Question about Plumbing
I have a well water pump that will not get top pressure. Does it need to be bleed from the pump to the well?
    Problem Solver:
  • 10 Answers
How pressure will it build does the pump stey running or does the pressure switch kick out ? if u hear a click and pump stops u need to adjust pressure switch so it will go higher or get a new switch switches are rated like 20-50 20-60 what is ur switch rated for ? if the switch doesn't kick out and pump just keeps running and running u either have a bad pump or ur sucking air
Posted on Sep 28, 2009
How to bleed water furnace
Maintaining water pressure and keeping the circulator pump running, go to the furthest bleeder and remove any air at each bleed port working your way back to the furnace. You must maintain water pressure or you will have to start all over again.
Jan 10, 2015 | Heating & Cooling
Directions to adjust water well pressure switch
Loosen the nut on the top of the housing. It's a "captive nut", so it'll stay with the housing when you lift the housing off.
There'll be a large spring under that nut, with another nut on a threaded stud that runs through the center of the spring. Turn that nut clockwise to increase pressure, or counterclockwise to decrease pressure. If you turn it counterclockwise, you have to run some water to bleed the pressure out of the plumbing before you can tell any difference - it won't instantly drop the pressure in your plumbing. It only tells the pump when to run & when to turn off.
Jul 25, 2014 | Square D FSG2J24M4CP Water Pump Pressure...
How to bleed air bubbles from engine of 99 lincoln continental
Un screw rad bleed . hose in radiatior . . loosen hoses and vent out . You can buy pressure pump to couple on top of radiator
Jul 02, 2014 | 1998 Lincoln Continental
I have a Vaillant Combi boiler, (not sure of make, but its 10 years old),the hot water works fine and the bolier heats up the downstairs rads fine, but the upstairs ones have all gone off...have bleed them...
lost pressure raise pressure up 2 bar and bleed the rads keep topping up untill all air has gone from rads do this with the pump off, turn all your rads back on and follow what in said .
Aug 27, 2011 | Heating & Cooling
Bear with me. my son has a above ground pool sta-rite system model JWPA5E7L-2A2 pump. he says the pump is running and sounds normal but he has very low suction and exhaust pressure. any ideas before I go...
Be sure that the pump gets primed, not always easy. Sometimes you need to examine the pump impeller. Debris sometimes restricts in this area.
look for an air bleed, near the pump, if you find one, you can bleed air there...
IF your system has to lift the water over the edge, as opposed to through the side, bleeding the air requires patience, sometimes. The pump quits pumping when it gets any air << an issue if you use a vacuum hose, you need to TOTALLY bleed the air out of the temporary hose, before hooking it up....
I hope this helps. Keep after it, you really NEED good filtering flow for clean water. After you finally get it going, have people put their hand over the discharge end of the system and make note of the volume and pressure felt there.... When taking in air or not pumping, it will be obvious.
May 14, 2011 | Sta Rite Pool & Spa
Water is seeping out from the pressure gauge on top of the filter.
You probably need to replace the air bleed assembly or just the pressure guage, depending where the water is coming from.
Sep 04, 2010 | Pentair FILTER TANK BOTTOM, 48 SQFT
Air lock in water pump
You need to bleed off the air. There should be a bleed port on the housing to do this. If that does not solve the pump coming back on, it could be air in the pressure switch.
Jan 16, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Clicking central heating pump
your auto air vent is in the top right corner inside the burner compartment.
you may need a new one or auto air vent.
clicking like this is usually on the divertor head or divertor valve.
very strange pump clicking.
jollygreenplumbing@hotmail.com
Jan 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you "bleed" the rear breaks? on a bandit 600? can anyone help?
Brake fluid will eat away at plastic and paint!
Wipe any spilled fluid with the rag and lots of water.
Tools needed:
Wrench/Spanner (average 10mm)
Brake bleeding kit (rubber fitting, clear hose, small container)
Brake fluid overflow container (to put the brake bleeding kit small container in)
Rags
Brake Fluid
Attach the brake bleeding kit to the brake fluid nipple located on the brake caliper.
Loosen the nipple so the fluid is free to flow down the brake bleeding kit tube and into the small container
Remove the master cylinder cap (top) so you can monitor and refill more brake fluid into the master cylinder as you bleed the brakes.
Pump the brake lever so the old/new brake fluid is forced through the tube into the brake bleeding kit fluid container
Keep the volume of the master cylinder constant (near full) as to not have it empty. Keep pumping on the brake lever until the fluid coming out is clear (rather than the old brown/black colour).
Once all the tiny air bubbles are gone hold pressure on the brake level and re-tighten the brake fluid nipple to close it off.
Replace the master cylinder top cover.
Remove the brake bleeding kit from the caliper and use the rag and water to clean up any spillage.
Alternately, you can pump the pedal once, open the bleeder then shut it, pump the pedal again, open the bleeder and shut it and continue (adding as necessary) until the fluid is clear.
The advantage to doing it this way is much less pumping to get the air out of the lines you created when you first started on the first method.
Sep 10, 2009 | 1996 Suzuki GSF 600 S Bandit
MY PUMP DOES NOT CIRCULATE WATER ANY LONGER. HELP
Need more information to get specific, but some likely causes are:
  1. Pump or heating coils are air bound, should be an air separator with a bleed valve on top by the pump and bleed valves on the coils, let the air escape slowly. It doesn't take much air to bind up a system and the air doesn't have to be traped in the pump itself, these pumps are low head (dont put out much pressure) but very reliable.
  2. System is low on fluid (water), Internal system pressures are dependent on design considerations but typically will be anywhere from 3 to 15 PSI. There needs to be enough pressure to keep the water from boiling.
  3. All valves to heat zones closed, most zone valves have a manual open position, try opening one or two. A valve problem is more likely than pump failure.
  4. Power to the pump? Correct voltage and polarity?
Thats about all I'v had to deal with on my system,
Good Luck.
Aug 15, 2009 | Grundfos Plumbing
Plumbing Logo
115 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
