Question about Copystar Office Equipment & Supplies
Small thin line comes up on copies, i have cleaned glass etc.
  • Copystar Expert
  • 158 Answers
Four things that cause lines on copiers dirty optics needs drum or drum blade or corona in a lot of the copystars the drum drumblade and corona are all in one unit that you can replace
Posted on Oct 03, 2009
Printing from auto feed leaving lines down side of page
if you mean making a copy from the automatic document feeder check the slit glass (the thin narrow glass beside the big platen glass) for debris, white out, dirt, etc... a small dot on that glass will make a line on the copy.
Aug 20, 2013 | Kyocera FS3140MFP AllInOne Laser Printer
Tip
Black lines on copiers!!
Hi!!
If you are making copies on a machine that has a ADF (automatic document feeder)on and your copies come out with black lines on them,but when you make copies from the glass there are no lines on the copies then the small glass on the left,has a mark on it!What i do is put the copy with the black line on,on the glass face up so you can see the line,now,more or less where the black line is on the copy,is where you can look on the thin strip of glass to the left,for a mark or thin line!!Clean it with a damp cloth and no more lines!!
Enjoy!!
on Jul 07, 2011 | Office Equipment & Supplies
3 thin black lines on copy
Do the black lines show up when you use the adf or if you make a copy from the copyboard glass. If the lines only show with the adf > there is a small **** of glass on the left side of the copy board glass > I would clean the slip glass with windex or a damp cloth..... Good Luck
Jun 08, 2010 | Canon imageRUNNER iR C2880 Color Copier
Copies leaves lines when put through the feeder,but not on the glass .......have cleaned and sprayed air can everywhere I can think of The Hp Printer is HP 3055 All in One printer
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | HP LaserJet 3055 All-In-One Printer
Getting a black strip in copy mode on X6575 lexmark printer. No line in print or test mode
Most likely a page was scanned with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
Mar 16, 2010 | Lexmark X6100 Flatbed Scanner
Line down the middle of copies
Clean the **** glass... usually a thin glass to the left.... check with a small flashlight, small blotch of ink or white-out can cause this... hope this helps.....
May 06, 2009 | Toshiba Office Equipment & Supplies
Line on copy
You have a small dot on your scanner glass. Lift the lid and check the thin piece of glass on the right side of the machine. The smallest piece on the glass will cause that. Clean if with some windex and a cloth and the problem will go away.
Jun 30, 2008 | Sharp AL 1631 Copier
Facing copying problem from scanning section
Although you didn't specify the scanner model, this solution should work.
If the scanner has a top feeder, open it.
You will see a thin strip of glass, either to the left, or right of the large scanner glass.
There is most likely a small spec of ink, white out, etc on it.
Clean the strip glass with rubbing alcohol and the line should go away.
Apr 09, 2008 | Office Equipment & Supplies
Black lines
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
Problem while copying
O.K. guys,
the problem is with the smaller glass on the left.
Lift the top and look at the small glass on the left, is there a dot, whiteout, dirt etc... on there? that is what's making your lines. clean with alcohol or mild cleanser.
Nov 07, 2007 | Kyocera RI-3530 Black and White Copier
265 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
