Question about Canon PowerShot A570 IS Digital Camera
Screen blackness I have the same problem. The lens is NOT stuck - it does deploy and the lens cover opens. I have replaced the batteries, tried a differant memory stick, and I turn it on and off to reboot. None of these solutions work. The camera is only a year or so old - it doesn't get a lot of use so it is not mishandled. Does anybody have any suggestions?
dbarchitect
  • 150 Answers
SOURCE: Lens stuck out
The lens probably has some dirt or grime stuck in the lens motor. If you can gently twist the lens back and forth, maybe with some air.
I have answered this in another post. Here is the link.
If this helps you, please return and choose FixYa! ThankYa!
Posted on Dec 04, 2007
t00nz
  • 4738 Answers
SOURCE: Canon SD900
First off, see if Canon can help you. If not, the following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 28, 2007
SOURCE: Canon IXY Digital 800 IS
TRY THIS! Had the exact same problem/error message. I had purchased a second Li-ion battery a while back and put the new one in as a lark. It fixed the problem. It's a cheap possible fix worth trying.
Posted on Oct 28, 2008
SOURCE: "Lens error - restart camera" message, but won't restart
I just had the same issue when one of my children drop the camera. I'm not wanting to break anyone's camera but I was able to open the lens cover and pull the lens out and then turning it on it retracted and worked just like it should.
Posted on Apr 20, 2009
t00nz
  • 4738 Answers
SOURCE: My Canon PowerShot SD1000 shoots completely black
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Nov 07, 2009
"Lens error, restart camera"
change the lens cover and change the battery please vote
Nov 04, 2009 | Canon PowerShot A1100 IS Digital Camera
My screen is black or blank
I think you mean your automatic lens cover opens. A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Feb 23, 2009 | Nikon COOLPIX L18 Digital Camera
My lens is stuck!
Sometimes this can happen if the battery cover was accidentally opened while the lens was moving. Try something simple. Turn the camera off. Open the battery cover and remove the batteries for 5 minutes. replace the batteries and secure the cover. Turn on the camera. The lens should go to it's home position. Let me know if this helps. And thanks for coming to FixYa. Don't forget to rate my answer!
Rob
Feb 08, 2009 | Polaroid T831 Digital Camera
Lens won't deploy
The problem you are describing is a problem with the sensor behind the lens cover door. It seems to have failed and needs to be replaced.
Olympus will charge a flat rate repair fee for this product. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Dec 26, 2008 | Olympus Stylus 410 / ? 410 Digital Camera
Olympus Mju mini - lens cover will not open
check out first if the battery is fully charged.and if the battery is very old.then prefer replacing the battery instead of charging.and if the battery is new,then the cover of the lens must be getting stuck up so try tapping the device from all the sides it will automatically get opened.also off the camera completely and try to move the lens door manually up and down.sometimes the gear assembly gets stucked and this makes it free to  move.
Nov 29, 2008 | Cameras
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
Polaroid i735 Camera won't turn on. Lens stuck.
I had the same problem, and fixed it by wiggling the lens a little, when turning it on.
After a few tries, it finally wiggled free, and the lens retracted.
Jul 05, 2008 | Polaroid I533P Digital Camera
Lens problems
Try opening your camera, check the lens gear if its teeth are complete. If so, check if something stucks on it. Its much better to bring your camera to an authorized service center to re timing your lens track... ^_^
Jan 16, 2008 | Canon PowerShot A530 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Lense Cover Stuck
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and be aware this will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 01, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot A570 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
