Question about Cyberhome CH-DVD 300 DVD Player
How to hook up cables. I think I Have It Right But I Get Two Images On Tv Screen In Black And White
What are you hooking up? what kind of cables are u using?? Your cables should be connected from the output (video and audio) of the disc player and into the input of your TV.. usually are color coded if using rca's or monster cables..hdmi is a lot easier! hope that helps.. verify!
Posted on Sep 28, 2009
Sharp LC-55LE643U - bottom 3/4 of my LCD TV is shadowed and purplish. How do I fix it?
Try a reset but unfortunately I believe it is a board cratered by the power outage. Try to get things shut down when the power goes
Feb 28, 2017 | Sharp Televison & Video
LG 55LM4600-UC LED TV I have was squirted with a squirt gun. Would replacing the t-con board fix this tv? Please read further details.
when water shorts out something it overloads a lot of other components so the best advice is to take it in for a proper diagnosis.
you just replace a board but another board is damaged it might just blow the board you replaced and that would prove nothing
Jan 09, 2017 | LG Televison & Video
I hooked up my cable box up to my sceptre tv and it had sounds but the picture is black and white I even went and bought the blue and green cords but still only black and white
With the blue/green/red cords (Component) you need to get a very good bright light on the connectors so you get the plugged into the correct COMPONENT connectors on the TV. Note, there are white and red AUDIO plugs right near the COMPONENT input so you need to be VERY careful. If you get it wrong, the colors on screen are often off and even black&white.
How is your cable box connected to the TV? Screw on "COAXIAL", Yellow, Red, White "RCA", single flat connector "HDMI" or 5 colored plugs 2 X Red, 1 X White, 1 X Blue, 1 X Green "COMPONENT"
Jan 08, 2014 | Televison & Video
My nintendo wi system when i turn it on the home screen is in black and white and fuzzy what is wrong
Well I think that it might be the av cables that are causing it to be in black,gray and white then. Or the tv might be having an issue with the rca jacks on the tv where you hook up the av cables or it could be the aux or video 1 2 or 3 that is not working so try another video or aux number too see if it will make a difference.
Jan 06, 2014 | Nintendo Super NES Console
Hooked up ps3 using hmdi cable worked not working now using the
mpc heesman1 might be right...
However. I´m inclined to think that you did change the input on your TV. So your problem is another, this is what you have to to to reset:
1. Unplug the HDMI cable from both the TV and PS3.
2. Plug in the AV MULTI OUT cable (the red, white, yellow one provided along with the system) to both your PS3 and TV.
3. Set the TV input to the correct one and turn it on.
4. turn on the PS3 with the front button but DON´T release it, keep your finger on it, until you hear a second beep, thats when you release the button, the PS3 will start to identify what it´s connected to and will display it on your TV.
Hope it helps.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
I have the tv only hooked up to a dvd player, picture only comes in black and white, i am hooked up with componant cable and audio cables
Check to make suer you ae not on progressive scan as that will display the images in a black and white format. Also check your system settings and make sure they are correct, NTSC, PAL, SECAM, etc. i hope this helps. Good Luck.
Nov 23, 2009 | Syntax Olevia 226T 26 in. LCD Television
Cable on TV suddenly went to black & white (and a bit fuzzy)(some channels show faint colour). Was fine, nothing was changed, one day was suddenly B&W. TV screen is not the problem, all other cable...
Was playing around with the TV's menu and changed the Tuning Band from "HRC cable" to "IRC cable". Suddenly I have colour again. No one had adjusted any of the controls, so still not sure why one day it was fine and the next day it had gone to black and white, but changing the Tuning Band fixed the colour problem for me.
Sep 13, 2009 | Televison & Video
Mitsubishi big screen
check the cable for the cable box
make sure the the white and black cable is in right
hit; black is in out white is in
Sep 13, 2008 | Sony KV-32S26 32" TV
I'm not getting any color pictures in my home theater system
Well, assuming were talking about a dvd player with dvd's,you dont specify what type of cables you are using to conect it to your tv, it appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Thanks...
May 23, 2008 | Audio Players & Recorders
DVD Plays in Black and White
Depending what cables you have, try plugging only the yellow cable into "video out", I previously had red, white, and yellow cables plugged into "comopents out" and only got black and white. Doing only the yellow into video out gave me color.
Jun 17, 2006 | Sony DVP-NS700P DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
81 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Henry  Thomas
Henry Thomas
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
