Question about Cameras
Red line on side of photo - Cameras
Have a canon clc 1110 and its leavening a red line in the left side of paper See photo attached
DECOTILE, PRINTER HEADS MAY NEED CLEANED, CALL CANON FROM YOUR MANUEL GET PHONE NUMBER CUSTOMER SUPPORT THANKS,,ALSO LOOK IN MANUEL FOR CLEANNING HEADS?
Jan 24, 2016 | Canon Office Equipment & Supplies
Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 26, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Projection lights don't line up
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Epson 1280 red lines on photo
Suggestion:   Open up the "hood". All the way on the right side of the top of the plastic case, you'll see a large switch.   Switch it up from "0" to "1".  This will give the paper a little more room and might help.
Jul 27, 2008 | Epson Stylus Photo 1280 InkJet Printer
Pink lines when I print on proper Canon photo paper
i'd say your print engine is quite out of sync...you had this canon for a while?
Mar 18, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Red/White Lines On Photos and LCD
HI,
The scren is just displaying the input from the CCD (Digital Sensor that actually takes the picture).. If The pictures were fine, but the screen was funky if you could live with it then there wouldn't be a problem.
Since it's on both the screen AND on your photos it points to there being a fault with the CCD
Given the age of the camera, the cost of a repair I'm afraid it's time for a new camera. there's nothing you can do to fix this yourself.
Sorry for being the bearer of bad tidings.
If my advice was at least helpful please vote for me!
Nov 19, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Mutiple lines on right side of photo
try removing the ink cartrage and clean the heads in the printer with a quetip and rubbing alcohol. same with the cartrages.
Nov 12, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
One of the best possible solution that we can suggest is to run a cleaning cycle for three times. Just to make sure that cleaning is effective please try the step below:
1. Using your computer go to printer utility.
2. Click on Maintenance then select Head Cleaning. Head cleaning usually took 1 minute.
3. Once the Head Cleaning is done Print a nozzle pattern to check whether the head cleaning is effective or not.
Repeat those steps for 3 times. If the nozzle pattern after 3 cleaning cycles still bad. Reseat ink cartridge if possible replace the ink cartridges.
After all those steps and issue still present printer needs to be in service.
Aug 05, 2006 | Epson Stylus Photo 1280 InkJet Printer
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
