Question about Dell Latitude D505 Notebook
D505 will not power of charge the battery, i have tried a different ac adaptor, that is not the problem, anything else i can try?
  • simplifyITuk May 11, 2010
    is it the square socket?
  • 3,940 Answers
Pretty much, you are left with replacing the motherboard to fix the charger issue.
Posted on Sep 29, 2009
Dell latitude D505 battery not charging
Take Dell latitude D505 battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
hope this helps
Mar 31, 2013 | Dell Latitude D505 Notebook
It doesn't do anything. get nothing when i press the start button either with ac adaptor or without battery appears to be fine.
Please elaborate on your issue: If your PC does not turn on or give any lights with or without AC adapter, most likely the internal power supply/connector has gone bad, and with it being a Latitude D505 it probably is out of warranty. Only on eBay might you find an old part or two to replace it.
Please feel free to contact me with any questions.
May 04, 2011 | Dell Latitude D505 Notebook
My netbook won't charge
Try with a different power outlet
check whether the connections are proper
check whether the system is working without the battery and the AC adaptor
by this we will be able to find whether the problem with the ac adaptor or with the battery
Dec 25, 2010 | Sylvania G-Netbook
Dell laptop wont turn on. battery only works if it is already charged and it doesn't run on A/C power.
It means that is something wrong, most surely with te AC/DC adaptor. Try with other compatible adaptor or take the laptop to service.
Nov 02, 2010 | Dell Latitude D505 Notebook
My laptop wont charge. if i unplug the ac adapter and plug it again it wont charge... how to fix it?
Check for physical damages on the power cord or teh power brick try it as well on a different Laptop if it does the same thing if the adaptor works fine in a different laptop try plugging the adaptor without the battery on the system try unplugging and plugging it back in if it will work properly without the battery then most probably either your battery needs to be replaced or your systems Motherboard....
also you can try updating system BIOS which is risky, check your Manufacturers website or call them for any information about BIOS updates for the system.
Jun 03, 2010 | Computers & Internet
Dell Inspiron B130 Battery Problem
Sounds like the cells in the battery went bad. Try to turn on your laptop with just the ac adaptor hooked up and your battery out off the laptop to make sure that your ac adaptor is working properly. If you can boot up into windows with just the ac adaptor hooked up then you know your ac adaptor is good.
If you get that far then try a different battery and see if the laptop charges with another known good battery. If it does then you know your original battery is bad. If it doesn't charge your different known good battery then you know the motherboard is bad. Hope this helps.
Ben
May 26, 2009 | Electronic Arts The Lord of the Rings: The...
Wont power up
the vr\ery first thing what u have to do is that disconnect the ac adaptor and take the battery out of the computer and then press and hold down the power button without the battery and the adaptor for one minute and then connect the ac adaptor and put the battery back in and then try and turn it on and what u can do is that try and turn on the computer only with the battery and then take the battery out and try and turn it on only with the adaptor,and then what u can try is that try with the different adaptor having same configuration,and try and connect the ac adaptor into the different wall outlet....good luck
Jan 28, 2009 | Dell Inspiron 6000 Notebook
My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
      Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    COMPAQ V2000 WILL NOT POWER UP WITH DC/ADAPTER OR BATTERY
    Hve u tried a differnt adaptor , the adaptor might be blown too ,try replacing the adaptor , also check for the power cord if it has any kinks in it which may be interrupting the power supply , since the adaptor 18.5 v 3.5 a is the most common of all hp adaptors u should find one to try .
    Aug 27, 2008 | Compaq Presario R3000 Notebook
    Lap top problem
    Hi
    If the AC power light is blinking, try the following steps:
    1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
    2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
    defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
    3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
    4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
    5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
    Regards
    Mike
    Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
    Dell Latitude D505 Notebook Logo
    157 people viewed this question
    Alun Cox
