Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
It won't connect...did I lock it. It has worked before and is fully charged
Yes
Posted on Sep 30, 2009
My blueant s4 won't charge
It must be a battery problem as the battery indicator level says full when you remove it from the charger and the phone doesnt work.
Mar 19, 2013 | Blueant Ant S4 Handsfree Voice Controlled...
Horn will not stop honking
try this. discconect battery neg cable, unplug horn relay under hood, lock front door with key, reconnect battery, unlock front door with key, start car, reinstall horn relay,,, good luck. this works for acura so no promisies on yours.
Feb 01, 2018 | Nissan Maxima Cars & Trucks
Starter motor won't work
Try turning the eng over with a socket and breaker bar the eng maybe locked up
Mar 02, 2013 | Cars & Trucks
My 2000 Vespa et150 won't start. Battery is fully
-do you use the right key? (thick brown/black colored) after aou turn the key on, does a light go on on the dashboard?
- seems to be an issue with the lock code of the key (wrong key)
then the engine immobiliser does not allow to start..
Sep 17, 2012 | Cars & Trucks
Battery won't charge up
One or more of the cells in the battery may have died while it wasn't being used. LI-Po batteries are memory resistant but they can still develop one if they're left fully discharged too long or at a half charge too long. They require full charge\discharge cycles to keep them from developing a memory.
Feb 13, 2012 | ESKY 001336 20C 11.1V 800mAh Lithium...
Won't start. 2 fully charged batteries tried. Cleaned battery connections. Just clicks when turning key to "Start". Car stopped while driving. Towed home.
This sounds like a loose connection at the starter, Follow the positive battery cable down to the starter. Check the connection for being hot (rusty color). There are two large connections on the starter check both. If one or the other looks discolored the starter may be damaged. Be sure the engine is not locked up. Try to turn the engine by hand at the main crank bolt.
Sep 24, 2011 | 2001 Mitsubishi Montero Sport 4WD
connect the charger to the socket, then connect the charger to your laptop. if it does not charge remove it for 5mins, connect the charger back. it will work now. sometimes when the battery is fully charged and you remove the charger and connect it back it may not charge until the battery is low;lets say 99%.
Sep 23, 2011 | Advent 4211c Notebook
I have a 1984 rx7 to get straight to the point,I park my car one evening to find out the next time i tried to start it won't. I thought it may have beenout of gas. but that was not the problem.The car...
I had a situation similar to this. My starter was not getting enough power, check your battery connections and make sure it is fully charged.
Sep 19, 2011 | 1984 Mazda RX-7
Panasonic HM-TA1 won't power on with battery fully charged.
The battery will not charge when the device is turned on. Make sure that when you connect it to your computer via its usb that you do not turn it on otherwise it wont charge.
The annoying thing about this device is that when you connect it to your computer and turn it on, on the LCD it will say "connecting via usb" and the memory bar will show that it is fully charged, however the battery is not. This must just be a design flaw as the battery won't be charged.
Just remember to plug it in and leave it, do not turn it on!
Jan 24, 2011 | Panasonic HMTA1 Camcorder
Lost pairing?
First when ya call connects, hit the Menu key (three lines inthe center) choose USE HANDSET.
Second Make sure the Bluetooth is fully charged, andit seems to lose charge fast.
Dec 15, 2007 | Motorola Mobility H300 Wireless Headset
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
83 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
