Question about Troy Garden
Have troy bilt riding lawn mower engine is not getting gas through carb. what is the solenoid thats attached to the carb?
  • 437 Answers
That is the fuel solenoid that allows gas to get into the carburetor when it starts up. The fuel solenoid opens up when the key is turned on to allow fuel into the main jet of the carburetor.
go to www.precisionope.com, you should be able to find an Illustrated parts list on the engine.
Posted on Sep 28, 2009
Troy bilt pony riding mower leaking gas from carburetor and now won't start
sounds as though it may be flooding. if that is the case the inlet needle valve will need removing and cleaning, and the carb cleaning out.
Sep 07, 2014 | Garden
How to replace fuel line on troy bilt tuff cut 230 lawn mower with B&S intek engine
The easiest why is to remove the carb, usually the gas inlet on the carb is between it and the engine, the other end is beneath the gas tank, once again it is easier if you take the tank off the mower.
Aug 01, 2014 | Briggs & Stratton Garden
Troy bilt pressure washer air filter is flooding with gas
rebuild the carb and check the mounting seals between the carb, air filter and engine. It's probably just gummed up & it's not stopping the gas from free flowing into your airbox.
Nov 09, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
I have a troybilt riding lawn mower that gas seems to be going into the oil..what could this mean
This is serious. Don't use the mower till it is fixed. Probably the carburetor has malfuntioned and may need to be removed, disassembled and possibly rebuilt. Major flooding is ocurring somehow either by the carb or a mechanical failure of the engine.
Aug 31, 2010 | Troy-Bilt® Briggs and Stratton Chipper
Troy Bilt lawn mower used months 2009 will not
stale gas in carburator...take the screw out of the bottom of the carb and let the gas run out...
Apr 17, 2010 | Garden
Troy-bilt bronco riding lawn mower choke problem
Check your air cleaner...then check fuel line from pump. Pull fuel line off carb make sure fuel is present. :)
Sep 07, 2009 | Garden
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
May 29, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
428 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
