Question about Kodak EasyShare DX7440 Digital Camera
Camera turns on when it is moved and then turns off
Camera works fine but turns on when it is in the case and the case is moved. It later turns off. It also turns on when it is moved at all.
    Sergeant:
  • 151 Answers
For this problem try the following:
* Try removing the memory and the battery
* Try using the camera w/o the memory card
* If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Posted on Sep 28, 2009
When I turn camera on, lens goes fully out and back in again, about 4 times, then Turn the power off and on again.
Guess work.
When fine sand (or similar particles) get stuck in-between the tubes (lens barrel) the lens will behave that way.
Your case may be caused by something else but its worth trying to fix it yourself first.
Prepare a blower or fine brush, ready in one hand and switch on the camera (either fixed to a stand or stand it on a solid surface) Give it a good blow and brush gently (all around the tubes) while the lens is moving. It will stop and work normal when the foreign body is removed. If this does not work, keep asking because other people might provide a better answer.
Nov 05, 2015 | Sony Cyber-shot DSC-H300 Digita Camera -...
My cub cadet was working fine when I turned it off one hour later I started it and it will not move in any direction. The blades work fine and brake is off. It has never done this before.
bad check valve caused from dirty oil and filter replace both oil and filter have to take in for check valve about 100.00 if oil and fiter 80.00
Sep 06, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
Why is my Samsung S1050 no longer taking photos, the outdoor shots are totally 'burnt out' but most flash photos are fine
Don't know if this is the problem but is the camera set on the right setting.
I had a problem whereby the pics were showing like duotones but then found the setting dial had moved when it was put into its case after use. When re-used I did not check to see if it was on the auto setting hence the problem!!
Jun 24, 2014 | Samsung S1050 Digital Camera
The lens keeps on moving in and out and there is a sign on the screen to turn off and back on the camera... I have a sony cybershot dsc-w55
I have a cybershot DSC-P5 that was doing this. The plastic ring around the lens that is glued to the casing had become warped. We simply popped it off, brushed/scraped the excess glue away and put the casing back on, now it works fine! Just store it properly and keep an extra eye out for dust coming in where the lens used to be.
Jun 28, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
I dropped my Nikon Coolpix S600 camera on the floor at a concert and now when I turn it on, it says LENSE ERROR and shuts off right away.. and the lens doesnt come out. It just makes a weird noise! Is it...
there are some fine gears that move the lens in/out ... if it dropped on the extended lens then its likely a gear was broken or knocked out of place .. it is likely repairable but its really tricky working on these things .. there are fine wires and delecate stuff inside.. sometimes a particle will get into the gears and keep them from operating .. if thats the case you can try gently moving the lens around to try to free it .. but unless you can find someone familiar with working on this then i think you need a new camera ..one with a strap ..
Aug 01, 2009 | Nikon Coolpix S600 Digital Camera
Digital camera
I had almost similar problems with my A10 from day one. The camera shuts down before the battery is depleted, most of the time while I was operating the zoomlens. I bought a new battery, but that didn't solve it. Later I decided to take it apart as a last option. As my suspicion was the zoomlens I took out two crews of the motor that operates it. Now the motor has a bit more space to move. It seemed to be too tight against the gears so it could cause an overload. After that it worked perfectly. I made pictures for hours without having the same fault again. Be carefull too make notes where all the tiny screws belong of the casing. And maybe it will be enough to just loosen the motorscrews, but leaving them out will not make it fall out of it's place. I hope someone can use this information.
Greetings, Ron Timmermans.
Jun 03, 2008 | Pentax Optio A10 Digital Camera
White Screen
Normally there are two reasons for the given problem.
1). Bad or defective CCD. and/or
2). shutter not working.
in the first case the only solution is the replacement of the CCD.
Please click HERE
And in the later case sticking of shutter blade, non functioning of shutter blade will cause the problem. This can be rectified by sending it to some repairer.
Click HERE for the manual.
Main support number: 800-755-3854
I hope you are satisfied with my solution..
Goodluck..
Feb 21, 2008 | Fuji FinePix S5000 Digital Camera
My nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
Aug 05, 2007 | Nikon D70s Digital Camera
Pentax Optio
Normally there are two reasons for the given problem. 1). Bad or defective CCD. and/or 2). shutter not working. in the first case the only solution is the replacement of the CCD. and in the later case sticking of shutter blade, non functioning of shutter blade will cause the problem. This can be rectified by sending it to some repairer.
Sep 13, 2006 | Pentax Optio S Digital Camera
Kodak EasyShare DX7440 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
