Question about Olympus SP-310 Digital Camera
Suddenly for no apparent reason Windows XP fails to recognise the camera. Have tried reinstalling the software, checked all the ports and the camera is accepted on my friend's XP
  • pellsyeat Sep 30, 2009
    As I mentioned in my message I had already checked all the USB ports! They're fine because my scanner works on all of them. And while I'm at it I have also told you that I've reinstalled the driver and confirmed too that everything's OK when the camera is connected to another XP computer.
    So have you any useful suggestions?
    Regards
    Peter Spillard
  • pellsyeat Oct 01, 2009
    Hello again
    Thanks for your prompt reply
    The problem isn't with my USB ports. They all work for all other hardware (even when I switch them around) but the camera works on none of them. Does that help?
    Ideas please
    Peter
  • 10,594 Answers
Please try another USB port in computer.
Hook camera in another available USB port in computer. Hope Windows XP will recognize it and problem will be solved.
Thanks.
Posted on Sep 28, 2009
  • Shahid Electronics
    Shahid Electronics Sep 30, 2009
    computer.
    Regards
    Peter Spillard
    In that kind of problem I would recommend to delete USB driver in computer, (My Computer, Properties, System Properties, Device Manager, Universal Serial Bus Controllers) run add hardware wizard from control panel and let Windows reinstall USB drivers to refresh it.
    Shahid Electronics Oct 01, 2009
    Hello again
    Ideas please
    Peter
    Thanks for update,
    Only 4 things are involve in camera hooking with computer, Camera, Computer, drivers and USB cord.
    Camera works with on other computers so it is clear and have no problem.
    Computer works with other USB devices that means USB ports are working fine.
    USB cord/ wire can be broken or internally cracked so please try/ use another USB lead.
    Once USB connection established between computer and camera, Windows will detect it automatically and will look for required drivers for file transfer process.
    So please check USB lead and check it on another computer or use another wire.
    Thanks.
For no apparent reason, Diskeeper 2008 won't suddenly analyse drive c. The analysis goes all the way to 100% and then jumps back to 97% and stops. Shortly afterwards Windows XP reports an unhandled...
Did you try uninstalling it and then reinstalling the software?
Have nothing to lose. You can also try a OS repair in case this does not work. Or try XP2/3 versions.
Sep 18, 2017 | RTO Computers & Internet
Olympus model FE - 170. I have just installed Microsoft Vista and keep getting a message that the camera is not being recognised even though it is properly connected through a USB port. I have...
try pluggin it in and go to control panel and search and add hard were and see if there is any files missing or invallid
even try uninstall and reinstall
Sep 07, 2008 | Olympus Cameras
Windows xp will not recognise the seagate freeagent desktop drive
Assuming you have tried other usb ports and had no change,remove the usb connection, then go back into device manager and select the usb controller, right click and select delete as this will erase any input driver the usb port recognises. Restart the pc and then the controller should be reinstalled automatically as it sounds as though the controller has become corrupt for some reason. Go back into device manager and check there are no exclamation marks, reconnect the drive and see if it's recognised.
Oct 05, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Regards,
Mar 26, 2009 | Canon EOS 450D Digital Camera
My computer will not let me install software
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 27, 2009 | Logitech Webcam
Webcam
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Oct 23, 2008 | Computers & Internet
Camera stopped bing recognised
sure..sounds like you may need to reinstall drivers for both the webcam and printer..sometimes those drivers will go corrupt when there's a power glitch.
get the printer drivers here
Mar 04, 2008 | Computers & Internet
Software driver problem
Do any other devices connect successfully to that same USB port?
If no, try another USB port.
If yes, when you reinstalled your software, did you uninstall first? If not, see if you can. Once uninstalled, verify that the device is removed via Device Manager.
Once removed, if on XP or Vista, try to connect using the built in system drivers.
If this does not work, try reinstalling your drivers, but be sure to check for system prompts when you connect. If you do not respond to those prompts, the device will not mount.
Let me know how it turns out.
DigiChick
Nov 05, 2007 | Fuji FinePix A340 Digital Camera
Will not function with Windows Vista
You do not need any software for the camera to be recognised. As you have discovered it can complicate things. Remove the software. Vista like XP before it will recognise the camera via the Camera/Scanner Wizard.
Aug 30, 2007 | Fuji FinePix A350 Digital Camera
Olympus SP-310 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
