Question about Hotpoint WMA54 Front Load Washer
Can bearings be removed without removing the drum itself on a wma54
  • 3 Answers
Sorry no its a big job but here goes isolate from electric and power remove lid and rear bottom cover.
remove soap drawer and remove screws you can see behind it then remove fascia, then undo the door seal and plinth cover ,then remove front panel.
then remove dispensor hose from tub, go to the back remove sump hose and motor and wiring to element then remove top front sub frame and undo the top and bottom weights then remove the pins that hold the suspension legs to the tub lift off the springs and the tub is free.
Then split the tub knock out the old replace with new that is assuming you dont damage the shaft of the drum support whilst removing il then do it all in reverse this normally takes me 2 hours it might take you 2 days but hey lifes full of challenges good luck
Posted on Sep 28, 2009
Hotpoint wd129 I suspect bearings gone drum has tilted and rub against outer casing and now leaking just under heating element. Does this mean a write off? Thanks Carlo.
Posted on Jun 12, 2011
    Genius:
  • Hotpoint Master
  • 1,461 Answers
I think its sold as half drum on this model!! 6^0 pounds
The rear drum wont come off as i would expect
Yes, Undo the 32mm nut, first. And, don't get the bearings dirty with dust from the brake drums, or , if you do, replace the inner and outer bearings with new greased up ones.prev.gif next.gif REAR DRUM BRAKES Brake Drums REMOVAL & INSTALLATION CAUTION
Brake linings contain asbestos. Asbestos is a known cancer-causing agent. When working on brakes, remember that the dust which accumulates on the brake parts and/or in the drum contains asbestos. Always wear a protective face covering, such as a painter's mask, when working on the brakes. NEVER blow the dust from the brakes or drum.
  1. Raise the vehicle and support safely.
  2. Remove the wheel and tire assembly.
  3. On vehicles without rear bearing hub, remove the dust cap, cotter pin, nut lock, wheel bearing nut and washer from the spindle. Remove the outer wheel bearing. Remove the drum with the inner wheel bearing from the spindle. If the drum is difficult to remove, remove the plug from the rear of the backing plate and push the self adjuster lever away from the star wheel. Rotate the star wheel to retract the shoes. Remove the grease seal.
  4. If equipped with a rear bearing hub, remove the drum by removing the retainer screws from the drum and pulling the drum from the hub assembly. If the drum is difficult to remove, remove the plug from the rear of the backing plate and push the self adjuster lever away from the star wheel. Rotate the star wheel to retract the shoes. To install:
  5. On vehicles equipped without rear bearing hub, lubricate and install the inner wheel bearing. Install a new grease seal. Install the drum to the spindle. Lubricate and install the outer wheel bearing, washer and nut. Adjust the bearing preload following the procedure outlined in the "Rear Wheel Bearing'' of this section. When the bearing preload is properly set, install the nut lock and a new cotter pin. Install the grease cap.
  6. On vehicles with rear bearing hub, install the brake drum to the hub assembly and install the retaining screws.
  7. Install the wheel and tire assembly. Adjust the rear brakes as required.
  8. Apply the brakes until a firm pedal is obtained, prior to moving the vehicle.
Jul 12, 2010 | 1991 Hyundai Excel 4 Door
Drum is not turning
Could be the brushes, only way to prove it is to remove the motor and check the brushes for wear.
If they are less than 3 or 4 mm long, then they need replacing. If brushes are o/k, then it is probably a control board fault.
Jun 03, 2010 | Hotpoint WMA54 Front Load Washer
My machine hotpoint WMA54 takes the water but the drum does not turn, what could be the problem? thanks
Could be motor brushes in need of replacement.
To check them, remove lower rear cover of washer.
Unplug motor and remove earth wire, remove drive belt.
Undo 2 screws securing motor to drum, and lever motor off
the mounts
Replace brushes if less than 3 or 4 mm long.
If brushes o/k, then could be control board problem.
Check all connections between module and motor.
Please rate my solutioin.
Thankyou..
Feb 01, 2010 | Hotpoint WMA54 Front Load Washer
Hotpoint WMA54 - in middle of attempting to replace the drum bearings. I've split the drum apart and am attempting to remove the existing bearings and spider; however, I'm unable to separate/unscrew the...
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Jan 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Locating the filter on the Hotpoint WMA54 front load washer
To check and clean the filter, you need to remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction or blockage here and in the pump as well.
Hope this helps to solve your question.
Please leave feedback.
Thanks.
Dec 12, 2009 | Hotpoint WMA54 Front Load Washer
Where is the filter on the hotpoint wma54 washing machine?
Remove lower rear cover of washer, locate and remove large black hose fastened to drum, inside you will find the filter.
Please rate my solution.
Thanks.
Sep 22, 2009 | Hotpoint WMA54 Front Load Washer
Loud niose coming from my machine when spinning
  • Hi,
  • Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | Hotpoint WMA54 Front Load Washer
Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
Hotpoint wma54 washing machine
sorry but not the job i would recommend to anyone not done or watched it done before its about the most difficult job to do on any machine, even though in my 20 years experience this is the easiest machine to do a drum bearing change on, most of the machine has to be stripped down, removing all the front panel / timer panel / door seal and drum front / drifting out the old bearings fitting the new ones and rebuilding the machine, not counting testing for and rectifying any damage the drum has done to the rest of the machine and surrounding parts, good luck if you attempt it, sorry
Sep 24, 2007 | Hotpoint WMA54 Front Load Washer
Bra wire has between drums
you will need to call in an on site tech.but from my exp.the tub assembly would need to be replaced if you want to solve this problem.
Jun 23, 2007 | Hotpoint WMA54 Front Load Washer
Hotpoint WMA54 Front Load Washer Logo
300 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
