Question about Toshiba 50H72 50" Rear Projection Television
Tv problem when l shut tv off, and turn it back on it flickers like crazy for 5 to 10 mins , then slows down to a flicker, once every 5 seconds . picture is good but the flickering is not
  • Greg H Jan 26, 2008
    Same problem, the flicker is on the right side and a constant wave on the top 3rd of the screen,
I just serviced this model, same problem as noted. I did a resolder job on the power/drive PC board. This was NOT the problem! The problem acts like an electrolytic capacitor issue or horizontal drive amp. Once I get my hands a service manual & schematics, we'll resolve it. I'll post my results AFTER Super Bowl.
Rick Macy
BC Electronics
Posted on Feb 02, 2008
Sony pfm-42x1 flickering screen when turning tv on
OKAY I found the Problem!! Bad Caps Compositors. I Proved this in 2 ways. First I took off the Back(always make sure the TV is UNPLUG) In the photo above I put my finger on the capacitors. I found some that where NOT FLAT ON TOP(You can kinda see in the photo too). I could feel a little nipple on top.(Some times you can see if their busted open but not in this case) so I felt them and the bottom right and top left area in red in the photo where not flat. I took my dryer(My wife really) and warmed them up for about 2 minuets each then another minuet rotating back then forth. I leaned the t.v. up to lean on the frame and plug it in. I continued warming the capacitors up and in about 2 Min the T.V. has stop blinking. Much better then the 20-30 min. So the hunt for the Capacitors is on. It will be some work to get the boards out. If everything is done delicately The Soldor job is easy for me. I am going to buy the 8 but replace 1 board at a time until the TV works and put the other on the side for next time or put them up on E-bay. I hope this helped Please like if this helped you. ea0a96a3-fb82-4ec0-89f4-76b4080e9c6e.jpg 1b190ebd-5d69-4553-a009-840d29ab4c87.jpg ab9b51d0-6e1d-4cce-b822-e80d0fde9163.jpg
Oct 13, 2013 | Sony PFM-42X1 Plasma TV
My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Aug 23, 2009 | Televison & Video
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Aug 11, 2008 | Samsung HLN467W 46" Rear Projection HDTV
KP51ws500 turns green and shuts itslelf off
There may be several causes but, one is that when any color gun is being over driven, the Sony shuts down the gun to protect it. Try this. Remove the front of the set by removing the two screws from each lower corner. Next remove the black panel held on by 5 or 6 screws. Now you should see a panel with 6 potentiometers on it. Turning the ones on the bottom row CCW reduces the drive. Turn the color down and if all the guns stay lit, SLOWLY turn them up until you get the color balance that you like.
May 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Ok...this sounds crazy but it happened to one of my PSPs. I updated the firmware on my system and the menu started stalling and taking a long time to respond. I shut the PSP all the way down....holding the power button until the light shuts off (about 4 or 5 seconds)...Hold the R button and power the system on again (you should be in recovery mode)...go to CPU speed and make sure it is either set at "Default" or "222"....I belive 222 is the default setting....also make sure the UMD is also set at "Default" or 222....if you're going to use the UMD.
Feb 06, 2008 | Sony PlayStation Portable (PSP) Console
Flickers on cold startup after 5 min then goes away in 2-3 min.
I had same problem. Tech's said the power was noisy. I cleaned up the power but the TV still did exactly as you describe. Problem will progressively get worse with longer bouts of flickering. I was under warrenty and sent the TV back. After 3 months I am still waiting for a repalcement.
Jan 12, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Toshiba 50H72 50" Rear Projection Television Logo
118 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
