Samsung led tv will not come out of power management mode the white led at the front centre just flashes away, if i leave the tv off for 30 mins i can get the tv on but after another 5 mins the sound goes off and then the tv switches itself back off so back to square one with a flashing led help?? samsung ue46b 7020 led tv
Sorry... this is not a solution, but I wanted to speak directly to you and didn't know how else to communicate with you!! OMG!! My t.v. does the exact same thing!! The power issue and the sound going out after it has been on for a while!! Have you called Samsung yet? I hear they have horrible customer service. Maybe if we get enough people with the same problem we can get something done about it!!
Posted on Sep 30, 2009
My Samsung LED has a flashing blinking light on the front. When I power on, it does not go into standby mode. It just turns solid red for a few seconds and then starts blinking. No image on screen. Is it...
I'm guessing you meant to say 'power off''. Otherwise it sounds like you have reasonably guessed there may be an electronic malfunction -- but with this, as with any device with a 'chip', I'd suggest first literally 'pulling the plug,' or if it's surge protected powering that down. Give it 30 seconds or so, then power back up. Best of luck!
Feb 25, 2015 | Samsung UN32D4000 UN32D4000NDXZA 32 inches...
Get rid of banners on Samsung HD TV
if its burn in,try the white feature,or record a white background buen to dvd and play for 30 min with brite and contrast turn up 3/4 up
Oct 10, 2014 | Samsung Televison & Video
60" sharp aquos power indicator is flashing one short flash and one long flash and keeps repeating the sequence
POWER LIGHT FLASHES ONE SHORT AND ONE LONG FLASH.
What is the problem? THE PROBLEM IS THAT ONE OF THE LED's STRIPS IS BAD!
SHARP AQUOS LC60LE810UN RESET INSTRUCTIONS
1)Plug in TV to electric current First then wait until LED start flashing.
2)Press Volume DOWN [ - ] HOLD BUTTON.
3)Press Channel UP [ ^ ] HOLD BUTTON.
4)Press Power [ (') ] HOLD ALL three buttons until LED stops flashing and then release.
    ┬ĚThis will reset the TV in order to fix the problem.
    ┬ĚTHE FIX IS TO REPLACE ONE OF THE LED's. You need to open the back of the TV and you will also need to remove the front cover and panel to get to the LEDs. The TV will need to be placed facedown and on the backside. This is a 2 person job to turn the TV on its sides. Be careful with the white computer connectors (wide white strip) at the base of the TV where the TV stand sits. You will need to disconnect this in order to get to the LED's.
    Once you have the LED's exposed, you will need to unplug one by one by placing the new strip next to it until the unit turns on. You will have to use the RESET procedure above if the Power lite flashes. The Power lite MUST BE ON SOLID - no blinking in order to test the strips. The LED's will flash, but still one of them will be burned. Even if you stare and all the strip light-up, you will still need to check one-by-one!
    Once the TV lights up, your face will also light up with joy! Put everything back together and you are set. If you need the complete instructions which come from Sharp as to how to disassemble the unit, please send me an e-mail to LGTR61@YAHOO.ES. Please note I don't check this address daily, so a few days wait may take for you to receive the instructions.
    Where can you buy the LED's - try searching Yahoo.com or Google.com for resellers.
    SHARP AQUOS LC60LE810UN LCD STRIP INFORMATION
    LONG STRIP (49 LED's)
    FRONT SIDE BACK SIDE RL 94v-0
    E329419
    1029
    LFa
    Sn-Ag-Cu
    Ps-1
    K4458TP
    4458ZZ
    0921FM
    104863
    ee03A
    SHORT STRIP (30 LED's)
    RL 94v-0
    E329419
    1025 LFa
    Sn-Ag-Cu
    Ps-1
    K4459TP
    4459ZZ
    0714FM
    302213
    Mm05A
Apr 10, 2013 | Sharp LC60LE810UN 60 in. LCD TV
How to reset LC60LE810UN
How to perform a cold hard rest on the Sharp LC-60LE810UN TV? It won't power on and just blinks.
Apr 14, 2012 | Sharp LC60LE810UN 60 in. LCD TV
Ln55c650 keeps flashing bright to dim very fast after about 30 minutes of being on if i shut it off for a few minutes it goes away til about 30 minutes the picture never goes away just gets bright and dim...
I had the same issue occur on my ln55c650 (screen flickering, not the actual image but the front lights flashed which was too distracting) and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Jul 22, 2011 | Samsung LN55C650 TV
When turning on TV Samsung 52 , 3 years old it starts clicking on/off for about 30 min. It looks like trying to start but cannot. The base line (blue) goes on/off , the screen is black, no sound, but...
This is common problems for LCD tv,most likely because bad components parts call capacitors on the tv power supply board.That the board,where the power a/c cord plug into it.U have tools like a soldering iron,desoldering pump or roll of desoldering braid also can do basic soldering and understanding basic electronic?Take the tv aparts.Yes,check all over the power supply board for capacitors parts are bulging up or puffing up.By replacing all these dying capacitors components parts,will help ur tv LED power light stop blinking and the tv will work right away.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Feb 03, 2011 | Samsung LNT5265F 52 in. LCD HDTV
MY SAMSUNG HLR5067WAXXAA PROJECTION TV JUST
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
Oct 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Rca model D52W20BYX1 comes on for a moment then goes off rite away
rca model d52w20byx1 itc222. sounds like shutdown mode. Does the led flash. unplug the set leave set unplug for 30 min. this reset procesor. now i tell you this in the shop its never that simple but it first step. IF you have a flashing led when you push power button. it tells you alot. it tells you main fuse is good the processor is getting power and it detects something wrong. leading causes are shorted horzontal output transistor. shorted cp150 capacitor. technicians have a computer that read error codes much like that of a car. let me know if i can help troubleshoot it down.
Nov 23, 2008 | Televison & Video
Philips 42PF7220A/37 April 2006. Chassis Number BP2.3U
Most likely the YSCAN UPPER board and/or YSCAN LOWER Board also gone. Your new YSUS board may damage again if you don't replace the bad YSCAN boards. Try to replace the three boards together and then to verify which boards are bad one by one. Good luck.
Aug 03, 2008 | Philips 42PF7220A 42 in. Plasma Television
TV will not turn on model aquos LC-46X20 Went away for a long weekend, did not turn power off left TV on stand by. Came back and power LED on front of TV is flashing and will not show any form of piture...
hello. here is something you can try , unplug the set and let it set. for about 10 mins. then plug it back and try tpo turn it on. hope this help's you. let me know "GOOD LUCK"
Jul 27, 2008 | Sharp Televison & Video
Televison & Video Logo
631 people viewed this question
Top Televison & Video Experts
