Question about Reddy R70ET Utility Heater
Small ReddyHeater won't stay on
I have a smaller (without wheels) unit that stays on for about 5 minutes and then shuts off. When I unplug it and let it set for a minute, It fires back up and does the same thing. I've changed the fuel, (burns oil or kerosene), and have blown it out real good. It's about 3 yrs old, but doesn't have much use on it, and is kept up fairly well.
Thanks to any help
Ray in SC
The photocell may be dirty or need to be replaced. Take a look in your owner's manual or check online for replacement part.
Posted on Dec 27, 2007
Oven won't stay on
I would say a fuse in cuircit board or something in the mother board
Dec 19, 2011 | Bertazzoni X30 4 GGV X Gas Kitchen Range
I bought a Sigma BC 509 bike computer. I have completed settings without any problem, but I don't know how to turn the computer off to save battery life. Can you help?
It will be auto shut down,
dont touch it for 5 minutes and dont spin the wheel with the pick up on it!!!!
The clock will stay on but all other details will disappear.
Jun 23, 2011 | Cycling
Water turned off unexpectedly now machine won't spin final cycle and timer stays on 4 min and appears to continually try and drain ( intello 7.5
Unplug unit for 5 minutes to reset control board. If problem still persists, you will need to call a technician to service it.
Jun 15, 2011 | LG WM-2277HW Front Load Washer
The power won't stay on..it turns on for a second then shuts back off
Unplug the set see if it resets. Plug back in after 5 minutes to see if it works then. Otherwise you need a tv repair shop.
May 16, 2011 | Televison & Video
I have a glow warm 20000 btu natural gas unvented heater. The unit is wall mounted. It won't stay on for more than 15 minutes, then shuts itself off. Its in a corner if that makes a difference... but has...
well, these heaters are typically thermostat-bound, and I have found that they simply will not burn continuously, like a blue-flame heater. Try turning up the setting--this will make it come on/off more often, effectively heating at least one med-lg room, and partially for adjoining areas. Keep in mind that these only rated for 700-1500 SF--that is NOT the floor measurements, but square feet of airspace; eg., a 10' x 15' room has 10' x 15' x 8' (8 foot ceiling) =1200 sf. That said, My 15k btu wall unit had been the sole heating source for my entire home for 5 years, until last year, when I acquired another smaller unit. However, I typically only use a few rooms, and shut off unused areas (ya, was 'cool' in unused back room areas).
Dec 16, 2010 | Desa International GWP20T GLOWARM Wall...
Optoma HD80 DLP - can't keep the projector lamp on.
remove lamp. put in freezer for 5 minutes. reinstall. when unit comes on go in menu and select lamp settings. reset to zero hours. it fixed mine. every month or two i have to do it again but its better then a new lamp plus check air filter
Nov 10, 2009 | Televison & Video
Alarm stays on,won`t go off
Press the clear/reset button.Unplug the unit wait 5 minutes and plug it back in.If the alarm is still on the keypad is shot.If you don't want to replace the keypad(if problem is not resolved) remove keypad and disconnect the alarm
Sep 16, 2009 | Dryers
Stays lit for 25 minutes and shuts off
How large and sealed of an area are you using it in? I ask because those units have a low oxygen sensor which will shut it down if there is not enough oxygen in the space.(kinda prevents that pesky suffocation thing). Otherwise if using it in larger cold spaces, the issue is can be from the smaller tanks. As mentioned above, a larger tank can solve this, because these units have a fairly good input rate, which will cause the smaller tanks to freeze, and lower the propane temperature and evaporation rate, basically runs out of gas until the tank warms back up.
Jan 19, 2009 | Mr. Heater (F274825)
Reddy R70ET Utility Heater Logo
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
