Question about Pentax Optio MX4 Digital Camera
Can't see anything through the lens. It's as if the lens cover is still on.
Lense cover sticking on my sony cybershot w170
Most likely what is wrong is that the lens cover has become sticky, or clogged. Have you spilled a soda, etc. on it recently?
The best thing to fix this would be to aim a canister of compressed air directly in-between the lens fover and the lens, blowing anything out. If this doesnt work, then manually push the cover back with your fingernail and try again with the compressed air.
Mar 01, 2011 | Sony Cyber-shot DSC-W170 Digital Camera
Dust inside lens
this can be a doozy, but if you are up to it, remove the top cover, you may have to remove the rear, front and maybe sides, i don't know, but what you are after is the cover over the top of the lens. take that off and use air to blow it out--don't touch anything, just blow. several bursts then quickly replace the cover over the lens assy. if used in a dusty environment or ceiling mounted, you may have to do this as needed.
May 20, 2010 | Optoma HD65 DLP Projector
My screen is blank can not see anything
do you have the lens cover open? do you get any error code or warning message? do this: make sure you have fully charged battery. close the lens cover.make sure cam is off.open lens cover by sliding it down until click is heard.if no go.close lens cover.make sure cam is off.remove the battery from cam for at least 15secs.reinsert battery.open lens cover until you hear the click.if no go try this. can you see the operational buttons and icons on the screen? if you do try to initialize the camera. touch HOME ->settings (looks like a toolbox icon) -> Main Settings (touch OK) -> [Initialize] -> [OK]. if it doesn't work service might be required.thanks :)
Mar 19, 2010 | Sony Cyber-shot DSC-T9 Digital Camera
Tasco telescope[46-114500]cannot see anything through lens.bought
THE protective cover is the FRONT of the telescope!!!
The focuser is on the front like the picture above. TURN the scope around -- you have it pointing at the ground right now!
Read my TIPS on my profile page. And read this and look at the pictures:
http://www.texasastro.org/telescope.php
Jan 15, 2010 | Tasco Galaxsee® 46-114500 (500 x 114mm)...
SONY DSC W300 SAYS TURN OFF AND POWER BACK ON AND LENS COVER NOT
Internal problem of mechanism of lens assembly. May be caused by grain of sand, or anything else, probably you will have to let it repaired.
Sep 18, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
N97 camera problem
actually the back cover of the lens is the culprit. It keeps on making scratches on the lens. So instead of protecting the lens it is giving scratches at lens. This is a general problem with this set try to clean lens with cloth but it wont effect much. Go to nokia care and they well make some adjustment with the back cover of lens so that it doesnot preeses with lens ..
Aug 06, 2009 | Nokia N97 Cell Phone
Camcorder says lens cap is on when its not
This is problem of bad CCD Imager in your JVC GR-D32U model. This part need to be replaced.
JVC offers Free of Cost repair for such problem in same model cameras.
Click JVC CCD Program for details.
Nov 09, 2008 | Cameras
Lens error
i had the same problem....my problem was the lens was pushed forward and the third zoom was pushed back. so the lens is blocking the cover(thing that covers the lens) so push the lens back carefully with a cottom swab and pull the third zoomer thingy out.
Jul 31, 2008 | Nikon COOLPIX L2 Digital Camera
Lens error, restart camara issue in SD900
well **** that doesnt sound complicated or anything.
Feb 29, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Cover over lens doesn't open properly.
This is a common fault and is caused by dirt/dust/sand particles interfering with closing/opening of the lens cover ( btw before you do anything else try blowing out with compressed air ). Solution :
1) repair yourself route ( if brave and skilled enough) : remove screws and fron cover compltely. Unsolder six thin wires on the left hand side of the circuit board. When front cover is removed blow out sand /dust from the lens cover which is now quite accessible.
2) send to repair outfit route . Note that this is not an expansive repair which does not require installation of spares. So perhaps you should send it in.
Jan 14, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Pentax Optio MX4 Digital Camera Logo
46 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
