resolve it for you however I am quite confident this will correct the problem.
Read more: http://www.justanswer.com/questions/1zuco-received-ink-system-failure#ixzz0SR16kcSc
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for HP Photosmart D7360 All-In-One
Questions and Unsolved Problems for HP Photosmart D7360 All-In-One
Do you recommend HP Photosmart D7360 All-In-One InkJet Printer?
Answer
Answer
My photosmart printer (D7360) is a few yrs old..I've changed the cartridges several times and had no... (More)
Answer
I am entering my SanDisk Ultra 15 MB/s 8GB card into my HP Photosmart D7360 printer and it is... (More)
Answer
do not have the disk for installing. I need help to connect the printer D7360 to my laptop. It will... (More)
Answer
Chosen solutions sound promising, but they leave out just how one is able to take the side panel... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
