Question about HP Officejet 5610 All-In-One InkJet Printer
HP office 5600 series - printing problem
Keeps saying refer to device documentation to trouble shoot. Shuting off and on does not help and no other key works on this all in one machine. Pl. help.
Sesha
  • 1 more comment
  • noexperthere Dec 20, 2007
    Have a cartridge error with a HP 5610 all-in-one. Says to refer to device documentation. Nothing seems to work in fixing the problem. Please help.
  • Anonymous Jan 30, 2009
    my 5610 HP printer has message, "cartridge error" refer to troubleshooting manuel. I've tried to post this buy can't get by the "put in these letters and numbers" Please help
    Zan Stark
    zanstark@gmail.com
  • atronish Mar 05, 2009
    it keeps mess.age of cartridge error refer to device documentation to troubleshoot, I disconnectd the power holding the #key and 6; the same strategy holding # and 3 and both 3and 6 #, nothing happened. Also install new cartridge and clean the contacts in the printer and still not working; dosn't allow to be set back to factory default. I will appreciate any help
    Novelist:
  • 57 Answers
Make sure you are using genuine HP cartridges and are the compatible cartridges. Check for the dates on the printer cartridges which should not exceed the date printed on the print cartridges as they might be expired.
Do not use refilled or remanufactured cartridges which might be the cause of the issue and may damage the printer hardware functionality.
However, follow the below given instructions to resolve the issue.
Clean the cartridge contacts by following the below given instructions:
Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts. The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Clean the cartridges from the printer front panel.
Press Setup on the Printer front panel >> Tools >> Clean Print cartridges.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Hope, this should resolve the issue.
Regards,
Lawrence
Posted on Jan 06, 2008
  • 30 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
752
Posted on Feb 27, 2009
I tried Lawrence's solution, but then I still got a message that the left (colored) ink cartridge was low. (I didn't think that should affect b&w photocopies.) At any rate, between holding # and 6 while plugging it in again, and changing the color cartridge, it's up and running again.
Thanks, Lawrence... where do you come up with these manufacturer's codes that they don't give in a manual?
Posted on Mar 21, 2008
Wont print copies it said documentation trouble shooting cartridges
Hi, first if you have just fitted them, open it up again and double check that they are properly inserted..
Dec 21, 2014 | HP Officejet 4500 All-in-One -...
When I click TO PRINT Document the following
First thing you need to do is remove the device from the device manager. Uninstall the printer, then reboot the computer and you use that first CD that you listed.
Aug 05, 2017 | HP OfficeJet 4255 All-In-One InkJet...
I have a print cartidge problem. tri color. it says to refer to device documentation to trouble shoot. i don't have the device documentation what do i do? its not indicating no ink- it just stopped working...
follow the steps in the below link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01887242&cc=us&lc=en&dlc=en&product=3645100
if you want a manual you can download it from this link
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=3645100&lc=en&cc=us&dlc=en&lang=en&cc=us
Jan 25, 2010 | HP OfficeJet J4580 All-In-One Laser...
Cartridge error, refer to device documentation for troubleshoot
show me a massage Cartridge error, refer to device documentation for troubleshoot printer model hp officejet 5610 all -in- one what is the problem and how do i solve thnk you
May 22, 2009 | HP Officejet 4315 All-in-One Printer
No scan options say refer to device documention to trouble shoot
Try ths:
This happens mainly when you try to scan from the printer ;
Always try to scan from HP solution center but still here is the resolution:
Open Hp Solution center
Click on Settings
Click on scn settings
click on Scan to Setup
Select all the option available to updrade the Front panel menu list and click on ADD
Click on Update;
Restart the computer and the printer and try to scan.
It should resolve the issue.
Regards Soumajit
Mar 02, 2009 | HP Officejet 4315 All-in-One Printer
New Hp Officejet 5610 All-in-one - Printing?
You may have a couple of problems. First, you say you have more than one icon in your Printers dialog box for 5600 series printers. My guess is that you installed two different drivers, one for the 5600 and one for the 5610.
Try deleting the 5600 printer icon and making the 5610 the default printer. Run the test print again to verify it works, then open a Word document and see if you can print that.
This brings me to the second issue; what exactly are you trying to print? The issue in this case, may not be the printer but an issue with the document. Some documents have a security feature that prevents printing. Try different documents (Word, Excel, etc...) and see if the problem is across the board. Post the results here.
Thanks.
Sep 23, 2008 | HP Officejet 5610 All-In-One InkJet...
Scanning
go here
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00503569&cc=us&lc=en&dlc=en&product=441240&dlc=en&lang=en
Dec 17, 2007 | HP Photosmart 2575 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
1,578 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
