Model 1104272220 a necklace fell into the machine and i want to remove the agitator
  • 6,784 Answers
Hi. The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly, which is removable as well. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to preform a combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytag's may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Posted on Sep 28, 2009
I think my necklace fell thru the holes of my Kenmore 70 series washing machine. How can I check if it is under the drum.
The link to the video will show how to gain access to the inside of the washing machine. I did not create the video.
Follow the safety guidelines in this video and those that came with your machine. This may well be a two-person project, especially if the machine is installed in tight quarters.
  • Take your time.
  • Be safe.
  • Use the proper tools.
  • Do not get frustrated and break any of the parts, after all, you want the machine to function again after you find your necklace.
Take pictures of screws, brackets, covers, etc. before you remove them to make reassembly easier.
You may be able to see your necklace and remove it without disassembling the washer as fully as described in this video. To be prepared for that have the following on hand:
  1. flashlight
  2. GrabEasy Grabber and Retriever PF0401 The Home Depot
    (I have a similar tool and use it frequently)
Whirlpool Kenmore Top Load Washer Disassembly Washing Machine Repair Help
Dec 16, 2015 | Kenmore Washing Machines
Have a kichen aid model kaws777e need to remove agitator -need to lookunder for lost necklace.
Can you give me more details on your problem so that i can help you fix it.
Waiting for your reply.
Apr 12, 2008 | Washing Machines
In the cup holder by the brake, it has a hole in it and my necklace fell through, need to remove console so I can my necklace.
you can also get a small telescoping magnet from the autoparts store and stick in hole wiggle around and possibly get it that way as well.
Apr 03, 2011 | Pontiac Grand Am Cars & Trucks
I have a necklace chain stuck between the washplate and the basket, how do i remove the washplate?
Remove the fabric softener on top of agitator and plastic insert. Use socket wrench to remove hex bolt and lift top half and then bottom half of agitator which should then expose chain.
Feb 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
/There is a gold chain necklace wedged under the agitator. How do I loosen the agitator so it will lift up just an inch or so?
remove center downy cap on top of agitator get a 7/16 socket and long extension and hold base of agitator and loosen screw in center of agitator pull up agitator out of washer...
Jan 27, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Necklace caught under the agitator
In the center of the sgitator, there is a bolt.
Sometimes there is a plug to remove by prying out.
Remove this bolt.... or just loosen it, and the necklace will come free.
See item 2 in the expanded view on the left side.
Thank you for using FixYa - A FixYa rating is appreciated!!
Jan 26, 2009 | KitchenAid KAWS750L Top Load Washer
Don't remember how to remove the agitator
withte palm of your hand youllneed to remove the fabric softener dispensor(a solid bump) will dislodge it, after that youlll gain acess to the center shaft of agitaotr, remove small white cover and underr youll see a 7/16 bolt head, remove the bolt and the agitaotr will pulll right up and then reinstall the same way
Jan 06, 2009 | KitchenAid KAWS850L Top Load Washer
Necklace stuck in washer
Hold the bottom part of the Agitator,(The part that you are talking about),Undo the very top part in an anti-clockwise direction and it will come right off.Use a wrench to remove the nut on the top of the agitator and then lift it right out,you may need to move it from right to left.You will now be able to remove the necklace.Replace the Agitator the reverse of removal.
DW
Oct 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Necklace wrapped around bottom of agitator
1. Pry off protective cap with knife or small screw driver.
2. Remove agitator bolt
3. Lift off agitator
4. Retrieve Necklace
Regards;
reg501
The FixYa team
Jun 23, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
