Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP Director A friend would like to use HP Director but does not have an HP printer, is it possible to download this program from the internet? many thanks
May i know why he wants to download the hp director when other programs are available for same purpose.
Posted on Jan 04, 2008
Lost HP Dirctor Icons
Please confirm the version of Internet Explorer you are using If it is 8.0 or 7.0 then I would suggest you to please degrade the Internet Explorer version to 6.0 because HP Director is not compatible with IE 7.0 or 8.0. You can alos check for the scanning file and you can find it at
please click on Start button -> My Computer -> C: Drive -> Program files -> HP -> Digital Imaging -> Bin -> hpqscnvw.exe whe you will double click on this file, it will give you an interface to scan.
you can also click Start button -> all Programs -> HP -> HP Director (if it is there)
then right click on the HP Director and click Send to -> Desktop, it will create a shortcut on the desktop.
I hope it will work for you.
Dec 09, 2009 | HP PSC 1610 All-In-One InkJet Printer
My HP Officejet 6310 All-in-One gives me a no destination when I try to use the scan feature. Do I have to have a specific program on my computer?
Yes, go to HP support and place your model in the search box and download the program
HP Director...make sure if you have IE7 and 8 there is a special driver download for that model that allows HP director to properly work with Internet Explorer 7 and 8
Aug 26, 2009 | HP Officejet 6310 All-In-One InkJet...
Can't open Hp director
I read ur problem.This problem with HP director occurs if you are running Internet version (7.0).If u have difficulties knowing your Internet version, pls do the things mentioned below.
1.Open internet explorer->click help->then click on "about internet explorer".---There you will see the version of your browser.
SOLUTION.
If see an hour glass appearing and disappearing without displaying the HP director window after clicking on HP director, You got the following solutions.
Solution 1.
1.Double click HP director icon.
2.Then Press Alt + space key together.
Result:YOU will see a small pop menu appearing on the desktop screen.
3.Click on "minimize" on that pop up screen.
Result:Now u will see a tab on the taskbar.
4.Right click the tab(hp director),then click restore...Now you will see your HP director window.
Note: Above solution should be performed while trying to open HP director.(ie) You should try this every time if u want to open HP director.To go for full time resolution,then try solution 2.
SOLUTION 2:
1.Open "www.HP.com"
2.Select "software and driver downloads"
3.Type your product name in the "for product text box",then hit enter.{(eg) if u type 7410 for office 7410,then u have to select the exact model in the next window}
4.Select the operating system.(if u dont see a option to select operating sys, there u will see "software and driver downloads"
5.In the next page, you will see a list call "Updates" you have to download a update which says "
Critical update to resolve an issue with HP Director after installing Internet Explorer "
6.After downloading the update, run the file and thentry to open HP director it will open the director window.
This will work.I assure u total problem resolution
Regards
Chittaranjan
Dec 25, 2008 | HP Scanjet 3570 Flatbed Scanner
HP DIRECTOR SW DOWNLOAD
Here is a link for the full feature driver/software for XP. This includes all of the programs that came with the printer by default.
You will have links to Install Now which starts an online install. You also have an option of Download Only which will let you save the file to the hard drive for future installation. Each option also has step by step instructions below it.
Hope this helps. Please remember to rate this information.
Thanks
Nov 15, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Hp 6110 all in one hp director not working.
try to do the following:
1. Double-click the HP Director icon to load the program into the memory. You will not see HP Director open at this step. Do not click anything else on the screen until Step 2 is completed.
2. Press the Alt key and the Space bar together, and then
select Minimize from the menu that displays in the upper left corner of the window. If necessary, click it again until HP Director minimizes.
The HP Director software now appears as an item on the Task Bar .
3. Click HP Director on the Task Bar . The software opens and displays normally.
4. Repeat Steps 1 through 3 every time the HP Director software is used.
or
  1. Go to the HP Software Download Page .
  2. In the Enter a product number text box, type the printer model, and then press Enter .
  3. Under Product search results , select the printer model.
  4. Select the operating system.
  5. Under Update , click Critical update to resolve an issue with HP Director after installing Internet Explorer 7 .
  6. Follow the instructions that display on the screen to install the update.
Cause:
In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software, does not exhibit this issue with Internet Explorer 7.
Sep 02, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scan function on HP6110 all-in-one printer won't work
See this link on HP's web site for a possible solution:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-46104-1&lc=en&cc=us&dlc=en&product=79477&os=228&lang=en
Jun 26, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 1315
If the patch or the updates did not work on the link I sent you try this Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
  1. From desktop, double-click the HP Director icon to load the program into the memory. HP Director will not open at this step. Do not click anything else on the screen until Step 2 is completed.
  2. Press the Alt key and the Space bar together, and then select Minimize from the menu that appears at the upper left corner of the window. If necessary, click it again until HP Director minimizes. HP Director software displays as an item on the task bar (the row of open software programs that appears at the bottom of the desktop screen).
  3. Click HP Director on the task bar. The software opens and displays normally.
  4. Repeat Steps 1 through 3 every time you use HP Director.
    NOTE: The HP Director window might appear larger than normal, but the software is functional.
Cause In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software on products introduced after 2004, is compatible with Internet Explorer 7 and does not exhibit this issue.
Mar 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Scanner won't work
hi,dahaka,
I did, but can't find the "Hp director" .
(start, all programs, HP) in "Hp" don't have Hp director!) where can find it?
bhca
Nov 29, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
55 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
