Question about Panasonic Lumix DMC-FZ28 Digital Camera
Auto zooming on power up, intermittent problem
I bought my Panasonic Lumix FZ28 in November 2008. it has been fine until recently (2 weeks ago)... the fault is intemittent, and I cannot "force" the fault to appear....
Fault 1 on power up, the lens zooms out to max zoom (including digital), and the zoom lever does not function.(no other buttons on camera function)
Fault 2, similar to fault 1, power up, camera works normally,for a while, then zooms automatically to full zoom, sometimes zooms back to zero zoom, change from rec to display, and back to rec, sometimes rectifies it,
Fault 3, Power on, using camera, press Menu, to change settings, but menu on screen just scrolls (happened only once) but nothing will stop it going through all pages of all menu repeatedly.
friend has given me instructions from Service Manual for FZ18 to get error codes.... most common error code is 18000530 with a 18000930, and a 18000130, but these do not tie up with the error code list.
  • enquiries196 Sep 30, 2009
    resultdibi is only a master at providing links to equipment sales, and therefore totally useless. do not post insults on this forum
    Scholar:
  • 96 Answers
Possibly a intermittent connection in the control buttons or the ZIF (Zero Insertion Force) connector from the controls to the main PCB.
Take it in for servicing, they will do a trial by substitution (swap out control) and lubricate the connector.
There isn't really anything you can do to fix with this sort of problem.
Cheers.
Posted on Sep 30, 2009
Testimonial: "Thanks for the info.... have sent the camera back for "repair" .. as it is under 1 year old cheers"
SOURCE:
welcomejee
  • 10594 Answers
SOURCE: lost manual for Panasonic Lumix DMC-FZ18
Click Panasonic Support to download user manual of DMC-FZ18
Posted on Apr 21, 2009
SOURCE: software for lumix fz18
I could borrow the cd from a friend.
Posted on Jun 24, 2009
  • 44 Answers
SOURCE: Hi, is the Panasonic Lumix DMC-FZ28 a four thirds
CHECK-OUT .....DPREVIEW.COM TESTS
Posted on Feb 15, 2010
rajdeepdutta
  • 2517 Answers
SOURCE: when i turn on my panasonic lumix dmc fz28 it shows system error
HI there the camera lens guide pin is damages and thats why not zoom the image properly . You got the system error message. So you need to replaced or repair the lens guide pin. Thanks.
Posted on Apr 01, 2010
SOURCE: panasonic lumix Fz28, Error "Thumbnail is displayed"
I have this problem too, but only when I try to view pictures I have taken on a later model. Photos taken with the FZ28 view as per normal.
Posted on Mar 20, 2011
Why does my Panasonic DMCFZ28 take pictures when I push the zoom lever?
I suspect the snap key is shot circuited, use contact cleaner spray in the click button often press it to get ride of possible carbon shot circuit between the switch. in some cases the processor will malfunction, and if moisture or water particles gone inside, you must open the cam and clean the motherboard thoroughly with PCB cleaning agent.
Apr 10, 2016 | Panasonic Lumix DMC-FZ28 Digital Camera
The zoom wheel does not stop when I want it to. It like it has its "own" will... Once I start zooming it goes all the way until the max. Sometimes when I make it (somehow... I don't know how)...
Hello.
It sounds like your camera's lens is broken. Did you accidentally drop it? When you shake your camera, do you hear something moving inside? Like a loose part? Or looking in the lens do see anything amiss?
Aug 13, 2011 | Panasonic Lumix DMC-FZ28 Digital Camera
How to I sorce a Panasonic Digital Camera Manual of Model the Lumix DMC-FZ28
Its here :-
http://www.panasonic.co.uk/html/en_GB/Products/LUMIX+Digital+Cameras/Super+Zoom/DMC-FZ28/Manuals/1258680/index.html;jsessionid=0a6d28ef30d77015cc14c3194cda9cf3d836e92231c0.e34NaN4Rb3aPbO0SaNuKbNeQa3f0n6jAmljGr5XDqQLvpAe?trackInfo=true
May 02, 2010 | Cameras
When i turn on my panasonic lumix dmc fz28 it shows system error
Apr 01, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Lumix Panasonic DMC FZ28 18x optical zoom, 27mm wide pix always out of focus... what could be the problem? thanks!
Does it make 2 beeps and have a green spot in the center of viewfinder/lcd? if so it is thinking it is focused, test this to see. If it is 2 beeps but definitely out of focus, it will need to go in for a back-focus alignment. Simple operation for the repair team.
Sep 21, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Systems error (zoom)
there is a small gear on inside zoom lense that one not working chaing that part
Jul 11, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
When using the zoom button the cam stops working
This suggests the zoom motor has failed. As you only purchased it 2 weeks ago - it should be replaced under warranty
Aug 21, 2007 | Panasonic Lumix DMC-FX50 Digital Camera
Panasonic Lumix DMC-tz1
lens mechanism needs cleaning ( moisture ) and possible alignment ( jarred ) ; charge or replace batteries , before getting estimate ;
Jul 31, 2007 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic Lumix DMC-FZ28 Digital Camera Logo
342 people viewed this question
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
