Question about Refrigerators
Fridge and Freezer not cold
My fridge and freezer is not blowing cold. It sounds like the fan is still going, but nothing was freezing and everything is defrosting.
kenmore 52522101 manufactured 02 2002
  • 1 more comment
  • sunydayz Dec 19, 2007
    We unplugged the fridge and we think it is the relay overlay part due to other peoples posts with the same issue. Problem is the part isn't directly listed on sears website, the model number of the fridge doesnt have a parts list. Does anyone have a part number?
  • Anonymous Mar 19, 2008
    I have a Kenmore Model 106 - 20 cu. ft. refrig with an upper freezer made in 07/91. For some time the refrig sounds like it is taking off when it starts up and now the ice maker doesn't work and the freezer will not keep food frozen. The refrig portion still seems to do a pretty good job.
  • c21kims Dec 27, 2008
    I have the same problem. Did replacing te relay solve the problem? It is either the compressor (locked up) or the relay. Before I go buy one and try that, I wonder if anyone else has had the same problem.
  • 87 Answers
SOURCE: Water dripping from top of fridge (coil housing?) under freezer.
It could well just need defrosting. It does sound as though the coil in the freezer section is frozen. If you try defrosting it and the problem disappears then you have at least found a temporary solution. If it does rectify it I would closely monitor the cabinet for a couple of weeks to check for a reoccurrence. If it does reoccur then I would suggest contacting a fridge guy so that he can check the defrost circuit. The reason we normally suggest to defrost is incase a door was left ajar and the coil froze up because of this. I hope this is of some help and you seem to be on the right track.
Posted on Sep 11, 2007
fridgetech
  • 473 Answers
SOURCE: My kenmore refrigerator side by side
Sounds like it has a defrost problem.  Check for thick frost buildup on the back bottom panel in the freezer first and let me know what you find so I can steer you in the right direction.  Also, give me the entire model # from the sticker inside fridge.
Posted on Oct 18, 2007
SOURCE: Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Posted on Nov 25, 2007
22yooper
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
dididsaythat
  • 291 Answers
SOURCE: Freezer freezes but fridge does not get cool
DO u have frost build up in the freezer ? If so you have a defrost problem.. defrost thermostat, timmer or heaters. You can by-pass the thermostat cut it and tape the wire together and put it into defrost with the timmer by clicking it to the right until it clicks the heater you need to ohm out .. the defrost timmer will be good most of the time if it comes out of defrost ... ref. will start running again when u test the defrost thermostat here is a diagram that may help
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?diagramPageId=00011&componentDescription=AIR%20FLOW%20AND%20CONTROL%20PARTS&documentId=00016472&modelNumber=1068562782&productCategoryId=0160000&brandId=0582&modelName=REFRIGERATOR&backToLink=Return%20to%20Sub%20Components
Posted on Aug 24, 2008
Amana fridge is not cold but freezer is working
If freezer is ok and cooling ( 5 degrees or less) one thing you might want to check is that the flow of cold air to refrigerator is not obstructed by the items in your freezer. The ductwork has to be available. Also check the opening of the damper if fridge is not cold enough. And is the fan operating at full speed - are the bearings dirty and slowing it down?
Also check your freezer temp - there are degrees of freezing. Water freezes at 32 degrees but a good freezer should go down to about zero. And the colder your freezer air is the colder your fridge will be.
Sep 21, 2017 | Refrigerators
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
My freezer seemed to have quit so I cleaned it out made sure the air flow was good and de-iced everything. Now the bottom of the freezer freezes but the top does not nor does the ice maker work. What do...
open the freezer door,do you hear the fan blowing around?it sounds like the evap fan motor isn't running and that's why it's cold on the bottom and not the top,you have to repair this fast or you'll loose your food in the fridge,the fan is what blows the cold air from the freezer to the fridge section.
May 07, 2011 | Amana ARS266ZBS Side by Side Refrigerator
The freezer is COLD..freezes solid. Setting at low. The frige part is not cold and is set at high. Seems everything is going up to the freezer. Unit is just over 1 year old. Drinks are cool but not...
where is the freezer on top,side by side or the bottom.all a fridge does is blow cold air from the freezer to the fridge side that's it,if the fridge is warm there's a problem most likely in the freezer,a plugged drain or when you open the freezer door do you hear the fan blowing,if not you have a bad evap fan motor,also check your warranty it still might be covered.send the model number and i can help you,if you see water under the bottom draws or in the fridge section if the freezer is on top you have a blocked drain in the freezer.let me know what you find and i can help you
Feb 20, 2011 | Magic Chef Refrigerators
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My dometic refrig is freezing everything what is the problem? the freezer part works great but also freezes the the bottom frig part also-
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 18, 2009 | Refrigerators
Whirlpool bottom freezer 5 years old everything freezes in the fridge
Oct 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Maytag fridge which freezes food in fridge compartment
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Maytag MFI2569VE Bottom Freezer French...
Problem with everything freezing inside icebox no matter where the control is set.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 01, 2009 | Refrigerators
GE GSS25LGMF BB refrigerator freezing everything. Refrigerator is set on 1, still freezing.
Jul 01, 2009 | GE GSS25LGM Side by Side Refrigerator
Refrigerators Logo
187 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
