Your Fax memory if full, thus need to free up some space. Here is what you do:
1 Press FAX >> MENU.
2 Press the left or right arrow until you find MEMORY REFERENCE. Press Ok.
3.Press left and right arrow again to find DELETE DOCUMENT. Press ok.
4.Press left and right arrow to select [1 DOCUMENT] which deletes a single document stored in memory. (take note that if you choose [ALL PRINTED DOCS] it will delete ALL the printed documents stored in memory).
5. Press OK.
6. Use left and right buttons again to select the transaction number (TX/RX NO.) of the document you want to delete. If you are not sure of the transaction number to delete, print the DOC. MEMORY LIST.
7. Press OK.
8. To delete another document, repeat steps.
9. Press Stop or Reset to exit.
If you need further assistance please dont hesitate to ask.
Hello !
You didn't indicate if you are just experiencing a problem with Faxing, not with printing.
Typically, an alarm LED flashes and lights up green to signal paper jams or improperly
installed ink cartridges. But, that would happen if the problem is more than printing, of course.
So, please let me know if your problem is just in Faxing. If not just Faxing, removing a jam or reinserting the cartridges could resolve your problem.
Sounds like the Waste Ink is full. A waste ink absorber is a pad that soaks up waste ink. An absorber can only hold a
certain amount of ink. Ttoo much ink leads to spillage.
Give this a try:
This reset should be used once waste ink counter reaches full and lock-out
occurs.
- To select something... Use the '-' and '+' buttons and then the
"OK" button.
- To go back... Use the "Stop/Reset" buttonService menu: Menu -> Scan -> Copy -> Scan (one at a time in
sequence)Select "TEST MODE"
Select "[8] ETC.."
Select "[4] EEPROM CLEAR"
Select "[1] INK COUNT"
Press the [OK] button.
Press the [Stop/Reset] button (Exits Service Mode)
press the [ON/OFF] button (which resets the printer)
The alarm doesn't flash green. It flashes orange. Also since we have the fax problem, the printer won't do straight printing. The copy light stays steady, but the Fax light flashes on and off. Does this help?
I am going to try it, Nina, (my daughter's name) and then I will let you know.
