Question about Food Mixers
H600 Hobart mixer Machine does not run sometimes after it gets hot from mixing a batch of dough. Sometimes it will turn on and not stay running if machine is warm from use
  • 110 Answers
Sounds like you are overloading mixer.cut back on batch size
Posted on Jan 09, 2010
What can you use for a hobart h600
The Hobart H600 is a 2 horse power, 60 quart mixer, it can be used for many things in the kitchen. It can be used to make about any kind of food that needs mixed, wiped or kneaded. It works well in a pizzeria for all facets of making pizza from the dough, to shredding the cheese with an attachment, to a restaurant that makes mashed potatoes and fresh bread, to a full service bakery.
However, the biggest thing that you need to know is the capacity of the machine. As overloading the machine can cause damage that may be costly and take a technician to fix. I do not know what attachments you currently have so I will go over a few of them.
The main attachments are a Wire whip, Flat beater, and Dough hook. There are three different types a "D" wire whip (has many wires and is evenly spaced) this is used to whip egg whites, whipping whip cream, etc. The "C Wing" (has six tines in it) is used for items that are heavy for the D wire whip, like whipping potatoes or icing. The last is the "I" whip is similar to the D wire whip just with less tines. The flat beater is used to mashing or mixing examples are mashed potatoes before they are whipped, cake mixes that do not require whipping, batters and icing. The Dough hook is used for kneading dough examples are pizza dough, bread dough, etc.
The biggest thing when using your mixer is to know its capacity for the material that you are mixing. All though this is one of the bigger machines it still has limits. You should refer to this the following link for the capacity of your machine:
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F-7701.pdf
There are also a few attachments that can be put on to the No. 12 attachment hub. A few of these are a vegetable slicer-grater and meat grinder.
Mar 04, 2011 | Hobart H600 Stand Mixer
I bought a used Hobart A200 20 quart stand mixer that hesitates or 'gets stuck' when mixing dough or other thick (hard to mix) material. When running without a load, or only a light load it doesn't stick...
First of all, I want to say that it is common for people to overload the A200 mixer when mixing dough. The owner's manual gives an extensive chart for various substances typical of what people may mix. Depending on the consistency of the dough, the maximum batch size varies, but as an example: 9 lbs. max with 40% absorption ratio thin pizza dough, 1st gear only, 5 minutes maximum mix time. I remember this particular batch size/specification because as a technician who works on these mixers frequently, I had a customer attempting to mix 20+ lbs. of that 40% pizza dough for much more than 5 minutes and didn't understand why the mixer would stall and why his mixer was so hot he could nearly cook eggs on it's transmission case. So, a word of caution (9 lbs. at 40% A.R. is approx. 7 lbs. flour, plus the water) about overloading these. If used to mix reasonable batches, they are excellent mixers and will last a lifetime (I regularly service 40-50 year old A200 model mixers that run very well).
If you don't hear any grinding when it's stalled (which would indicated stripped gears, damaged keys, etc. in the transmission) I would say you are overloading it. Many people want to say the motor is weak when the mixer stalls, but unless the motor has been repeatedly and severely overheated to the point of shorting some of the motor's windings, that's not the case. I suggest finding the recommended capacity chart from Hobart and abiding by it and you'll love your new mixer for years.
Jan 04, 2011 | Hobart A200 Stand Mixer
Hobart A-200 mixer gets hot and weak. Motor housing gets too hot to keep your hand on it. Service tech told me the motors usually don't go out. What other problem could it be?
I'd say you're most likely overloading the mixer. This mixer, and others similar in size, are frequently overloaded by people making pizza dough. If you are making dough, keep in mind the A-200's capacity is 9 lb. of 40% A.R. pizza dough, mixed for 5 minutes maximum. If you need to mix longer, the batch must be cut down even smaller, but I don't even know if you're mixing dough.
Try running the mixer unloaded (i.e. nothing in the bowl) for ten minutes or more and see if it gets hot. If it still gets hot, the motor's start circuit (varies depending upon age of the A-200; Hobart used numerous motors in the A-200 over the years, incorporating different starting circuits) most likely has problems. If it doesn't get hot when operating unloaded, then you're probably overheating the mixer by overloading it.
Dec 20, 2010 | Hobart A200 Stand Mixer
Can you use a spiral dough hook when the mkixer runs in reverse?
You can but the dough would ride down towards the bowl instead of up and your mix would not turn out properly.What kind of mixer do you have?i'm a hobart tech and repair these mixers often.Let me know.
Nov 04, 2009 | Hobart H600 Stand Mixer
Got a hobart mixer model h600-t cutting off and kicking breaker,it runs sometimes for about 5 min. when the ladys are mixing bread,checked amps,not under a load
If you can access the brushes you may want to inspect them. If anything but the carbon brush is touchiing thhe armature. It with trip a breaker.. Unplug it before accessing the brushes < -- my disclaimer :)
Oct 27, 2009 | Hobart H600 Stand Mixer
Hobart A-200 mixer (OLD!) runs hot & shuts down.
You have killed it by overloading the bowl. Hobart recomends no more than 65% bowl capacity on doughs & 75% on batters or icings. Replace the motor or the whole unit
May 25, 2009 | Hobart A200 Stand Mixer
Motor stalls out when mixing you unplug and plug back in and it will run had the motor checked out and was fine
You are overloading the bowl or you bought this used and when they wore the motor out, you ended up with it. Batters & icings 75% bowl capacity, doughs 65% bowl capacity. If you live by this, you will buy 1 mixer & never have to replace it, especially if it's a Hobart.
May 01, 2009 | Food Mixers
Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Mar 06, 2009 | Hobart H600 Stand Mixer
Hobart a200 mixer won't mix
The bowl holds 20 quarts--are you overloading the mix?This mixer is not made for medium/heavy pizza dough.Depending on the pounds of dough,water and other ingredients will affect the mixer in some way.
Nov 09, 2008 | Hobart A200 Stand Mixer
Dough Hook Stops moveing under heavy load
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
Feb 21, 2008 | Hobart H600 Stand Mixer
Food Mixers Logo
70 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
