Question about Breville Coffee Makers & Espresso Machines
Breville Cafe roma milk does not foam - Breville Coffee Makers & Espresso Machines
You need practice !
Rules of thumb :
1 - Use COLD MILK, did you ever try to make whipped cream with warm cream ? It's the same.
2 - Use a COLD RECIPIENT to put your milk in.
3 - Foam your milk AT LAST, extract your expresso before, so if you do a not so good foam it doesn't have time to deflate.
4 - If you put any condiment on the foam, it will drop fast, like nutmeg, cocoa or cinamon.
Technique :
a. Put whole milk in a cold stainless steel recipient.
b. Start the machine and let it go for couple of seconds, just to let the first dropplet of water to spat out. When you have a clean and steady jet of steam, it's ready.
c. Swiftly, insert the vapor tube in the milk, if you go too slow, the steam will blow milk everywhere.
d. Go deep in the milk, but don't touch the botttom.
e. Within 5 seconds go toward the surface of the milk carefully, avoiding the big bubbles sound, you are looking for a steady "pcchhhhhh" no grunting, no bubbles, no ear piercing sound. Everytime you loose it, plunge and come back to the surface, eventually you will find the sweet spot.
f. When you are in the sweet spot, keep in mind that the milk surface rise during the process and you have to follow it, so rise slowly, following the path of the foam/milk.
g. If you feel the pot becomming to hot for your finger, you have to stop, milk doesn't like to be heated that much.
h If you succeed you will have a whole pot of foam, the milk wont separate from the foam and when you pour it, it will be like a deep creamy soap foam.
Good luck,
JF
Posted on Oct 17, 2009
2 Suggested Answers
SOURCE: Extremely loud squealing noise during steaming milk
it has nothing to do with it being blocked :)
it just a sound milk makes when boiling im trying to look for a awnesser but ever coffee machine dose the same sound when steaming milk im still researching why milk makes that sound but don't worry it not your machine it normal :)
Posted on Mar 30, 2011
My brevile cafe roma coffee machine wont operate the steam through the spout to froff up my milk.
hi there, it sounds like the steam wand is blocked up...see page 11 of the following PDF that is for your machine. also see the cleaning section of that same PDF. Notice the "decalcifying" section. http://www.brevilleusa.com/media/mediaappearance/4553/ESP8SXL_IB_C11.pdf
Hope this helps you!
Jun 11, 2012 | Breville CM5 Espresso Machine & Coffee...
Free download manual for breville espresso machine
Please log on to the link below and click for support from your location.
http://www.breville.com/
Jan 17, 2012 | Breville Coffee Makers & Espresso Machines
I have a Breville Cafe Roma Machine. I made about...
have you tried to use the sharp pin and try to dislodge coffee grind from the filter cup? You will need to remove it from the filter holder to gain access.
May 20, 2010 | Breville ESP8XL Espresso Machine
I just need to know how to make a cappuccino useing my DeLonghi Cafe Sorrento. Thanking you
Cappuccino is a mixture of espresso, a little steamed milk and a little milk foam. The milk/foam ratio is up to you what you enjoy most. Some like a thick layer of foam while others just want foam as a garnish on top. Mix as you please.
Feb 22, 2010 | DeLonghi Cafe Sorrento Espresso Machine
This could be blocked. The best way to clear this is to switch off the machine and see if you can dismantle the frother arm. Sometimes the arm will come off by unscrewing. If it does, wash it in hot water and washing liquid. If it doesn't come off try putting the frother wand into a mug of cold water and allow it just to steam the water.
Frother wands don't just steam liquids - they **** up liquid which can block the vents and the actual steam hole which this machines' problem sounds like it does have.
Apr 05, 2009 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Mar 06, 2008 | Breville ESP8XL Espresso Machine
Breville cafe roma
Obviously the problem is with your grind, not the Breville. SImply adjust your grind to finer.
Nov 14, 2007 | Breville ESP8XL Espresso Machine
Coffee Makers & Espresso Machines Logo
328 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
